SOURCE: 2000 jeep cherokee interior lights wont turn off
on the head light switch you can rotate it either left or right and you will hear a click ...... I took the jeep to a mechanic ... and we took all the door switches out then to auto electrician over 50 euro later i found the fault my self
SOURCE: 06 jeep commander wont crank. No interior lights,
Check your battery cables. Remove them and clean the contacts, if the ends are replacements take them apart and clean. Use a wire brush or sand paper. Make sure you remove the negative first and reinstall it last. Also check the battery and fuse links. Your problem is in there some where the battery, cable ends, cables, or a fuse link. If still no start let me know the results and we can go from there if need be.
Testimonial: "Ron, thanks for the help. I had already done what you had listed. I cannot figure out how it could work and then not work 20 seconds later "
