Question about Siemens optiPoint 500 Standard Corded Phone
Can Siemens optiPoint 500 phone be used at home
We have a bunch of extra phones at work. These phones are through computer system and has multiple functions including conference calls, multiple lines, hold etc. I need a simple phone at home. Can the phone work at home on my regular home telephone line?
  • Anonymous Jan 20, 2009
    Dear All,
    I bought a used Siemens Optipoint 500 Advance. It seems the phone is not working. If I connect the phone to my home phone line, all what it does is that the LEDs flash and nothing happens. Does anyone know what the issue is?
    Thank you,
  • Carl Navarro
    Carl Navarro May 11, 2010
    Yes. That's why so many people have them in their houses.
    Do you need emoticons with that answer?
    Problem Solver:
  • 5 Answers
An "Optipoint 500" phone can not be used at home!
It is a digital phone, specifically designed for Siemens digital phone systems. Do not plug it in at home. That could damage the phone or may knock your phone line off.
However you can use a "Optipoint 500 IP" phone at home for voice over IP calls. But this would be connected into your broadband router and would connect via the web to your companys Siemens phone system.
Posted on Aug 04, 2009
Change internal directory on optipoint 500
The extension name and extension number are set in the system programming. Use manager 'e' and change them in the station view. If you are swapping people around and want them to keep their extension numbers and names, you should re-patch the cables feeding to the wall sockets rather than change the programming (if you can).
Oct 20, 2014 | Siemens optiPoint 500 Standard Corded...
Headset not working in opti point 500 basic
In order for a headset to work on that phone, you first need to make sure your headset is compatible with it. For example, our headset system:
http://www.aiheadsets.com/lxg-800.htm .
From there you would need to make the necessary switch adjustments on the setup . You are probably going to need a battery operated devise like ours. If you could provide your current headset model, I can help further.
Nov 05, 2012 | Siemens OptiPoint 500 Basic Refurbished
We have an optiPoint 500 system at our workplace and it is currently saying we are unable to record messages because the mailbox is full. Also, people say the phones are ringing but we are not getting the...
it.cc.stonybrook.edu/site_documents/.../guide_optipoint_500.pd
user manual
http://wiki.siemens-enterprise.com/index.php/File:Service_Manual_optiPoint_500_.pdf
Field service manual
If the mailbox is indeed full, and this WILL hold the entire system up, you simply need to remove the old messages. IF it is NOT true, then you have a fault,you need to first try a reset, and if that doesn't work, a re-program if that doesn't work, then the unit has developed an internal fault,and needs to be repaired.
wiki.siemens-enterprise.com/index.php/optiPoint_500
it.cc.stonybrook.edu/site_documents/.../guide_optipoint_500.pdf
Quick reference.
www.phy.hr/siemens/A31003-H1012-C121-8-7619.pdf
Please have a look at ALL links, all have good troubleshooting tips.
Apr 12, 2010 | Siemens Lands Phones
Programmed speed dial - internal calls
To add an Extension Key: -
DONT lift handpiece, enter [*91] then press a vacant memory key and then choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
To dial an Extension Key: -
Lift handpiece.
Press the memory key you programmed.
Storing a personal speed dial number: -
Lift handpiece.
Dial [*92]
Dial memory number.
(*0 - *9 for personal numbers)
Press the [ü] key.
Dial 0 then the number to be stored.
Press the [ü] key.
Hang up.
How to dial speed dial numbers: -
Lift handpiece.
Dial [*7]
Dial memory number.
(001-999 for system numbers)
For Example: [*7*0 ü] will call the personal number stored under position *0.
[*7001 ü] will call the system speed dial number stored under position 001.
Jan 19, 2009 | Siemens optiPoint 500 Standard Corded...
Cant seem to find how i change the display name on my Opti500
Usually changed by your Siemens system programmer.
Can be changed by the customer using Manager C software or by using an optiset E Memory Handset.
Nov 12, 2008 | Siemens optiPoint 500 Standard Corded...
Features keys
To add an Extension Key, enter [*91] and choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
Sep 17, 2008 | Siemens optiPoint 500 Standard Corded...
Changing the time on a siemens optipoint 500
here you go , follow this on your main phone to reset your time.
press sevice button ( top left )
press *95
press *95 again and press tick
press tick again
press right arrow key until you come to time
press tick key . then press *
enter time (hhmm) then tick key
press main service button and your done.
Jul 12, 2007 | Siemens optiPoint 300 basic...
Siemens optiPoint 500 Standard Corded Phone Logo
583 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
