ATI Catalyst Control Center settings
The message "You do not have permission to change Catalyst Control Center settings, please contact your administrator for further help" has all of a sudden appeared on my PC at home and i am now unable to use Internet Explorer. Im even having difficulty in accessing my programs menu through the START button at bottom of screen. This seems to be causing major probs with my PC can you help pls??
sandrew
  • 2961 Answers
SOURCE: cannot access my control panel
you should be able to open another account in the users, to do this start the pc in safe mode F8 while booting,when in windows either open a new account or change your old one to administrator.
Posted on Sep 26, 2007
  • 99 Answers
SOURCE: ATi Graphics error
Try installing the lastest catalyst drivers: http://ati.amd.com/support/driver.html
Posted on Jul 26, 2008
  • 565 Answers
SOURCE: Catalyst Control Permission Problem
It seems u dont have administrator privileges to do it
Posted on Dec 26, 2008
SOURCE: Problem with integrated webcan Lenovo 3000 N100 notebook
Buy external webcam; troubleshoot this problem was westing our time.
Posted on Mar 28, 2009
SOURCE: Ihave an ACER Aspire M5630
re install the drivers.
Posted on Apr 07, 2009
My son's dell Inspiron mini is having problems after sign on. The Desktop and windows that appear after that are reading upside-down and we cannot figure out why it happened. Any advise to get it...
I think that Ctrl+(Alt and/or Shift)+(Up or Down) should fix it. There are a couple of key combos to check, but I'm sure that one of the above will fix it for you.
If the key replys dont work you can go into the advanced settings of your video card and set it there. On my x1400 I can do the same thing in the ATI Catalyst Control Center. Once your in there you can turn the Hot Keys off that will flip your screen like that and you can also flip your screen the right way round.
Steps to get there if you have an ATI video card and ATI Catalyst Control Center installed.
1 - Right click on your desktop.
2 - Select "properties".
3 - Select "settings".
4 - Select "advanced".
5 - Select "ATI Catalyst Control Center".
6 - Select "Displays Manager"
7 - Once the "Displays Manager" tab opens you should see at the bottom tab you should see a box marked "rotation". Set your rotation to 0 degrees landscape.
While you are also in the ATI Catalyst Control Center you can also click on the "Hot Keys" tab and turn the ATI hot keys off that flipped your screen in the first place. John
Feb 08, 2011 | Dell Inspiron Mini 10 Notebook
Can't setup dual monitors on ati radeon x1050
Hello
You might have installed ATI's CCC, "Catalyst Control Center", along with the display drivers. I suggest you download the latest combo-CCC and drivers for your video card. ATI comes out with new drivers pretty fast. When using dual monitors CCC is where you want to setup your monitors. After you set up the catalyst control center you'll find it much easyer to assign what monitor displays what. One other suggestion. ATI will want you to uninstall any other software for your ATI card even though all you have is ATI software.
Hope it helps, if so do rate the solution
Dec 21, 2010 | ATI Computers & Internet
I have 2 acer data managerment problem found in edata security software installation it says please close all running programs and reinstall edats security. the second one is catalyst control center is not...
Close programs (word-processor, web-browser).
Click Start
Click Control Panel
Click Classic View
Click Add/Remove Programs
Click on EDATS SECURITY (or something approximately that)
Click Remove
Click OK
Shutdown
Restart
Reinstall the software
> catalyst control center is not supported by the friver [?]
> version of your enabled graphics adapter.
ATI (www.ati.com) distributes the "Catalyst" software with their adapter video-cards. So, there is a problem with the "Control Center" component of their software.
> please update your ati graphics,
> or enable your ati adapter using displays manager
First, do you have an add-in video-card in your computer?
If not, then you should not be trying to use the ATI software,
and you should remove it:
* click Start
* click Control Panel
* click Add/Remove Programs
* select the ATI Catalyst software
* click Remove
* restart your computer
Second, if you have added an ATI card, you may need to restart your computer, press DELETE to enter BIOS SETUP, and "disable" the "onboard" video-adapter, or change the video-priority so that the ATI video-card becomes the "primary" video-adapter, and the onboard video-adapter becomes the "secondary" video-adapter.
Then, click Save Changes, and before selecting Exit From Setup,
move the video data-cable from the onboard VGA port to the VGA port on the ATI video-adapter. Then, "blindly", click Exit, and let your computer restart. Then, during the reboot, the ATI software will recognize the new "primary" video-card, and will the software will control the ATI video-hardware.
Sometimes, it helps to have a second computer monitor, and connect one adapter to the "onboard" VGA-port, and the other to the ATI VGA-port, so that you can see video output wherever it is produced.
Nov 09, 2009 | Acer Computers & Internet
ATI Radeon HD 3200 conflict with NVIDIA GeForce 9500 GT driver
To solve this problem, uninstall the old driver, the ATI Radeon, it will not cause a problem when you uninstall it. After the uninstall, restart the computer and then install the support cd for the NVIDIA Geforce 9500 GT.
