Question about LG Flatron L1710B 17" LCD Monitor
Dark/light horizontal bands...
That spread across the screen when a window is open. any suggestions? Thanks in advance!
  • 2 more comments
  • renee tung Jan 04, 2007
    The video cable looks good and I will try to find another monitor to test my pc. Good advice! Thank you!
  • koadog71 Nov 12, 2007
    this sounds like my problem...did you fix it? What was the issue?
  • thien Nov 30, 2007
    Sir. Monitor always appear a small size of windown with the text " DAY TEST, NIGHT TEST...like that. cuold you help me about that. thanks
  • akash25j Jul 05, 2008
    screen displaying a thin white very bright horizontal line.... plz help
    Scholar:
  • 130 Answers
ITS THE CAPACITORS!!!!!! READ THIS POST IM PUTTING IT UP ON ALL THE OTHER LT916S FORUMS I JUST FIX MINE THAT HAD THE EXACT SAME PROB!!!!!!OK PEOPLE I GOT THE SOLUTION TO THE MAG INNOVISION LT916S GOING BLACK AFTER ANY LENGTH OF TIME BEING ON!!! I JUST REPAIRED MINE TODAY! THE PROBLEM IS THE CAPACITOR BANK IN THE POWER SUPPLY PART THERE ARE 6 CAPACITORS I HAD A FEW LEAKY ONES "NOT GOOD" THE CAPACITOR SPECS ARE AS FOLLOWS 470UF 25V 105 DEGREES C MEANING 470 MICRO FARAD/25 VOLTS I HAD A VERY HARD TIME FINDING THE 25 VOLT ONES SO I WENT WITH 470UF/35V 85 DEGREES C THEY MIGHT NOT LAST AS LONG AS THE OTHERS DUE TO THE TEMP RATING HOWEVER, IM THINKING SINCE THEY CAN HANDLE UP TO 35 VOLTS IT SHOULD EVEN OUT AND HEY, ITS WORKING SO FAR SO GOOD!! THE CAPACITORS ARE FROM UNDER A DOLLAR A PIECE TO A COUPLE BUCKS EACH. THE CAPACITORS HAVE A BOLD LINE RUNNING UP ON ONE SIDE INDICATING THE POLARITY. BOLD LINE SIDE IS "-" SIDE WITHOUT BOLD LINE ITS "+" THE POWER SUPPLY BOARD HAS THE POLARITYS STAMPED ON THE BOARD ITSELF UNDER EACH CAPACITOR. EASY 30 MINUTE FIX IF YOU ARE LEARY ABOUT SOILDERING, FIND A FRIEND THAT KNOWS HOW TO. ITS REALLY NOT THAT HARD THOUGH AND YOULL HAVE SOME DECENT ROOM TO WORK WITH. I PROMISE WHEN YOU OPEN IT UP YOU WILL ALMOST CERTAINLY SEE AT LEAST 4 OF THE 6 CAPACITORS BULDGING AT THE TOPS MAYBE EVEN LEAKING BROWNISH STUFF. DO YOURSELF A FAVOR THOUGH AND REPLACE ALL OF THEM WHILE YOUR IN THERE "THE SIX BIGGER ONES ONLY" IF ANY OF YOU NEED FURTHER HELP OR ANY OTHER QUESTIONS ABOUT THIS PROJECT PLEASE FEEL FREE TO EMAIL ME AT BTLEE26@HOTMAIL I DAMN NEAR WENT CRAZY TRYING TO FIND A SOLUTION ON HOW TO FIX THIS THING SINCE I SPENT OVER 300 BUCKS FOR IT NEW. AND IM BY NO MEANS A EXPERT WHEN IT COMES TO THIS STUFF BUT I DO KNOW A FEW THINGS. AS IM SURE MOST OF YOU DO. TAKE CARE YOU ALL AND THANKS TO THE GY WHO MENTIONED SOMETHING ABOUT CAPACITORS BEING BAD IN HIS! when it eventually dies just replace the capacitors! mine was doing the same thing then it finally died. and also please send or call mag and complain this is a ridiculous problem due to crappy business practices.
