Question about Dell E773C 17" CRT Monitor
Dell monitor E773C 17"
Hello. l have a problem with this monitor the horizontal size and pincushion ajustments don't work all others works fine. if you can help me, tanks. in advance PEDRO.
  • 1 more comment
  • babyfame May 23, 2008
    I have the very same problem with the very same model. I don't think it is residue because in my case you see the levels changing as you adjust, it's just that it doesn't affect the screen display at all.
  • Anonymous Nov 04, 2008
    every time i turn on my coputer the contrast keep popping up on the screen when i exit it comes back up
  • Anonymous Nov 11, 2008
    Pincushion and h-size won't change, h-position seems to work. I've checked all the diodes nearby the HOT and found nothing wrong, checked the high voltage capacitor, and it was ok and checked the pack of mosfets, they were ok... but keeps on failing.
  • 3 Answers
Changed the TIP122 and worked. It was not short-circuited but most likely to have a severe leakage.
Posted on Nov 13, 2008
  • 9,149 Answers
It sounds like this needs component-level troubleshooting, probably in the signal section. It might also be loose connections or residue of some kind in one of the switches or on the switch board.
Posted on Jan 04, 2007
The image is getting smaller
If in the horizontal direction your line output stage requires attention, new line output transistor/ capacitors etc. If in both dimensions probably a power supply fault.
Mar 07, 2011 | Dell E773C 17" CRT Monitor
When you push the power button on the monitor the green light comes on for a few seconds then goes to yellow. Any ideas? It is a Dell e773c connected to a HP Pavillon 700
Please check the vga connection cable. It may not connected to the computer. If you have dual monitor support (2 monitor connection on the PC) try other vga port.
Aug 19, 2010 | Dell E773C 17" CRT Monitor
How do you adjust the vertical and horizontal of the image on your screen?
Press the OSD (On Screen Display) button on the face of the monitor. You'll find controls to control the size & position both horizontally & vertically.
Jun 01, 2010 | Dell E773C 17" CRT Monitor
My Dell E773c Monitor's image is like a "hyperbola" wider at the top and bottom and narrower in the middle. The Horizontal adjustments do not do anything to correct the problem, Help!!!!
Try to do a factory reset (look up "recall" in the manual, or here: http://support.dell.com/support/edocs/monitors/e773c/EN/ug/setup.htm).
If this does not help, you need to adjust the geometry settings (H/V position, H/V size, rotation, trapezoid, parallelogram, pincushion and pin balance) using the monitor's settings menu. Expect a long afternoon of fiddling around until you get a satisfactory result. A test picture for geometry settings could be of help.
Make sure your computers video setting does not exceed the monitors specification of 1152 x 864 @ 75 Hz.
Feb 04, 2010 | Dell E773C 17" CRT Monitor
Problem with Screen in Horizontally Reduced
Set the screen resolution on the computer to some place like 1024x768. Use the menu buttons to resize the screen screen.
If the monitor is not keeping the settings it can be an indication to get a new monitor.
Aug 18, 2009 | Dell E773C 17" CRT Monitor
Pincushion and Horital Size Problems
This is a hardware based issue, and sadly cannot be fixed without sending it to a service center. If you really want to, you can send this monitor to a service center, but it will be around 100 bucks to fix. I would say just replace it with a smaller LCD panel. They can be bought for around the same price, and they'll save power too.
Feb 05, 2009 | Samsung SyncMaster 753 DFX 17" CRT Monitor
Burn resistor
if its a 4 band resistor, use the following calculator...
http://www.dannyg.com/examples/res2/resistor.htm
if the resistor is a 5 band, use the following link....
http://www.sizes.com/materls/resistorcolor.htm
hope this helps!
Jun 16, 2008 | Dell E773C 17" CRT Monitor
Dell Monitor E773C
on dell monitors they have buttons on the front (at least the old ones do).   If you can't see things on your screen like task bar on the bottom, or anything on the top and sides --- try adjusting this buttons.  They control vertical size, horizontal size, etc. -- also position on the screeen    If you accidently hit them (I did) it throws everything off.
good luck
May 23, 2008 | Dell E773C 17" CRT Monitor
Monitor settings can't be adjusted
You may need to check the resolution for your graphics card. Check the display settings in the control panel.
Jan 27, 2007 | Dell E773C 17" CRT Monitor
Dell E773C 17" CRT Monitor Logo
224 people viewed this question
Clive
Clive
Alun Cox
