Question about Whirlpool ET1FTKXK Top Freezer Refrigerator
Whirlpool ET1FTKXK Fridge not working
My 6 yr old whirlpool fridge is not working at all. The freezer is working fine, and actually has ice crystals all over. I used to have a problem with water dripping inside the fridge part, from the ceiling of the fridge, that I had ignored.
Thanks for all the help.
  • gayathri78 Nov 28, 2008
    Thanks! I opened the base cover, like you had suggested and found huge amount of ice in and near the drain hole. I turned the fridge and freezer off, and let it thaw out. On turning it back on, both freezer and frdige are operating just fine! Thanks much
  • 306 Answers
The reason you had water dripping from the top is the frig goes into a defrost cycle every 12 hours or so and melts the ice build up. Now your drain line for the water to go down to bottom of frig is plugged more then likely with ice. Take the cover off back of freezer and get some salt table salt be good. And put it in the drain hole located roughly in the center of freezer cabinet. That will take care of the drain quick. Now notice to see if the fan on the inside of freezer is on. My hunch is that it is not turning. You can replace the little fan motor make sure you don't damage the fan blades you will re-use them. Be sure compressor is on cause the fan only works when compressor is on. Let me know what you find out.
Posted on Nov 26, 2008
Whirlpool top freezer 18c.ft w/ icemaker: freezer works fine. fridge does not cool below 56 degrees. vacuumed dust from bottom, turned entire unit off and restarted but still not working, in back of
i think you have to check to make sure that
the fan inside the freezer is cycling on.
it will be concealed of course but you should
be able to hear it. i replaced one once with
the same symptoms and that fixed fridge
portion of a 2002 or 3 whirlpool. make sure
to listen closely and not mistake it for the
stronger fan motor which operates in
conjunction with and nearby the compressor.
Feb 05, 2013 | Whirlpool Refrigerators
I have a Whirlpool Gold top-mount fridge (GR2SH/GR2SHM). It's about 6 years old. About a year ago the freezer started to have ice build up and water would over flow into the fridge. I defrost the...
The defrost cycle is not working. After a predetermined number of hours of compressor running time, a timer actuates the defrost cycle, which stops the compressor and turns on a heating element to melt the ice. Either the timer or heating element is not working. Also, make sure the melted ice water is actually draining and not re-freezing.
Aug 31, 2017 | Whirlpool Microwave Ovens
The things in the freezer are not frozen and there is ice in the milk in the refrigerator. It a 6 year old Whirlpool side by side.
You possibly have a 2 part problem. Do a 12 defrost and make sure the product in the fridge is not near the auger (cold inlet vent into the fridge). Fridge gets its frost from the freezer compartment.
Nov 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Our whirlpool 6 yr old refrig / freezer is not working correctly
Use a vacuum and clean under your fridge. A dryer cleaning brush will help make the job go much faster. Use a good light so you can get all the lint out. Give it 12 hours to level out. hope this is helpfull.. Saw
Aug 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side-by-side won't get cold, compressor clicks on-off.
Sounds like the start relay OR the compressor is no good. Have a service tech look at it, because there may be a capacitor in the circuit, which could be dangerous for you to fool with.
May 28, 2009 | Whirlpool Refrigerators
Whirlpool conquest fridge; freezer isn't working
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
Oct 03, 2017 | Whirlpool Freezers
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
Whirlpool ET1FTKXK Top Freezer Refrigerator Logo
236 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