Posted on Sep 04, 2007
Try checking the neck board for cold soldered joints. resolder as needed. probably a bad capacitor thou.
Posted on Jan 15, 2007
I've examined this same problem, and found it's due to worn out electrolyte condensers (the little metal cylinder you can see on the main board). Maybe few of them are at fault, but since the problem is connencted to aging of components, it's convenient to replace them all. Servicing is not simple, because you need identical replacement parts, suitable tools and a certain skill. Best luck.
Posted on Jan 07, 2007
  • 4 Answers
With a good freind and his good computer swap parts. His monitor on your system, yours on his. After swapping monitors if the problem goes away on yours and appears on his it's in your computer. If your monitor still has errors on the other computer it is your monitor. If the problem goes away on your monitor and appears on his monitor (on your computer) it's your video card or your Mother Board or maybe software. This problem seems most likely to be a hardware problem but I have been wrong before. Reinstalling the OS, Video Drivers, and any Monitor Drivers may also work. If you have built in video support on your motherboard and that's what your useing turn it off and install a new (friends) video card eather PCI or VGA which ever one your computer supports best. You can do the oppsite if you have a video card in your machine and your computer has a built in video support disabled. Remove remove the card and enable the boards video support. If the problem goes away get a new plug in card. If the problem stays minus any plug in cards or with a known good card plugged in it most liklely is mother board related. Hope This Helps
Posted on Jan 04, 2007
  • LG Master
  • 9,098 Answers
I would first suggest that you verify the video cable and connector are okay. The connector should look like the one in the photo with no missing or bent pins. if you can plug in another monitor, that would help rule out the PC. After that, it would probably need component-level troubleshooting, probably in the video or signal circuits.
I have dark horizontal band across the top of my Vizio M4470NV how can I check the back light led's
You will need to remove the panel screen to get into the lamps, be very careful when you remove the screen and re assemble it
Apr 03, 2018 | Vizio Televison & Video
Have a dark band horizontally across vizio tv. Appears to be a backlight, but not sure how to fix
Could be a bad CCFL lamp, if the set usess CCFL back-light system. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 08, 2017 | Vizio Televison & Video
SONY LED TV Vertical & Horizontal Lines on the Screen
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 30, 2016 | Sony Televison & Video
Dark band lcd tv
Back-light fault. Contact any service technician. The panel might be taken out for repair. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 23, 2014 | Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Samsung ln52a650a1fxza LCD has horizontal band of dark lines across screen
check connections on top of screen this is becoming a stockfault on samsung tvs
Dec 01, 2012 | Televison & Video
Dark horizontal band at top of Sony KDF - 46E 2000 TV
rca ps2720lv blue is very dim any suggestions
Nov 14, 2009 | Sony Televison & Video
I have a Dell 17" LCD monitor with a horizontal band.
You would better served replacing monitor you can buy one for about $100-$120 dell if you lie has one for $99
Mar 01, 2018 | Dell Computers & Internet
Rear projection TV (LG 44SZ51): Horizontal dark band on upper screen field
The LG 44SZ21RB Have a problem with their light tunnel collasping due to the heat from the lamp. They are available as a spare part @ LG and would also require some silicon adhesive to bond it into the assembly. Very tedious job for any technican (2-3 hrs). Lg will not release parts to the general public only to an authorised LG agent.
Mar 30, 2008 | LG RU-44SZ51D 44" Rear Projection...
Pictur
I have had a similar problem. Pictureres look like they are taken through a Venetial blind with white horizontal bands though I did get one with dark banding. It appears to have something to do with light levels. I took a few pics in a dark area with no flash and now it is working again...until it quits working again. Perhaps it is something to do with light level calibration? Whatever it is the problem is internal. If you are still under warranty, I highly recommend taking your camera in for repairs/replacement. Ours started acting up just after the warranty expired so no love for us.
Aug 07, 2007 | Kodak EasyShare C533 Digital Camera
LG Flatron L1710B 17" LCD Monitor Logo
1,179 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
