Question about Kenmore 63942 Dryer
Kenmore Dryer does not heat.
Kenmore dryer (model #66902), does not heat. Powers on, drum spins, but no heat. I have a list of things that it may (or may not be) but I can not get into the unit. Where are the fuses? Heating element?
  • 5 more comments
  • jqzw Dec 01, 2008
    My Kenmore 90 Plus Series Dryer doesn't heat. It spins as usual when it is set to COTTON, but no heat comes out after power is on for a long time. Is it possible that the fuse is broken?
  • Anonymous Jan 26, 2009
    my kennmore dryer will not heat
  • nelix2008 Jan 26, 2009
    where is the fuses alocated
  • Ninhfrank Feb 05, 2009
    When i start the dryer the heater heats up but after awhile (15mins) it stops. As i restart the dryer the heater no longer heats up but it runs on cold air throughout the auto timing cycle. When the cycle is finished its stop by itself. After 3 hours i put the dryer to automatic again and i start it then the heater heats up after awhile (15mins). It continues to repeatedly do the same thing. I don't know what's wrong with the dryer, please help me?
  • halogen242 Feb 10, 2009
    ditto
  • Anonymous May 08, 2009
    Dryer not heating
  • Anonymous Mar 25, 2014
    drum spins, exhaust line is clear, not drying/heating
  • Kenmore Master
  • 8,220 Answers
Posted on Feb 07, 2009
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Hi my whirlpool doesent speen
? 6:29
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will notturn - 11068202794. ApplianceVideo.com ...
Kenmore / Whirlpool Washer Not Spinning 1 - YouTube
? 11:33
https://www.youtube.com/watch?v=TB_W6sPdzkM
Jul 10, 2012 - Uploaded by Bill Newberry
Kenmore / Whirlpool Washer Not Spinning 1. Bill Newberry ... Washer will not spin the clothes dry ... Now ..
Dec 03, 2015 | Whirlpool Dryers
Dryer does not heat correctly code F31
The thermostat which is a round 2 wire control on the blower box on the back of the dryer controls the heat on all dryers. always shut off power when checking any electrical appliance. Clothes dryers are wired with 2 voltages, The 240 volt supply is for the heating element only, while the 120 volt supply gives power to the timer and motor that spins the drum and powers any lights and switches. If the heating element is coming on, try replacing the thermostat. As always unplug the dryer first.
Dec 05, 2013 | Kenmore Dryers
Heat works on dryer but won't spin... the drum
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 28, 2011 | Kenmore Dryers
Dryer does not heat, drum does rotate
check the tstats on the heat can
Apr 23, 2009 | Dryers
Dryer wont spin
Take the back off  of the drier after unplugging and the beklt goes from the motor pully all the way around outside of the the drum.You can't miss it. Most of the Kenmore drier belts are the same. WE have apliance repair parts stores locally.If you also do , go to the store with the old belt and match it up.
Dec 19, 2008 | Kenmore 63942 Dryer
Dryer won't spin on my kenmore stacked model 417.90812991
This is the 2nd time I have this problem.
IF you look thry the drum to the back you should see 3 screw heads. Mine has one screw still in the hole and 2 empty holes.
This requires the drum to be removed (like take the drier apart). Behind the drum is Asmbly-shaft (ball hitch) (item 32 in the parts list). This what the 3 screws screw into.
I spent 2 days trying to put the screws in without removing the drum not possible (no way to hold the drum in place)
The first time I had to replace the drum because it wore the rim through.
I have to get 3 new screws and some thread locker.
I recommend that you check the screws every month, Use a long phillips screw drive
Nov 02, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Kenmore 63942 Dryer Logo
1,248 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
