Question about HP DeskJet 5650 InkJet Printer
Get one cartridge in a 5650, 2nd cartridge will not go in
Doesn't matter which one is put in first. If black goes in first, color won't go in. If color goes in first, black one won't go in.
  • HP Master
  • 990 Answers
Hi dear; Are you got "off market"cartridge, if you are bring back to store exchange I believe that the cartridge is damage.
Posted on Dec 29, 2008
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
HP 4700 not printing cyan
If your printer is missing a color it could be caused by (off the top of my head) 3 possibilities.
1. High voltage board
2. laser/scanner assembly for that color
3. DC controller might need a firmware upgrade,
Run the PQ diagnostics, check the cyan color
Run the Cartridge Disable diagnostic. Remove all cartridges and take the black cartridge and insert it where the cyan normally is. If the black prints in the cyan slot, your cyan cartridges are bad. If the black doesn't work then go to #3 above. It won't cost any money to upgrade the firmware. If it still doesn't work call in a printer tech.
At this point you may need a printer tech.
Nov 01, 2011 | HP LaserJet 4700 Printer
I want to print using my lexmark X6170 but I don't want to print color so I didn't put a color cartridge in. It keeps coming up with an error message and won't print at all.
Some printers require you to have the color cartridges in them even when you are printing black and white. You usually can in your print options choose black and white over color.
Sep 03, 2011 | Office Equipment & Supplies
The priter goes through the motion as always for printing but a blank piece of paper comes out. I have cleaned the print head but It still does the same thing. Do you have any suggestions that I might...
If you are printing using a color (not "black cartridge only" ) driver, yes, the printer won't print because it uses a "process black" when you use a color driver.
In other words it creates black using the 3 colors, and doesn't actually touch the black cartridge.
You will need to change the default driver to one that you create.
go into control panel, hardware and sound, devices and printers (win7)
right click the officejet 6500 (not the fax driver) and click printer properties
click the advanced tab, and click printing defaults
click the fast economical printing template.
Change "print in gray scale" to Black Ink Only
Click "save as" and name the profile "black draft"
click the newly created "black draft" profile, and click APPLY and OK
This will now be your default, and it will print in black and white while the color cartridges are empty.
Jul 29, 2011 | HP Officejet 6500 Wireless All-in-One...
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
My epson stylus SX115 won't print out.....It says no black ink, but it has color........
Epsons will not print at all if ANY of the cartridges are empty. It doesn't matter whether or not you want to use the color exclusively or not.
Apr 28, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Installed new black cartridge in Deskjet 810C printer and after doing this it will only print in pink color. Please help.
Make certain that the cover is off the jets - if you forgot to pull the strip off or it broke leaving part of the tape on the cartridge, it won't work. Try to do a clean process on the cartridge. If that doesn't work, and you don't have another printer to try the cartridge in, return it to the place you bought it and get another new one. If the printer is printing pink, the color cartridge is probably empty also so that it cannot make black from the other colors. These sound like refilled cartridges - OEMs would have failed with some form of error code or warning.
Apr 11, 2011 | HP DeskJet 810c InkJet Printer
I lost my manual for my lexmark x1270 all in one printer.Can you tell me in what order is the ink cartridges placed.Black first or color first?
Here's the link to download the Lexmark X1270 setup sheet: Actually, it doesn't matter what goes in first as long as you have the right cartridges installed. Black cartridges for X1270 are #16 and #17, and color cartridges are #26 and #27.
Aug 30, 2010 | Lexmark X1270 All-In-One InkJet Printer
Won`t recognize new ink cartridges. Still insists black is empty, other colors low, although all have been replaced. Any way to reset or override? Thanks
Hi there
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Things You'll Need: · Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 03, 2010 | Brother MFC-230c Printer
HP DeskJet 5650 InkJet Printer Logo
Ben Johnson
