Question about TMI Products Vizualogic Headrest Pair w/DVD Lincoln Navigator 05-Up Dove Gray Car Video Player
DVD Message: Bad Disc
My son dropped a coin into the DVD located in the headrest of my 2006 Toyota Sienna van. I took it to the dealership and they retrieved the coin, said it was working but when I tried it after leaving, I rec'd the above message. Took the vehicle back in; they said they couldn't fix it and they couldn't get me a new one because they don't make that model anymore. Now what?
    Top Expert:
  • TMI Products Master
  • 12,962 Answers
If not available any more, you are scr---d.
You can check with this outfit to see if they have anything that will fit in your situation. Crutchfield Car Stereo Speakers Home Theater Pro Audio 4k TV
Posted on Sep 09, 2017
2 Suggested Answers
SOURCE: dvd player won't read disc
I believe Vizualogic has serious quality problems. I had RT20 installed and it was defective to start with. The headphones did not work on one unit and the other unit made a loud sound when it was turned on. I had the units replaced. The new units had a new problem - Disc Error. The players were not able to read the discs. The installer tried another unit and it also had the same disc error problem. Interestingly, the word disc was spelled as DSIC - can you believe the quality control on Vizualogic prodict?
The installer then found that a wire had come loose in one of the units. He applied some tape to hold the wire in place. The unit seemed to transmit sound again. Well, a broken connection, disc error in multiple units and incorrect spelling was enough to turn me off. I am now trying to get some other brand installed.
Posted on Dec 15, 2009
The check engine light came on in my van. Took it to the toyota dealership. They said the computer needs to be replaced. What does that entail? Price seemed very high.
they can be liying to you just to get your money take it to a mechanic or autozone and ask them if they can check it
Feb 18, 2013 | 2000 Toyota Sienna
I own 2006 toyota sienna van, one cigarate charger doen't work which fuse shoud i need to check
Check the fuse marked "power outlet" on the fuse panel inside lower left of the dash, there may be more than one marked like this.
Feb 16, 2012 | 2006 Toyota Sienna
My son put coins in the cd player of my 2006 toyota sienna and i want to scream! how do i fix it ?
This problem has a fifty fifty chance of working. considering coins are conductive and when inside of a radio they can do some major damage to the board that controls the radio.
No mater what you radio has to be removed from your sienna. To remove the radio disconnect the negative battery terminal on you battery. The panal sorounding to radio pops away from the dash ( I suggest using a plastic panel pop that can be a bought from any hardware store).
Jul 14, 2011 | Car Audio & Video
A red flashing car shape light flashing on my 06 toyota sienna van?
Is the immobilizer, if there is no key in the ignition is ok if flashes, if it flashes when the key is in the ignition the key is bad car wont start.
Dec 31, 2010 | 2006 Toyota Sienna
Water on the front floor of a toyota sienna minivan 2006, I suspect iti is the AC drain but I can not find it in the car.
If it is the clogged drain line it is located under the van. Look around and you will find it. It may also be a leaking heater core, especially if you have been loosing coolant with no apparent leak. Taste of the liquid and if it tastes sweet it is coolant and not just water.
May 25, 2010 | 2006 Toyota Sienna
2006 Toyota Sienna with an ADVENT DVD
Well, if its crammed in there from kids shoving stuff in there as kids will tend to do sometimes, then i am sorry to say, you most likely will need to get a new player. Cause general when something is jammed into disc slot, other components that are vital to operation have been compromised. But on the other hand. If it was working and operating fine one minute, and the next it simply just wouldn't eject. Your problem is one of the 2. Is the player making any noise as if it is trying to eject the disc but will not, and can you still at least play the disc and watch it since its already in there? If so. It sounds like you have a bad gear or a little spring that has popped that engages the gear to make the mechanism for disc ejection impossible. Or the main drive belt has dried and broke. Take it to a local tech. 2nd. If its not making any noise when eject button is pressed. The button itself might be bad. Try the remote controls eject button. If it has one, that might eject the disc. Hope this helps. And in tghe future, no paper clip tricks okay. Only damage can occure with that method. good luck,
Apr 26, 2010 | Televison & Video
How do you access the rear tail light bulbs to replace in a 2006 sienna van?
2006 Sienna taillight.
Open tailgate. Loosen bolts holding tailight assembly. Standing next to the car, pull light assembly toward the side and back of the car. It will feel like you're going to break the light assembly, but you won't. I attempted this last fall (2008), but feelin' a bit uncomfortable pulling on it in different directions, I reassembled it and had the guys at the dealership do it right there in the dealership parking lot. If it was to break, I wanted them to break it! But it didn't break and I saw how to do it next time.
Jul 14, 2009 | 2008 Toyota Sienna
Airbag says off
Usualy there is a key hole located near where the passenger air bag off light is. All you do is find the key hole, insert your ignition key and turn to reactivate the air bag. If this doesn't help, i would make a quick phone call to your nearest toyota dealership, and ask for service.
Dec 16, 2008 | 2006 Toyota Sienna
TMI Products Vizualogic Headrest Pair w/DVD Lincoln Navigator 05-Up Dove Gray Car Video Player Logo
128 people viewed this question
Top TMI Products Car Audio & Video Experts
greg benton
Tommie Jones
Level 1 Expert
Are you a TMI Products Car Audio and Video Expert? Answer questions, earn points and help others
