Question about Viking 31 in. VGSU101 Gas Cooktop
Viking professional 30 inch, sparking problem
The oven ignition keeps sparking when the oven is lit or not lit.
I've a viking professional 30 inch, clean it up perfect, checked all connections. I have to cut the breakers at th emain panel to shut down the sparking and the other kitchen outlets at the same time. No matter what burner I use, ALL 4 burners spark when the breaker is ON. can you save me?Nicolas
    Welcome Back:
    Visited the website for 2 consecutive days.
If you have replaced the spark module with the new, blue PA020041 Tytronics 0+4 spark module, the physical positions of the leads that go to the burner igniters are reversed compared to the positions on the old, white module. Make sure that the switch wire for the burner and the position of the spark wire both go to the same burner! The positions are marked on the white label with green lettering.
Posted on Sep 02, 2012
    Sergeant:
    Champion:
  • 338 Answers
You need a new wire harness that has the ignitor switches on it. I believe viking calls it the ignition switch.
Posted on Nov 26, 2008
My Viking vgsu cooktop has the igniter go on continuously when I try to turn on 4 of the 6 burners
My Viking stove igniter won't stop clicking. Both igniters on one side are clicking over and over
May 21, 2010 | Cooktops
How do you replace the ignition module on stove.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 14, 2010 | Viking Professional VGRT362-4G 36 in. Gas...
I hav a Viking professional. Only one burner ignites.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Mar 18, 2010 | Viking 42 in. Professional Series...
Same one - ignition click will not stop. Is there a solution?
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
wwttw
Sep 25, 2009 | GE 30 in. Profile JGP933 Gas Cooktop
Viking 30" gas professional series cooktop sparking problem
And before that Most likely one of the ignition switches (they are under knobs) got shorted possibly due to spilled liquid or a cleaning stuff sprayed on. In that case it should stop sparking after a switch drys. Still no go replace the spark control unit.
Thanks
Kindly rate the answer
Kevin
Jul 06, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Mar 09, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Viking Gas Cooktop - Ignition sparks continuously when in 'on' position
This is likely caused by either a dirty ignition electrode, a cracked ignition electrode, or a bad spark re-ignition module.
Clean and inspect the six electrodes for cracks, If that doesn't solve it order a new
Ignition module from an internet appliance dealer that carries Viking parts like Appliance Zone.
If you replace the Ignition module yourself, make sure to turn off the circuit breaker to the range/cooktop before you work on it. Also, make a drawing of where the different color leads are plugged into the ignition module before you unplug the wires and plug them into the new re-ignitor. If the unit is under one year, this should be covered under the warranty.
Viking had a recall a few years back on their ignitor modules.
Jun 03, 2008 | Cooktops
Rv cooktop range 22 series
hi,
it sounds like the oven safety valve is bad, it will reach a point when the pilot will make enough energy to keep itself lit, but not enough to open the gas valve to light. it will need to be replaced. if you are handy you can do this, but make sure you shut off the gas to the range first. you should be able to find a replacement online, if not check with a local LP gas company that sells parts to the public.
Feb 25, 2008 | Cooktops
Ignite problem
imfornu, under each burner control is a valve and a switch that controls the spark to each burner. Sometimes these switches become wet or short out. In this case it sounds like yours is shorted in the closed position and therefore the spark. These switches run on a harness across each burner control valve..I believe the part number is PG220020, you can look it up on the net to get an idea of what it looks like...Catriver..post back.
Sep 05, 2006 | Viking 31 in. VGSU101 Gas Cooktop
Viking 31 in. VGSU101 Gas Cooktop Logo
890 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
