Question about Olympus FE-230 Digital Camera
Battery won't hold a charge
My camera battery doesn't hold a charge. Take 3 or 4 pictures and the battery shows it's empty. Would buying a new rechargeable battery solve the problem.
  • river_run21 Dec 03, 2008
    I have the same problem. I did buy a new battery and still have the problem so I suspect it is not in the battery
  • Anonymous Dec 06, 2008
    my canon s500 do the same thing...
    Problem Solver:
  • 14 Answers
Buying recharable batteries will not solve the problem of the battery draining quickly but will help save $ by not having to purchase so many disposable batteries. Check your user guide to see what kind of batteries your camera will accept. Lithium ion rechargeable is the best if compatible. Lithium ion disposible (CRV3) will last a long time as a secondary choice if compatible. Some cameras drain batteries more quickly than others. Just a tip to help reduce the drain: don't use your LCD screen when unnecessary (such as scrolling through several of your pics in-between snapping pics).
Posted on Dec 27, 2008
Will not hold charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 02, 2012 | Kodak EasyShare DX6440 Digital Camera
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
Built in battery wont hold its charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 21, 2012 | Cameras
Nikon Coolpix L110 camera was bought for me for Christmas 2010. Worked fine at first, but now seems to be having problems. Batteries don't last. I just bought new batteries in Feb/March this year...
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
Jun 14, 2011 | Nikon Coolpix L110 Digital Camera
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
Hello. At first, the indicator light that shows whether the battery is loading/getting empty etc. failed. As I thought it wasn`t important I continued using the laptop. Then the battery loading adapter...
Most probably this is caused by the battery charging circuit inside your laptop. It looks like it is not charging the battery. If this is the case you won't be able to fix it yourself. You and should send it for repair.
Feb 28, 2011 | Computers & Internet
"battery empty" on screen after I disconnected camera from compu
Hi, have olympus fe-280 camera. Battery on screen shows full but shows empty (an inch strip) in middle. I have charged it. Even bought a new battery. Can anyone help. Thank you. ...... I want thinking I may have two faulty batteries and just need to buy another one?!
Jan 25, 2009 | Olympus FE-280 Digital Camera
Olympus camera: battery empty
OK, here's the answer. You won't find it anywhere else, but here it is.
If you use rechargable batteries, you MUST use ones with a respectable capacity. 2000mah are probably not enough. You need 2400mah at least. Yes, it doesn't make much sense, in the the battery capacity is supposed to reflect how long they'll last. But the wimpy batteries just won't let this camera turn on.
I have some experience with different battery capacity in this camera, and it took some aggravation to figure this out. But I'm pretty sure this is the answer.
The higher capacity batteries are more expensive, and their hold time is probably not as good. But I get a reasonable amount of usage with them.
Jul 20, 2008 | Olympus FE-210 Digital Camera
Samsung 301
Rechargeable batteries, do lose their capacity if recharged when partly down- the best way to discribe it is to say they have a memory- but only remember the last bit to be charged. So put the batteries into a torch or similar and leave on until completely flat and empty- then recharge. So do that and buy some new batteries - a couple of sets of batteries are best to have any way. Make sure they are NiMah and the charger accepts NiMah. Then clean out the contact in the bottom the of the battery chamber with the eraser at the end of a pencil. and the contach on the cap. Do that first then come back.
Jul 15, 2007 | Samsung Digimax 301 Digital Camera
Olympus FE-230 Digital Camera Logo
266 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
