Question about Intel Motherboard
Problems installing win vista home premium
While installing on a new system, foxconn motherboard, sata/300 drive,keep getting different error messages,can't figure whats wrong, the win vista disk is for builders
  • delval15 Nov 28, 2008
    this was helpful thankyou
  • mattdowns May 11, 2010
    what are your error messages?
  • 781 Answers
Try slipstreaming SATA drivers into your O/S
You need "Driverpacks" one word search and "Nlite" to do it
Posted on Nov 26, 2008
I have a HP DV 1659 laptop, and am looking to buy Seagate Momentus 7200.4 ST9500420AS Mobile Hard Drive - 500GB, 2.5", 7200RPM, SATA-300. I am not sure what version of SATA the current drive is. Also...
It will take ANY 2.5 SATA drive.
There are different versions of SATA but they're all backwards compatible so the new ones will work on your system no problem the only difference is you won't get the full speed from the drive since the motherboard supports only the earlier versions of SATA.
As far as partitions and size limits go you'll be fine so long as you format the drive as NTFS during install. FAT32 is the one with limits etc.
Before installing a new drive though I'd recommend verifying you've got the latest BIOS version on your system.
Hope this info helps and if you've got anymore questions, fire away ;)
Oct 28, 2010 | HP Pavilion dv1000 Notebook
Need raid pata driver for foxconn rc4107ma motherboard
Normally RAID setup on board, is handled in the BIOS settings.
Feb 21, 2010 | Computers & Internet
I am trying to install a gdr-8164b drive in my inspiron 531 but the connectors are different. How would i go about this, is there an adapter that is available?
your drive is an LG gdr-8164b and is a IDE your computer is using for SATA drive which is different you need to change your drive to a SATA or get a PCI with a IDE
Sep 10, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
I have Dell inspiron 1525 laptop with windows Vista home premium
go to bios setup n change sata driver to ATA from AHCI n  also disable da flash play module
Mar 18, 2009 | Microsoft Windows XP Professional for PC
Ms-7061 msi motherboard will not install win xp with sata drive
The problem is that your version of XP does not have SATA drivers and therefore does not recognise your new drive. Vista does. If you Google the problem you will find many solutions on how to rectify the situation. Basically, you have to make a floppy disc with the correct drivers for your Motherboard's hard drive controller. Then, when you launch your Windows XP installer, it will ask you a question about needing to install 3rd party drivers. Yes is your answer. Tap F6 to ensure that the installer doesn't skip.Insert the floppy disc and then after the drivers are loaded, the installation will proceded normally. The other alternative is to leave your existing XP installation in place and add the new disc. Later you can clone your old disc onto the new drive and then remove your original disc.
Feb 11, 2009 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
Why not win xp load in compaq presario cq40
The notebook is preinstalled with a SATA hard drive which needs seperate drivers to be installed inorder to get the hard drive detected. The drivers for the SATA can be installed only by using a floppy drive. As the notebook does not have a floppy drive installed, we can either try disabling the SATA native support in BIOS or install the drivers with the help of a USB floppy drive.
Here is the link for SATA driver:
http://downloadmirror.intel.com/16759/eng/f6flpy32_85.zip
Check the following document to install SATA dirver without using the floppy drive:
http://www.scribd.com/doc/4864999/sata
Jan 22, 2009 | Microsoft Windows Vista Home Premium with...
XP to vista and install sata drive
Yes vista will format & install on the new drive. Just make sure if there is an o/s on the old drive that you set up windows vista as a dual boot if you wish to keep using the o/s on the old drive. Hope this helps.
Dec 25, 2008 | MSI K8N Neo-FSR Motherboard
Installing win vista
You have a corrupt NTFS file system
Download "Hirens Boot CD" burn to disk and boot from it use the programs on it to check and repair MBR etc.
Then try one of the partitions programs to partition and format it
Nov 18, 2008 | Intel Motherboard
How to install XP on pre loaded Vista in HP Laptop
I bought a cheap Compaq laptop that came with Vista Home Premium. The speed was horrendous! Anyway, I received the same no hard drive found error. To solve the problem, I went into the system config (BIOS) by pressing F10 on startup, and turned off SATA hard drive support (its supposed to make the hard drive run faster), I rebooted, inserted my Win XP Pro disc and viola, it detected the hard drive. I would say that the laptop runs a good 40% faster than before. Vista is a big no no when it comes to low end laptops built for word processing and internet browsing.
Aug 19, 2007 | Microsoft Windows XP Professional With...
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