Oct 28, 2009 | Computers & Internet
ATI Rage mobility graphics card update for dualview
Display Driver
http://ati.amd.com/support/drivers/xp/radeonxprevious-xp.html 13.3MB 8.12 12/10/2008 Display Driver Only tooltip.gif try this you might need new update to receive dual view
Resolved Issues for the Windows XP Operating System
This section provides information on resolved issues in this release of the ATI
Catalyst™ Software Suite for Windows XP. These include:
• Using an HDMI cable to connect an ATI All-in-Wonder to a Yamaha receiver
may result in the display resolution being limited to 1280x1024 and audio
failing to function
• Catalyst Control Center, some of the 3D settings are not displayed on ATI
Radeon HD 4870 adapters
• The operating system may fail to start after installing the display driver with
some configurations of "Crosfire" with Radeon X1900 Series devices
• The operating system may intermittently fail when exiting Test Drive Unlimited
after extensive game play
• Dual display, playing multiple video files on each monitor may cause the system
to stop responding
• City of Villains: Attempting to launch the game on a system running Windows
XP and containing either two ATI Radeon HD 38x0 or 46x0 products
may result in the game failing to load and the operating system failing to
respond
• Some OpenGL applications may cause the OS to stop responding on some
ATI Radeon HD 45xx adapters
• On some configurations, the display driver may stop responding when resolution
is set to 2048x1536 with 8X Anti-Alias and Edge Detect filter enabled
• Exiting some games may intermittently cause the following error message
when 8X anti-alias edge detection is enabled: "Display Driver stopped working"
• Hot unplugging a HDMI connection during video playback may cause system
instability
• Catalyst Control Center: Enabling pulldown setting may not work on all video
formats
• Systems configured with Overlay Theater Mode enabled may intermittently
become unresponsive after playing video
• Catalyst Control Center, setting the de-noise slider does not affect the quality
of progressive video content
• Intermittent flickering may be noticed on the TV out display when playing a
DVD using Cyberlink PowerDVD
Jan 22, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Dec 26, 2008 | ATI Computers & Internet
ATi Graphics error
Jul 26, 2008 | ATI RADEON HD 2400 PRO Graphic Card
ATI Radeon IGP 340mM/345M display driver or software needed..
Go here:
ATI Catalyst 8.2 - ATI Radeon - XP
Then, near the bottom of the page, click on:
Individual driver download packages, ATI Multimedia Center, Avivo™, and Korean full package and download the Catalyst Control Centre package (download 2 of 3)
Here is a direct link, but i don't know if it will re-main active:
AMD GAME! Drivers and Utilities
Then click on "Catalyst Control Center (English)"
This package will only install the ATi CCC. I personally have found that the ATI CCC doesn't like older cards, but some people have had luck getting it to work. If it doesn't work, you'll either have to find an older Catalyst Control Center, such as the one bundled with the Catalyst 4.10, or go back to using an old version of ATi Catalyst Control Panel.
Apr 29, 2008 | ATI Mobility RADEON Graphic Card
Vertical/horizonal
There is no button on the monitor that sets this that I can find.
it is likely you changed the rotate settings for the video somehow.
If you have an ATI video card.
you should see an icon for ATI on the tool bar by the time and date .
right click on it and choose catalyst control center. in there you will find the rotate desktop.
if you don't see the icon then you can find it under start/programs/catalyst control center
Feb 25, 2008 | 3Com EtherLink III Combo Network Adapter
Samsung tv
Your ATI has two DVI connectors but your monitor can only take CRT. In the box came an adapter to change your video signal from DVI to CRT. You connect this to your monitor cable & hand tighten the 2 screws, this connects to the video card. While in windows open control panel, than open Display than click Settings. Click Advanced. Among the tabs here, there should be a tab that says Catalyst Control Center. This is where you setup your display. You can't be switching between the two DVI ports. Ya need to stay with one. The second is for another monitor.
In here is also Help. The control center will help you adjust your adapter. If you do not have the Catalyst Control Center you'll have to download it from this link: http://ati.amd.com/support/driver.html
Enjoy!
Please vote...
Nov 05, 2007 | Power Color PowerColor ATI DVI Adaptor for...
Open Questions:
Steps To Fix Toshiba Laptop virus and Freezes Issue Call toll free Number :+1888784-9316 Are you facing sudden pop-ups on your computer or witnessing slow loading of files and programs? If you are getting issues like slow internet and processing, unexpected computer behavior then contact Toshiba support for making your computer free from all such dangerous online threats. Toshiba support provides safe and secure removal of all virus and other infections along with protecting the system from any such instances further. Toshiba support providing technicians make sure that your pc is secure and also that all your important files and documents are safe from any type of harm. If your system is infected with viruses, Trojans or malware then it might show signs like slow computer processing and internet speed, unexpected computer behavior, sudden freezing and crashing down of the system, frequent arrival of error messages, many advertisement pop-ups, non-intended outgoing emails and messages to contacts, files disappearing, problems in hardware and accessory devices, screen freezing and image blurring issue etc. Toshiba support helps in scanning all the variants of virus inhibiting the system by using proper scanning process and removal processes after that. Many a times, user while scanning viruses on his system might not be able to remove all even after many attempts. This happens because system gets infected to new variant of virus due to vulnerabilities of programs used in that system or because of inefficient scanning methods. The anti-virus program used for scanning the presence of that virus might not have got that virus's signature. So, for proper and efficient scanning of all viruses and removal afterwards, it is necessary to take help from experts like Toshiba support technicians. These technicians utilize the efficiency of advanced techniques and much better tools to clean the system and make it infection proof in order to yield greater productivity. Specialists of Toshiba support collect samples of all the variants of new and recent viruses and update the user's software database with their signatures. In case your system is also suffering from the infection of any such viruses which is new and is creating trouble getting detected, then contact Toshiba support us for help on their toll-free Toshiba customer helpline number +1888784-9316 anytime for expert supervision and advice.
Aug 14, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
67 people viewed this question
Alun Cox
David Payne
David Payne
