Question about Linksys Wireless-G WRT54G Router
Changed my password & now i can't get back in to reset
How do I reset my password so that i can add my new printer?
  • 64 Answers
As Sandrew said there is a reset panel in the front panel. press and hold it for 20 secs... this will reset to router to factory settings. be aware that aside form rsseting the password it will also loose any custom data and configuration you've made Good Luck
Posted on Jan 04, 2007
Boba your just a ********, next time when you configure your router you should take down notes, and reset the indicator huhhh... reset is at the back, press hold of that for 10-20sec when the power light blinks let go. Pull up a browser, type 192.168,1.1 on the address bar, password is admin (no username) make sure you dont have ip conflicts on your ISP or modem like AT&T, motorolla modem, westell modem. youll be having hard time opening the setup page. to be sure isolate modem from the router when configuring most cases DSL
Posted on Nov 14, 2008
  • foolishguy Nov 14, 2008
    aprasevic thanks of being helpful, but you should note that the settings can be found under ADMIN tab/ Config Management/BackUp, remember files where you back it up because you are going to browse that file when you restore it. better if you will put notes and stick it under your device
THat is right that it is good that he do reset, but what to do if reset is not bringing router to default settings. 1. Do reset (if functional) 2. Do setup again 3. save the confing and back up 4. again problem you could restore it Best from www.makadvb.com
Posted on Jun 30, 2007
  • 624 Answers
Most cable and DSL ISPs in the States don't require the password in the router configuration.
Posted on Feb 06, 2007
Hey thats right that he need to reset the router but then his router needs to reconfigure, so we have to save his user name and password in GUI of the linksys router (provided by the ISP )
    President:
  • 2,961 Answers
There is normally a reset button on the casing of the router, use a pen tip or paperclip and press for around 10 seconds to set it back to factory settings. I am assuming your printer is wireless, and requires a manual ip address setting; otherwise you set a normal printer to share within Windows print and file sharing.
I forgot my password and would like to chane it
if you reset the router physically the password will be reset to the default password, which you can then change.
Mar 30, 2011 | Computers & Internet
Logon password problem
okay that's easy man
start windows run in command prompt
then type this net user admin admin /add
first admin is will be your new username and the other one will be your password
then make your username become administrator local by typing net localgroup administrators admin /add
restart system then login with your new username
have a try..
don forget to rate me... :)
May 16, 2010 | IBM ThinkPad T23 2647 Notebook
I just set up the password on my macbook to get rid of a network settings problem and now the computer is saying i am putting in the wrong password!!!! I powered off the computer and restarted thinking...
Ok well try this... Resetting a user's password in Mac OS X v10.3 or later
Note: For information about resetting a password in Mac OS X v10.2.8 or earlier, see the Additional Information section below.
  1. Log in with an administrator account. Tip: If you don't know the password of any administrator accounts, see "Resetting the original administrator account password" below.
  2. From the Apple menu choose System Preferences.
  3. From the View menu choose Accounts.
  4. Click the lock button if it appears locked; enter the administrator password.
  5. Select the username whose password you want to change.
  6. Click the Reset Password button (Mac OS X v10.3 and v10.4) or the Change Password button (Mac OS X v10.5 or later).
  7. Enter a new password in both the Password and Verify fields, and add a hint if desired.
  8. Click the Reset Password button (Mac OS X v10.3 and v10.4) or the Change Password button (Mac OS X v10.5 or later).
  9. If a dialog box appears with the message "Your Keychain password will be changed to your new account password," click OK.
    1. Enter a new password.
    2. Click Save.
    3. Click the red button in the upper left corner to quit the application.
    4. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
    5. Click Restart.
    After following these steps, you'll want to also follow the steps in this article.
Feb 06, 2010 | Apple MacBook PC Notebook
Lost my user name and need to add new computer
Are you trying to connect to the wireless network ?
Or your new computer will be connected to router with the cable.
If it is hard wired to the router and the router is working for the other computers then you don't need to change anything on the router.
If you are trying to connect to the wireless network then you should know the wireless settings of the router.
Click Here for step by step solutions
Nov 06, 2009 | D-Link DIR-300 Wireless Router
I need to reset the wireless network key
If you have forgotten your password to log into the unit, you can get it back to the factory defaults by pressing and holding the reset button on the back of the unit for approximately 5 seconds
If you can log into the unit, you can reset it through the menus.
Sep 13, 2009 | Linksys Wireless-G WRT54G Router
Deleting and adding new users/passwords
try this: for IRC 3200 ,press asterisk with head press(near ?button)> ID SYSTEM setting> Dept ID management, you can add/delete Dept ID
Jun 18, 2009 | Canon imageRUNNER C3200 Color Printer
Need to add a new laptop onto my wireless router wgt624 v.3
By default, Netgear uses admin and password. The username is always admin, the password is the only thing that changes. If it's not that, there is always the reset button in the back of the unit.
Carl
Dec 30, 2008 | NetGear WGT624 Wireless Router
I forgot my Administrator Password
Take Windows Password Genius to help remove forgotten administrator password.
It not only removes Windows password, but also add new user for your computer.
1. Just get it and install it on another accessible computer.
And then burn a password reset disk into bootable USB with it.
2. Plug USB password reset disk into computer password forgotten. Boot computer from USB and then choose appropriate Windows and user. Click "Reset Password" to remove forgotten Windows password.
Besides, you can click "Add User" button to add new user.
This is a video showing you how to reset Windows 8 password.
https://www.youtube.com/watch?v=-vnCbWlOge0
Jul 19, 2008 | Microsoft Windows XP Media Center Edition...
Printer Password
If you reset the network card on the 8008 back to factory defaults it will reset the web password back to 'sysadm'
To reset factory defaults power the pritner on holding down CLEAR, keep CLEAR held down whilst you power the printer ON, keep the clear button held down untill you see RESETT on the display.
Resetting factory defaults will reset all network settings EXCEPT - IP, Sub net and Gateway address
May 13, 2008 | TallyGenicom 8008 Laser Printer
Linksys Wireless-G WRT54G Router Logo
286 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
