Question about Hobart A200 Stand Mixer
Hobart A200 noises
I'd really appreciate some input regarding an older A200 (#794389) that I have.  It is making a periodic noise that seems to coincide with the occasional clutch slip?  I assume it is the clutch slipping as the planetary motion speeds up momentarily before settling back down to normal speed.  All 3 speeds of the transmission function and the attachments are not hitting the bowl.  The machine has sat idle for quite some time so I was wondering if there is anything I can do (grease?) to refurbish it a little.  Here's a quick video of it kneading a small piece of dough.  I wasn't able to catch the 'slip' or change in speeds but these are the noises that I'm hearing.  With the exception of the noise and occasional speed hickup, it is kneading fine.
Many thanks!
    Novelist:
  • 125 Answers
Hi, here is my opinion: 1) your planetary, or attachment hub is making the noise as it goes around, and there is grease in the gear ring that keeps it lubricated, it may be as simple as removing the planetary grease ring ( the chrome ring), and taking loose the bolt and lowering off the hub and cleaning the old grease, and installing new, reassemble in reverse. You may also have bad bearings in the shaft portion of the planetary ( the shaft your attachments go onto) allowing the shaft to "wobble" a little bit causing a slight misalignment as the smaller gear goes around while mixing. How far you want to go is up to you.
For your other problem, I have seen the brass clutch bearings stick on the main shaft in the transmission, causing the planetary to momentarily speed up, or to maintain a wrong speed ( 2nd or 3rd) when set to first, but that would require full disassembly of the transmission. Best left to someone who has done it before, but if your inclined, go for it, but get a part breakdown first, or take pics as you go. Hope at least some of that helps, and thank you.
Posted on Jan 04, 2009
How much/what grease do I put in the planetary system of a Hobart A200?
contact the hobart manufacturer for recommended lubricants to use
Jan 05, 2017 | Hobart Food Mixers
Hobart A200 Noise
After viewing and listening to your video, my first guess would be bad bearing(s). The sound varies with the speed of the agitator, so the noise is at the speed of the transmission shaft or planetary area. These mixers use very common standard bearings. As such, they are available very reasonably from sources OTHER than Hobart. You will need to take the transmission apart in order to find and solve the problem. Study the parts manual in detail. It seems complicated, but once you understand it, it is logical. I highly recommend that you get a really good understanding of how it works and goes together before you start taking it apart though.
Nov 02, 2012 | Hobart A200 Stand Mixer
Was just givin a hobart a200 was in a school warehouse for at least 1o years attach.shaft and seals replaced by hobart 6 month before put in storage runs great smooth no gear noise BUT fromm sitting bowel...
Ogrin56,
The problem is in your lift handle cams, you need to take the pedistal apart and clean and grease all the cams. I take them apart and wire brush them and use white lithium grease to keep them from freezing up.
Feb 26, 2011 | Hobart A200 Stand Mixer
Hi i have hobart mixer 220v and it start to make loud noise when the dough get harder .thank you
What is the model and ml # on the data plate?I'm a hobart tech and repair these mixers often,let me know.
Nov 20, 2009 | Hobart A200 Stand Mixer
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
Hobart A200 transmission issues
does not sound good it need to be torn down and checked from here thats more then can be figured out sorry
Nov 26, 2008 | Hobart A200 Stand Mixer
Hobart A200 noise
Your mixer was built in 1942 and from the sound of it, it's been without grease for some time. Before you dismantle it, try adding new grease to it. This is the less expensive and less time consuming approach. The grease product to look for is Shell Darina XL EP-2, Try to find a local Shell Distributor and see if they'll sell you about 4 tubes of 400 grams each. This grease is compatible with most other greases, so you won't have to remove the old grease before you add the new stuff.
Remove the four screws that attach the Hub to the body of the mixer, pull off the hub. You now have access to the transmission area. work the new grease into the cavity, try to get as much grease as you can toward the back of the compartment. This will be a very messy job unless you have, or acquire a grease gun that the tubes will fit in. Lay the mixer on it's back and let gravity help you to get a lot of grease down through the hub opening. Keep adding grease until you've greased up to the hub opening. Grease the hub gear and then re-install the hub. Raise the mixer to vertical and start up the mixer, letting it run for a couple of minutes. Stop the mixer and shift gears,, once again start the mixer and repeat this procedure for the last gear. Listen for the sounds it was making before, they should be silent or at least muted. If it's still making loud noises, You may well have to take it apart for an overhaul. Dont overlook the planetary gearing, this gearing is not bathed in grease like the trans. Remove the planetery assembly, clean and inspect the planetary gear and the large ring gear in the mixer body. Regrease both and re-assemble. Your mixer is now as quiet as it will get short of a complete overhaul. If this solution works, it has only cost you a few bucks and a bit of time, making this. solution a good one, unless you still have the major noise issues.
I f you've found this solution helpfull, please rate it and Good Luck! ricardok45
Hobart A200 diagnosis
the first A-200's have a worm gear drive that will slip when old but also when mixing dough somtimes the dough will push the mixer aherad of its self and look like its slowing but its just catching up. if you have a old worm shaft it will have a spring on it is how to tell. it is replaced with a shaft that is all keyed and has no slip or give unless a key shears.
Michael
Nov 25, 2008 | Hobart A200 Stand Mixer
Whining noise in all three speeds.
There is only one bearing in the back a an A200, the rear motor bearing. Page 12 -- Otherwise I'd look for something rubbing the motor. (wire, capacitor shield) The two back side covers are easy to remove, two screws each.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
The timer is also in the link. The part is not cheap, but easy to install.
Jun 20, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
211 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
