Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
The water doesn't go through and there is no coffee coming out... There is always lots of water under the machine... Vienna
  • 1 more comment
  • anabdavies Nov 25, 2008
    Still nothing is working....
    I have checked everything ...is there some kind of motor for the water inside the machine?
    I have opened the machine...I think I might have one something wrong...It's making a strange noise now...Is there any engineer in London that I can send the machine to?
    I have no more energy to mess around with it...
  • 928 Answers
You may call this number and or email for information on where to have your unit repaired in London for the official seaco repair
Tel: 01422 330295
Email:info@saeco.uk.com
You may also go to the link below for a third party company that fixes espresso machines in london.
http://www.londonespresso.com/services_repair_london.htm
Posted on Nov 25, 2008
  • 4,806 Answers
The machine probably needs a right good clean, if you live in a hard water area there could be a build up of limescale, to clean the coffee maker using some linescale remover
kind regard and the best of luck
    Sergeant:
  • 291 Answers
Just get your machine serviced at your nearest service center they cost $120 for servicing .if any of the part is faulty in it and replacement that will be extra.as this is the common problem in this machines of getting clogged in the tubes and they also getting worn out.also the valves needs replacement sometimes.
    Sergeant:
  • 229 Answers
The flow arm is broken. It is found under the bsket where the pot slides under. Fix or replace this flow arm and it will work good as new. Thanks Good Luck
    Genius:
  • 1,239 Answers
Hi
  • There is a black tube that carries the hot water to the drip area.
  • There is the drip area (on the left-hand side of this picture). Water arrives here from the black hot-water tube and simply falls through the holes into the coffee grounds.
Looking at this picture, you get your first impression that this isn't a high-tech device. If you take the bottom off the coffee maker, here is what you will find: the one of these problem cause your problem
  • The one-way valve can get clogged open or closed. You can usually fish out the debris that causes this problem with a toothpick.
  • The tubes can get clogged with calcium. This is especially true of the aluminum heating tube. The normal way to solve this problem is to run vinegar through the machine once, and then run two batches of water through to clean out the vinegar.
    Genius:
  • 1,142 Answers
Check for clogged hose.
    Sergeant:
  • 276 Answers
This indicates the problem with the water supply assembly .water is not going through due to some blockage or internal pressure leakage.check it 1 by 1.
    Genius:
  • 1,550 Answers
Switch off the machine
  • Check all supply taps are open
  • Check other water supply points / faucet are working
  • Check for damaged / kinked pipe
  • SAM ANDERSON Nov 25, 2008
    Mineral deposits from the water may be clogging the pump or other parts. Try descaling.
I always find coffee liquid under my coffee maker seaco Vienna superautomatica
are you putting too much water in it ? try a little less next time
Feb 21, 2015 | Coffee Makers & Espresso Machines
I need instructions of how to clean the Saeco Vienna Superautomatica in and outside. We lost the manual.
-Rinse Brew unit under warm water, and let dry.
-Rinse coffee tray, water tray and water tank under hot water (may melt in dishwasher)
The rest coffee been tank and exterior needs to be washed with a warm cloth, just make sure it is not to damp, which could leave water drops in the grinder.
Feb 07, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna leaking water from bottom of machine
The o-rings of the water tube coming out of the boiler need to be changed. Rubber O-ring tend to expand after extended exposure to heat.
Jan 03, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna leaks coffe from under the machine.
1-Try changing the seal of the water inlet under the tank (part# NM05.006)
2- Check the o-rings from the water tubes coming in and out of the boiler.
Oct 19, 2010 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna coffee when the machine starts the coffee dispensing
Is it leaking only when brewing coffee ?
If not I would check the seal under the water tank (Part #NM05.006)
If so, I would check the following:
1- The water input port on the back of the brew unit (looks like a smoke pipe) might be clogged
2- The o-ring of the water tubes coming in and out of the boiler.
Jul 30, 2010 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna leaks CLEAR water from under the machine. A tiny amount of coffee makes it through to the cup
The leaking is from the water pipe coming from the boiler thought the solenoid valve to coffee group. Their are many points that this leak can be so the only way to find it is to run the machine completly open without the plastic sides. The most posible postion is the plastic hose conected on the coffee group and some times you will have to place it back in position very easy.
Good luck.
Remeber to vote for this answer.
Feb 24, 2010 | Saeco Vienna De Luxe Espresso Machine
Red warning light comes on and stops
put a cup under the water spigot and turn the knob to release the pressure
Dec 09, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco vienna "machine ready" light (second light) blinking--not allowing to dispense coffee.
Try to open the steam knob and make a cup of water(Tea).
Best regards
/Mirran
Oct 21, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Digital
I had this problem on my Saeco Vienna Digital a while back. I read somewhere just to keep on ventilating, even if it took 20 hoppers of water. Sure enough after about 16 cycles, I heard a change in the noise and looked to see the ventilate sign was gone.
Oct 24, 2007 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
59 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
