Question about NetGear WGT624 Wireless Router
Wireles connection shows connected but cannot open any web page
  • 57 Answers
Check your internet settings
for Internet Explorer
1. open browser, click tools menu the select "Internet Options"
2. in Internet Options select "Connections" tab
3. at Connections, click "LAN Settings"
4. at LAN settings "Automatically detect settings" should be mark check
5. click OK to save settings, close Internet Explorer Browser and open it again.
for Firefox Browser
1 open browser click "Options" menu
2. at Options, select "Advance" then select "Network" the click "Settings"
3 Connection Settings, select "Direct Connection" if your computer directly connected to Internet provider otherwise select "Auto Detect Proxy Settings" if your using a Router.
4. click OK to save changes, close youi browser and open it again.
Hope this will help you.
Posted on Nov 27, 2008
No connectivity to any browsers. Have done a factory reset. Shows I'm connected but says it's unable to show the page
Open web browser click tools in toolbar then internet options next connections next lan settings check automatically connect uncheck the rest an save
for firefox tools options advanced network connection settings no proxy checked
Nov 15, 2015 | Tablets & eReaders
How to put password into my router
if you connect your pc to the router via ethernet cable and open your web browser. In the address bar type 192.168.1.1 and it should bring up your router's home page. you will have to type user and password which should be admin for both. Then just navigate to the password settings and enter your own and save it.
Nov 09, 2012 | Linksys WRT54GS Wireless Broadband Router...
Without an ethernet cable the laptop will not pick up any internet connections. After plugging one in, i get the internet connection but there is still a problem with the wireless. i thought it may be the...
Hello
Possible the wireless is not activated on the router.
Do this...Open internet explorer
Type 192.168.1.1 or 192.168.1.0 in the address bar of your internet,hit enter.
username =admin
password = password or admin
Once in the routers web page navigate to wireless settings and make sure it is enabled and secure.
If you choose to use a wep security key,write it down for future use.
Once done,exit router page and reboot pc.
Jan 11, 2011 | Computers & Internet
How can I fix this problem?? IE can not display web page. I only get this when I use my virgin wireles modem. When I use this modem in other computers it works, and my computer works with every other wiFi....
The settings on your PC might not configure correctly.
Try this,
Go to "Network Connections" and select the "LAN" connection, most probably your is the "wireless LAN" right-click and select properties and in the "general tab" select "Intenet Protocol(TCP/IP)" properties and check "Obtain an IP address automatically" and "
Obtain an IP DNS address automatically" and click "OK"
If you have selected a "Static IP" earlier your PC will not be able to link to the web access.
Jul 25, 2010 | Microsoft Internet Explorer 8
Hey. How can I connect to the linksys router in order to change the settings? There's some address I can put into my safari that will take me there, right?
default IP of router is 192.168.1.1
then it will open the page
the default user name and password is
admin
if you are unable to open this page through wireles, then try connecting the router to pc through lan wire.
dont forget to vote
Nov 19, 2009 | Linksys Wireless-G WRT54G Router
Cant connect laptop to router
The passphrase can be seen on the router's Admin page or its usually called router's Setup Page. You can open the router's setup page using your Internet Explorer. First you must your default gateway address. Connect your computer wired to the router or you can use a computer that is hardwired to the router to check the Default Gateway by going to Command Prompt then type IPCONFIG. If you see the Default Gateway, that's the address that you need to type on your Internet Explorer like http://192.168.1.1. If you have the router's setup page opened, you can see the passphrase on Wireless tab or Wireles Security Mode
Oct 22, 2009 | Computers & Internet
I have a Dell Inspiron 6000 w/ window xp. I show my wireless connection on the signal is excellent but when i click internet explorer its says its connect to internet - i dont have working offline clicked...
Try connecting to another wireless connection... if it connects to another connection and you get to the internet, then it is something with your wireless router or modem. Your PC can "see" a wireless connection, so it is NOT PC hardware.
It sounds like you can connect to the router, but cannot go through the router to get to the internet. Probably a simple issue with your modem or router. Try power cycling the modem, and power cycling the router. Then restart your PC and try connecting again.
If all that fails, try installing Mozilla Firefox and see if that will get out to the internet. It may be a problem with Internet Explorer.
Sep 09, 2009 | Dell Inspiron 6000 Notebook
Connection using DSL-2640T
Try diagnose and repaire the connection if that does not work Reset your modem it should go back to default manufacture setup.Then turn modem off and connect any computer or laptop to the modem with ethernet wire turn the modem on go back to your computer that you are connected to modem with wire go to network connections and disable the wireless Network connection and enable local area connection once you see you have connected and have internet working go to start menu you can do this on the start search bar with vista or run with any other windows version type cmd and press enter, it should bring a DOS command menu and then type in ipconfig and enter scroll up and down to where you see default gateway type that ip address to your internet browser it should take you to login screen username should be administrator password admin setup your WEB key make the wireless access available DO NOT FORGET to write the web key down, give a name to the connection and change the default password from admin to something you can remember. save the settings and turn that off keep the laptop on. Then unplug the ethernet cable and switch the network connectiion again enable wireless disable local area also you need to scan the available wireless internet and pick the one you just named use the webkey to access and save when the connection in made.
Feb 18, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Motoq internet does not open page
FREE INTERNET FOR YOUR MOTO Q
You need a blue tooth doggle 30 bucks at wallmart
install usb blue tooth doggle on ur pc or notebook
on your phone goto bluetooth folder. connect to personal network
open up active sync on phone and click menu then connect via bluetooth.
Try browsing the web. Your online and its shared from your home connection.
Feb 14, 2008 | Motorola Mobility Moto Q
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
394 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
