Question about Kenmore 80803 Microwave Oven
Turntable goes off track
Iv'e checked the wheels and they appear in good shape. The microwave is only ayear old. It's complete model # is 721.80803400.
  • Ramon Rodriguez Jan 16, 2007
    I found the problem!!! Someone spilled food and did not clean the entire microwave, leaving some dried food on the track area that the wheels goes over. This made the whole tray go off track and cause things to spill. Thanks for the suggestions anyway.
  • Kenmore Master
  • 9,156 Answers
It may be bent at the points where the "legs" meet the center hub. It may be very subtle. It would be useful to see how well it rests in place on the coupler with the tray off and with it on. Seems like it should be a mechanical alignment or wear issue.
Posted on Jan 04, 2007
SOURCE:
Microwave makes noise when on
All microwaves make some noise when running. Cooling fans, exhaust fans, turntable motor, transformer, and magnetron all make noise. I assume you mean some unusual noise. I need to know more about what kind of noise it is - a loud roar, a rattling sound, a high-pitch squealing sound, a "clunk-clunk" sound or what? By the way, a "klunk-klunk" sound is frequently caused by small debris stuck to the wheels of the turntable support tray. Try cleaning those wheels and the track they roll in.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 21, 2014 | Whirlpool Accuwave Microwave Oven
I have a Sharp 930 Convection Microwave that is no longer rotating. Any help?
This problerm is commonly attributed to a turntable motor that is no longer working. If the model number you posted this question under is correct, the part number for a replacement turntable motor is 46-841666-3. You may also consider replacing the turntable coupler (also called the turntable shaft). The part number is NCPL-A021WRFO. If your existing coupler is still in good shape, there is no need to replace it.
Replacement parts can be purchased on line at searspartsdirect.com. There is a complete list of helpful exploded view parts illustrations to assist you with parts identification/location.
If you need instructions on how to replace a turntable motor, the following link explains:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
If you have any questions, please post back and let me know. I hope this helps you.
Jan 29, 2010 | Sharp R-930AK Convection/Microwave Oven
Turntable has stopped revolving... will start to spin as soon as START button hit - goes about half an inch and then completely stops.
One suggestion i would make is that in the microwave there is the turntable, lift the plate off ,then below it you will see a circular object with wheels on.I think you may have this the wrong way up, so turn it over put the plate back on top and should work.
its the circular piece on runners that is the problem
Oct 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
TURNTABLE AND LIGHT NOT WORKING
It will cook entirely different ... you will want to turn the food occasionally to assure complete cooking.
You probably have a burned out lamp ... look inside for an access panel. If none, you will have to remove the cover. There are probably 8 to 10 screws and they may be Torx - Torx is a star shape, available at auto parts store of Sears (K-mart).
Once inside - DO NOT TOUCH THE SILVER CAN - LETHAL.
Find the lamp, check it out. If burned, get a replacement at your hardware or appliance store or maybe at a Big Box store.
a
Sep 26, 2009 | Magic Chef MCD990W Microwave Oven
Turntable wheel under glass tray broken
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
Mar 20, 2009 | Panasonic Microwave Ovens
Microwave turntable won't turn
You may have a tunrtable motor or spindle problem..
This info is from GE website..( link : http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance or cleaning.
  • Make sure the turntable is centered and seated properly. On models with a stirrer motor there is a shaft protruding up through the floor of the microwave. Make sure the turntable is securely fastened to this shaft. On models that turn on a ring with wheels attached, make sure the turntable is seated securely on the ring.
  • Check the turntable to make sure it is placed right side up. If the turntable plate is upside down it will drag on the floor of the microwave.
  • Check to make sure that there is no food or debris under the "wheels" of the turntable ring. Food can prevent the wheels from moving forward.
  • Be certain you are pressing a cook function rather than a timer function.
  • If the microwave has a turntable on/off feature make sure the turntable was not inadvertently turned off. Try depressing the turntable on/off pad to re-engage the turntable.
Sep 21, 2008 | GE JVM1850 1000 Watts Microwave Oven
The turn table goes clockwise sometimes & counter clockwise sometimes.It also makes a groumbling noise.
The motor for the turntable in these ovens is bi-directional. This is normal.
As for the noise, it is very common that the main turntable wheel track-ring under it is dirty at its wheels, or its pin-pushings have some wear. It is also posssible that the main turntable motor has become noisy from use and age.
I have had microwave ovens make a grumbly sound when one of the cooling fans are going defective.
Jerry G.
May 14, 2008 | GE Microwave Ovens
Noisey turntable
try pulling on the plastic drive and inspect it you just pull up on it to remove it
Jan 30, 2008 | GE JVM1440 Microwave Oven
Kenmore elite 721.80833 microwave
I purchased a later model glass tray which was redesigned and now it works fine.Just take your tray to the store and compare it to a newer one and you will see the difference.
Oct 20, 2007 | Kenmore 80803 Microwave Oven
Kenmore 80803 Microwave Oven Logo
91 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
