Question about Nokia E71 Smartphone
All rings is up and down,up and down,
Setting on the phone is good (general ring)
i have nokia e71
  • Z?ps Paiva Jan 16, 2009
    when the phone is ringing the sound volume goes up and down...up and down...
I had the same problem. After hours searching the web i found out that this is not a problem. The 3D ringtones was active. Go to Home -> Media -> 3d Ringtones and desactivate
Posted on Jan 16, 2009
No ringing tone on nokia e71
Contact mobile repairing shop .They will change the Ringer (Speaker) if it is found damages or if not they check it out all the sound related components.good luck
Feb 02, 2012 | Nokia E71 Smartphone
Why my nokia C3 doesnt ring accordingly although i set the ring tone already?its only vibrate.i'm not using silent mode.
I can imagine it how annoying it would be to you to see your cell vibrating instead of playing your favorite ring tone. Most probably it could be because of incorrect Profile configuration. It is possible to make your phone vibrate in almost every profile so we will assume that it is the reason for your problem too. Do the following and check some parameters as described.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
Jun 04, 2011 | Nokia C3 Cell Phone
I am having nokia e71 i am not able to see the pics taken by me and also i am not able to access the inbuilt ring tones, sms tones, etc.
You will need to check into the main menu- gallery and open the link. You will find the images on the memory card and also the images on the phone memory. Open the files and click to search .
Also in the settings sub menu you can scroll down to see the Tones under which the SMS tones can also be set.
Mar 28, 2011 | Nokia E71 Smartphone
How to get to ring and vibrate
Please go to Menu->Settings->General->Personalisation->Tones. Here you will find various options and ring tones and type and vibrating are some of them. Please do as you please here.
Feb 07, 2011 | Nokia E71 Smartphone
Where is the ringtone volume adjustment for the Nokia N73? Thanks
Hello !
Look in Profiles -General - Options - Personalise - Ringing volume.
You will have to set the volume and Ringing tone for every profile ( General,Meeting,Outdoor.... ).
You can find Profiles in Menu - Tools - Profiles.
Good luck !
Nov 18, 2010 | Nokia N73 Cellular Phone
Cannot get phone to ring only vibrate
To change the Nokia 6133 to ring, do the following-
Select Menu > Settings > Profiles > Select any one profile that is available in your mobile. (Ex. General)
1. Menu > Settings > Profiles > General > Personalise > Incoming call Alert > Ringing
2. Menu > Settings > Profiles > General > Personalise > Vibratibng Alert > Off
After this activate the profile(Ex. General)
Menu > Settings > Profiles > General > Activate
After this the phone will only ring and wont vibrate.
If you want both then change the vibrating alert to On.
Good Luck.
Jun 04, 2010 | Nokia 6133 Cellular Phone
How do i mute ringing on my e71?
To mute the ringing tone instead of answering a active call,select Silence.
or u can try the following
To set a mute ringing tone for a profile, select Options >
Personalise > Ringing tone. Select a ringing tone
from the list, or select Download sounds to open a
bookmark folder containing a list of bookmarks for
downloading tones using the browser. Any
downloaded tones are saved to Gallery.
To play the ringing tone for a selected contact group
only, select Options > Personalise > Alert for, and
select the option similar to none,etc...
May 24, 2010 | Nokia E71 Smartphone
My nokia n70 only shows name without ring .pls help.
dear anasalsayesa..
does it happen when you recieved calls? If it is..maybe your phone is in silent mode. Try this..on your N70 phone. press the sharp key ( # ) till the general profile is selected. you can hear a tone for that.
OR
Your phone's ringing volume is set to zero( 0 ). try this. go to tools folder. then profiles, select general and click personalise. scroll down to ringing volume and you can set it to its maximum volume.
hope this will help you..
Dec 24, 2008 | Nokia N70 Cellular Phone
Ring problem with nokia 6131
HI SIR.  please cheak whether the profile in the general mode.. and keep it in the ring mode.. if also it does't work mean's. u need to restore the factory setting's..   step for setting's..   1. menu>tool>setings>phone>general>restore factor settings>it ask's for thr passward. general passward is 12345 or ur security code..what have u given.. it will restart .. and u will seen it will be ringing . if any doubt assist me.. i am there .. thank u..   please rate it.
Sep 09, 2008 | Nokia 6131 Cellular Phone
Nokia E71 Smartphone Logo
121 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
