Question about Philips GOGEAR SA6045 MP3 Player
My Philips GoGear SA6045 displays a distorded main menu
Once I start my Philips GoGear SA6045 it displays the Philips logo and GoGear tag and then does it's quick update of the player and the main menu screen just shows distored blocks of where Philips icons or menus should be. Like it cannot display the animations or something. Just like a bad TV with distorted llines. You can see it animating because the lines are moving. Has anyone had this problem and have you found a download or app that can correct this or replace the main menu. I've done update after update, both firmware and drivers, still nothing. I also did a reset and tried the + and connect function and that did nothing either.
  • malonzo2 Nov 25, 2008
    Well after much trial and error I finally got it to go into a repair mode and fix itself. Here is what steps I took to get it back online and into repair mode.
    1) Turn off the unit.
    2) Have a pin on hand and ready to push in the RESET button.
    3) Turn back on the player. As the player is just starting up push the RESET button.
    4) The player will go black and turn itself off.
    5) Turn on the player again, if it does not attempt to repair itself, repeat until you get a repair state.
    6) Once the repair message comes up, connect your USB to the computer and let it fix itself.
    7) Mine is working like a brand new unit now.
  • 8,596 Answers
Xxx
There is a program on the installation CD called the Philips Device Manager - it has a Repair option. If you have lost the CD, you can get the Device Manager from Philips website.
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
xxx
Posted on Jan 01, 2009
How do i change th time and date on my phillips gogear player
Here is the manual for your device:
http://download.p4c.philips.com/files/s/sa6045_37/sa6045_37_dfu_aen.pdf
You will find how to set date and time. Go to main menu, choose Settings then Date and Time and so on...
I hope this helps you.
Bye,gylacz
Feb 06, 2011 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear HDD086/05 backlight will not stay on
go to the settings on the mp3, go to backlight and set light to "always on".
May 20, 2009 | Philips GOGEAR SA6045 MP3 Player
Will not start
I have a Philips GoGear SA3025/37 that is somewhat similar to the Philips 4GB digital audio player. Maybe your audio/video player circut board is messed up. Try getting a new one.
Mar 16, 2009 | Philips GOGEAR SA6045 MP3 Player
MY philips go gear 2gb music player does not getting on.
Run a Repair in Philips Device Manager - the program came on the installation CD.
If that fails the first time: Unplug the GoGear from the PC. Uninstall all Philips software in the Add/Remove Programs section of Control Panel. Restart your computer and reinstall the software. Replug the GoGear. Re-run the Repair.
-Tha Mp3 Doctor
Dec 27, 2008 | Philips GoGear SA178 MP3 Player
GoGear SA6045/37
oh okay
its now a matter of changing a igniotion circuit inside the board
if u dissemble ur device u will smell a kinda electronick burn smell
that assure my diagnotise
Aug 19, 2008 | Philips GOGEAR SA6045 MP3 Player
Logo of the company/philips
you can see it at www.usasupport.philips.com
Jul 23, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player doesnt register.
I worked on this thing (sa6045) for three hours................no luck.Finally got a fix.....Go to programs add/remove menu under control panel and delete Philips device manager.Then go to Philips site and download new driver:http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&mid=Link_Software&cat=MP3_PLAYERS_CA&sct=SU00304_SU&grp=PORTABLE_ENTERTAINMENT_GR&session=20080506223817_68.47.250.64&ctn=SA6045/37&dct=PAL&did=AEN&file=/files/s/sa6045_37/sa6045_37_dmr_aen.htm
Install your new driver and be SURE windows media player is not running or trying to sync.If it is running in background philips device manager will not work.Once new driver is installed you can pull up the repair panel and do a hard reset thru software on your Sa6045.
Good Luck
May 03, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear SA6045 MP3 Player
Either try replacing the screen or if the player has firmware to either update it or reinstall
Sep 16, 2007 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
202 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
