Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby Did you find a fix for The Ultimat G? Taking any suggestions.
  • 1 more comment
  • dporter538 Nov 25, 2008
    There are two places a saftey switch is; one where you attach hoses. The other is at the base of the handle where the bag connects; after a problem with a bag this must be pushed. Fixed mine!
  • Denny Adams
    Denny Adams May 11, 2010
    what is the actual problem
  • Rocky
    Rocky May 11, 2010
    This is posted as a PROBLEM but it is not clear what is the problem?
  • 4 Answers
When you push the heel of the boot (armat.) towards the machine, you should make sure you feel a firm snap into position.
Posted on Jan 14, 2009
My kirby is making a very loud noise and somehow the white fan inside has broken. I have the pieces. What do I need to do? I can't find a vacuum repair place near my location. Can I fix this myself?
What you need to do is a long process of taking apart the vacuum apart. Your fan broke so you are going to need a new one. So go to Kirbys website and look up a nearby vacuum store. Or More recommended a Kirby. It is a long process of taking the vacuum apart,
Mar 26, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Plug in kirby vac to do the floors and it won't start.
It could be the power cord or even the switch. I suggest taking it to an authorized Kirby repairshop and have it looked at. It could be something as simple the power switch
Aug 25, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby Generation 3 no power...
I don't believe there are any service manuals online, as Kirby has service centers around the country. There are 3 things in the power string--on/off foot switch, the power cord, and the power assembly that the cord plugs into underneath the bag in the main part of the body. One of the problems the G3 had was where the cord plugged into the body--the assembly was a very thin plastic piece supporting the 2-prong electrical connection. This plastic piece was known for breaking, and was actually recalled back in the 90's. You can take the cord connection off and look to see if that piece is broken, then you'll have to take it in, or buy a "switch" as it's called on ebay or somewhere and replace.
Dec 29, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G5 intermittent power
I would say that it is a short in the power cord.
Try my troubleshooting guide. It helps with do-it-yourself Kirby repairs. You'll also find links to directions, parts (cords too!!) and free repair guides!
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Jul 31, 2008 | Kirby G5 Bagged Upright Vacuum
My kirby g6
Try taking it to a local kirby office and ask them if there is anyone in your area that can refurbish the motor instead of replacing everything. If that doesn't work ask a local dealer or call the dealer that you bought it from and tell them that you would like to trade your old one in for a newer one. I used to work for Kirby and I can guarentee that the Kirby itself, straight from the factory only runs about $200!
Jul 09, 2008 | Kirby G6 Bagged Upright Vacuum
Help on kirby G4D
here is a link to taking the fan off of the kirby...all the Generation Series Kirbys are the same :)
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
Hope that helps!!!
Apr 05, 2008 | Kirby G4 Bagged Upright Vacuum
Electrical
PROBLEM: THE KIRBY WILL NOT TURN ON AT ALL
POSSIBLE CAUSES:
Please note......The Kirby has TWO safety switches that need to be engaged before it will operate. One is on the fan case in the front. It is activated by having an attachment attached to the front. (hose, power nozzle, etc.) The other switch is on the side of the Kirby where the cloth bag attaches and is engaged by the little tab that sticks out from the side of the hard plastic cloth bag "boot". The bag boot MUST be completely engaged to activate the safety switch and allow the Kirby to power on. If you are having trouble getting the bag to properly engage, (sometimes they are STUBBORN) simply lubricate the black gasket that the boot fits onto with gasket lubricator, VASELINE, or try a tiny drop of DISHWASHING DETERGENT or HAND CREAM. It doesn't take much, so use the smallest amount possible to get the desired effect. You should hear a slight "pop" when the bag completely engages.
If neither of these things are indicated, it is probably again, either the power cord, switch or the carbon brushes.
If your Kirby is sparking there are a few causes...
PROBABLE CAUSE (MOTOR): Worn out carbon brushes, bad armature or perhaps BOTH
PROBABLE CAUSE (CORD): The cord has a short in it. Replace the power cord
PROBABLE CAUSE (POWER NOZZLE): There is something metallic stuck in the fan or power nozzle
I think you have a problem with the carbon brushes and amature because of where you describe seeing the sparks. I would suggest taking it to an authorized dealer for repair if it is the motor that is going bad.
Apr 01, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Sentria
If the green light is off, then its time to replace the band. This video shows you how.
Jan 16, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5 - Stopped
The carbon brushes in the motor need to be replaced. Very IMPORTANT....... DO NOT run the Kirby anymore until you get this fixed. If you do, the armature will be in danger of being damaged. (and that part is expensive!) The carbon brushes are reasonably priced, and you can use this online guide to get to them and change them. It's a guide for replacing the power switch, but it will help you change the carbon brushes too. Hope I've helped...
Marci
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Nov 07, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby g 2000
I would suggest taking it to a vacuum repair place to do this. There are just too many screws and seals that you have to break and reseal for someone who doesn't know what they're doing. However, if you still want to do this yourself, I have a fan kit and will be happy to send you one. You may call us at 1-866-509-1952. Thanks
May 08, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
21 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
