Whenever I format my USB, It always says that "the disk is write protected" how do I format it.... I've tried some of the solutions that I have found here on this website but they don't work... plz someone help me....
Click start click to open on my computer you should see your Usb drive E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
right click on your usb drive select format
if you need more help with this post a reply
hope this helps you
SOURCE: Not able to format 32gb kingston usb device givin
this problem may be due to a strong virus
just go through Dos promt
by writing cmd in run place at start menu
and then cd..
till u not get c:\ prompt
then write pendrive location like g: and press enter button
then u get g:\ then write format and press enter
hope by this process u will format ur pendrive
SOURCE: can't formated 4 gb sandisk usb drives
dear,
Follow these instruction and the work will be done..
Click start
Click Run
Type "CMD"
Hit Enter - A black screen should now appear (this function can be achieved by selecting Start---->Programes---->Accessories---->Command Prompt)
Type "diskpart"
Wait untill you get "DISKPART>" then type in "select volume (blank)" fill in the blank with the letter of the drive you are trying to remove write protection from
Now type "attributes volume clear readonly"
Remember select correct letter otherwise u will loose data of other drive..
e.g; if your Flash USB drive is F then type F there..
goodluck..
hope it will fix the issue so dont forget to rate it.....
SOURCE: Kingston Data Traveler 2.0 64 GB USB - file system
2gb kingston pen drive showing capicity only 4 mb so pls provide the solution
SOURCE: I HAVE A 4 GB
Click Start
Click Run
Type CMD
Press Enter
Type CHKDSK q: /F
where 'q:' is the drive-letter assigned by Windows to your Kingston.
Press Enter.
When "check-disk" has completed, Windows will remote the "write-protect".
