Question about Eureka Vacuums
Was vacuming floors and it just q2uit no power
    Scholar:
  • 55 Answers
The most common thing would be a bad cord. It could also be a switch, the heat sensor or fuse(depending if you have one on that particular model). All of these can be tested with a continuity tester.
It could also be the motor, but usually the motor tends to smoke, stink, and spark before it shuts off completely. Do do a quick check to see if it is the motor you can manually turn the brushroller(if the belt is still good) and that will rotate the motor a around and sometimes that will make it kick back on if it is the motor. Now that probably won't fix it. It might sound terrible, but you'll know what the problem was.
Some vacuums have a reset switch on the machine that could have been tripped. They are usually on the back of the machine towards the bottom. Not all vacuums have these, but it's something to look for.
If it overheated, you just need to let it cool off and try it again.
I hope one of these suggestions helps. Good Luck
Posted on Nov 26, 2008
Vacum has suction, but won't pull debris from the floor
The vacuum may not be set for use on carpet.
Jan 19, 2017 | Vacuums
Should the rotating brush be rotating at all times when vaccuming
The brush should rotate when you are vacuming carpeted floors but not when vacuuming hard surface floors.
Jan 19, 2017 | Dyson Vacuums
JUST HAD THISPRODUCT FOR TWO WEEKS ,BOUGHT AT HARVEY NORMANS. THE POWER BRUSH WONT COME ON. PLEASE HELP
Some hard floor settings on vacumes stop the brush rotating, there is normally a tab or rotating knob that you have to turn, also normally with a little picture showing position
Oct 06, 2015 | Vacuums
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
I have the bissell powertrak revolution. I have hardwood floors...even on the lowest setting it is throwing some dirt back at me instead of picking it up....
do not worry about this....it is a common issue with every brand of vacume this style....the poblem is not of power or quality..but rather one of friction or lack of resistance because of the smooth floor surface....carpet surfaces permit the brush part of the roller to FLICK the dirt back up high enough ( only millimeters) to be sucked by the continuous suction flow of the vacume...however smooth finished hardwood or tile floors allow for the heavier none dust particules on your floors to be swept accross the floor with speed...if there was a back drop on the back end of your vacume cleaner these particules would be stoped and sucked up....try taping a strip of brstle board paper with scotch tape to the back part of ur vame head and see if it makes a differnce. Put the paper at dragging floor level and tape it..then sprinkle some dried toast on the bare floor and try it....let me know if it works...
Feb 20, 2010 | Bissell 6591 Power Trak Revolution Bagless...
Rotating Floor Brush Isin't spinning
It appears that the end of the brush is getting jammed with hairs, treads, and/or dust or the belt may be worn. Try taking the brush out and hold it by the ends and try to turn it. It should turn quite easily if it is working good. If not try taking the ends off and clean them out. Also, make sure the belt is good.
Mar 19, 2009 | Bissell Upright Vacuum - The Pet Hair...
I just purchased a DC07 Dyson vacuum cleaner. It is not vacumming my floor - I have hardly any suction at all. Do I need to activate something in order to initiate the suction?
With vac upright suction is sent to the hose ie top of vac handle when handle is tilted down to the user vacuum position it should send the power suction to the floor also make sure collection bin it in securely that make be the problem
Sep 08, 2008 | Vacuums
My vacum has no suction power it spray the shampoo but it won't **** it up. Thnis Vacuem is a Bissell 9400
make sure the selector for carpet or tools is set to floor. also make sure water tank is seated well. clean filter in tank.make sure tank seals are in tact. good luck
Mar 25, 2008 | Vacuums
Spin vacum won't suck up water
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter. Or the lid is not locked down all the way.
Dec 15, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
361 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
