Question about Dell Dimension 9150 (DIM915MIN) PC Desktop
Intermittently the power button constant orange fan full speed
7 days ago when i went turn the cumputer on after maybe giving a little blow where i saw house dust the fan came on at full speed and the computer failed to start and orange power button stayed on. Eventually i can get the computer to start with a green  light and the computer is working in its normal highly efficient way. When i hit restart on my computer i am left with a constant green light and the monitor light is yellow I have taken out memory cards and put them back in. I have contacted dell but they wanted to undertake a £25  BIOS test and Then maybe charge me £70 to repair the switch My computer is 4 years old and more may go wrong   Can just leave my machine on allthe time or have you any ideas of how i might remedy my problem thank you
dermot Ireland
  • galgorm Nov 26, 2008
    any more ideas?
    Problem Solver:
  • 11 Answers
Try removing the battery from the motherboard if its not soldered and leave it for an hour then out it back in, that might reset you bios and fix your problem.
Posted on Nov 25, 2008
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
1986 Mustang 5.0 wont stay running very long with loss of power
it sounds like a stun gun?? you are losing spark, get it in a dark place or at night and look under the hood for the lost spark, spray water on the cap and wires, youll find it
May 18, 2010 | 1986 Ford Mustang
Unit was used about 5 weeks ago running fine went to use the other day and no go the batterry is still full strength pump doesnt run nothing works i put a new pump in about 4 months ago
Blown fuse on circuit board. Take one side off, find the board. Fuse is water tight sealed. Remove the seal and replace fuse. This seems to be a rather common problem, but coleman doesn't give any help on it. There are only aprox 7 screws that hold the case together. One little one in under the decal on the front just blow the knob. THERE IS NO NEED TO TAKE THE KNOB OFF.
Oct 14, 2009 | Coleman Hot Water On Demand
Intermittent operation of interior fan - isuzu kb/trooper
fan speed resistor block blown if fan works only on full speed (because power goes directly to fan on full speed, not through resistor)
if fan doesnt work on full speed check for power at fan on full speed with test light if power there fan faulty
no power check switch bank assembly
Aug 06, 2009 | 1999 Isuzu Trooper
42 inch lg tv powers on,goes off after about 30 seconds
I have the same problem, I just spoke with LG Customer service. They had me unplug the power cord, hold down the power button for thirty seconds, plug back in and turn it on, this DID NOT work for me, but maybe it will work for you.
Good Luck! Mine is going to a service shop, maybe what they tell me I can post and it will help you if you have not gotten your tv fixed yet!
May 25, 2009 | LG 42LC2D 42 in. LCD HDTV
No signal to monitor, fans run full speed
maybe your cpu is faulty or ... maybe power suply ??
Mar 31, 2009 | E-Machines W3107 (RBW3107) PC Desktop
The heat/AC fan will not go on.
When you put the fan on full speed it normally bypasses the resistor. This sounds like a bad blower motor
Good Luck
Feb 09, 2009 | 2000 Pontiac Grand Am GT
E-Machine T6216 PSU fan runs, computer will not boot
Giving the fact that your fan is constantly running and you had an electrical spike you should take it in to be looked at. If it overheats then the motherboard will go and it will cost more to fix it than to buy a new one.
Don't forget to rate this solution before you log off.
Jan 26, 2009 | Computers & Internet
Canon BJC 8500 WASTE INK FULL
How to Reset Waste Ink Protection Counter Canon Pixma IP8500 Printer
Instructions:
Resetting Waste Ink Counter Canon Pixma IP6000, Canon MP450, Canon Pixma IP8500
1. Turn off the printer.
2. Whilst pressing Resume button also press on POWER.
3. Then Press RESUME button and release POWER.
4. Then Press RESUME button again .
5. Then release all buttons.
6. Led Indicator should be green and stay green.
7. Click RESUME button 4 times if you wish to try again.
Then See Table Below:
Orange - Service test print ONCE - Orange - Service test print.
Green - EEPROM information TWICE - Green - EEPROM information print.
Orange - EEPROM initialization 3 TIMES - Orange - EEPROM initialization.
Green - Waste ink counter resetting 4 TIMES - Green - Waste ink counter resetting
Orange - Destination setting (Press Power then Press Resume 3x) 5 times - Orange - Destination setting (Press Power Press Resume 3x)
Green - Print head deep cleaning 6 TIMES - Green - Print head deep cleaning.
Orange - Green, Orange - Return to menu selection 11-13 TIMES - Orange, Green, Orange - Return to menu selection.
Green - Left margin correction 14 TIMES - Green - Left margin correction.
8. Turn off printer.
9. Restart Printer.
Good Luck!
Tinteiros - Magic Inkjet Flush (Ebay)
Nov 07, 2007 | Canon BJC 8500 InkJet Printer
Dell Dimension 9150 (DIM915MIN) PC Desktop Logo
286 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
