Question about Hughes HR10-250 DirecTV / TiVo 200-Hours Video Recorder
Clearing everything Three hours ago I attempted to "clear everything" from the menu option and three hours later I'm still faced with a message that reads simply, "This will take an hour." I have unplugged all of the everything from the rear of the unit including the power cord for more than fifteen minutes and after powering the unit back up, I get the welcome screen, the almost there screen and then back to the hour screen. Nothing I've done has freed the unit and I know it to be working the moment before I decided unwisely to clear everything. Help. Please?
  • matoo Feb 02, 2008
    I have the same problem, but only the ratio light is lite. No red light.
    Scholar:
  • 27 Answers
A DVR has a small computer built in. When you run the clear everything option, this feature reinitialized the computer Hard Disk Drive doing a limited format. A format of a Hard Drive is always a slow process which normally takes 45 minutes to 1.5 hours on a 40 GB drive. Yours will actually take longer since it is larger (250 GB for 200 hours recording time), so I wouldn't panic yet. As long as you have a flashing red light on the box, it IS still formatting. If it goes beyond 8 hours, I would suspect you might have a problem or have been having some problem before (that motivated you to use clear everything).If, after 8 hours, it hasn't completed the format (red light flashing) then I would pull the cover on your DVR and pull and reseat the EIDE cable on the Hard Drive. Then restart again. Dirty contacts can cause this problem as well. Put the cover back on, do a hard restart and let it run again. If after another 8 hours, the problem still persists, then you may be experiencing read/write data errors on the drive. A failed or failing Hard Drive is most likely the culprit and it will have to be replaced. www.weaknees.com sells pre formatted and loaded Tivo Hard drives. If this is a Western Digital Drive, I would replace it with a Maxtor from them since the Maxtor are a special design just for DVR's.
Posted on Mar 09, 2007
  • elecadvisor Mar 09, 2007
    Safety note: before pulling the cover and sticking your hands in it, insure the power is off and unplugged. Set the unit on a sturdy surface. You will need a set of Torx screwdrivers since this is the head used on the screws. Touch your finger to a bare point on the case to insure you do not have a static charge on your body. Wearing of a static wristrap is advised to prevent any occurance of ESD.
Delete history skype
windows key+r type %appdata%/skype delete everything in that folder
Jun 16, 2014 | Computers & Internet
2009 crv check fuel cap
Go to the parts store where you bought the cap. Sometimes the code clears on it's own and sometimes you need to have it reset. If this is not an option disconnect the negative battery cable for a minute. Just as a warning, if you disconnect the battery you will have to reprogram most all of your electronics.
May 08, 2012 | 2009 Honda CR-V
Need to reset lamp usage time without the remote on NEC VT490
Hello
Press the MENU button on the projector's control panel to display menu options.Press UP/DOWN button to reach the RESET option window. There you can see Clear Lamp Hours and Clear Filter Hours option. Select the Clear Lamp Hour option and press enter. That is all. OK.
Oct 22, 2011 | NEC VT490 LCD Projector
I have been running Netflix through my Wii for several weeks. About a week ago it would occasionally give a cannot connect to the internet message, but later it would connect. About three days ago I got...
What might be happening is that your system is not updated. You may want to head to the options menu, go to Wii setting and look for the Wii System Update button and click that. That might be the solution.
Sep 01, 2011 | Nintendo Wii Console
During software update N73, the phone does not switch on. what can i do????
reset your phone using three finger method
follow this instruction :
Turns off the phone
Press simultaneously on the green/talk, 3 and* keys and hold the 3 keys.
Turn on your phone
Wait for the onscreen Format message then can release the three keys
This method may also work for Nokia phones that won't turn on.
Note that before making a reset on Nokia's latest phone
using the *#7370# or the 3 finger method, better make a backup, as you will automatically delete important data:
The license for pre-loaded contents (music, video, maps,etc..)
Mar 11, 2011 | Nokia N73 Cellular Phone
How do you reformat the hard drive for hr-20/700
If you go into the DVR's Menu/Setup there will be menu selections to "Restart Receiver" and "Reset Receiver"
In the reset menu you should find three options "restart receiver" which is roughly equivalent (and possibly safer) than the reset button or a power cycle. "Reset defaults" will clear all of your preferences and personal setting without affecting recordings. "Reset Everything" pretty much returns the receiver to ground zero and deletes everything.
Apr 26, 2010 | Directv HR20-700
Same problem - text notification incorrect
go to menu then messaging click on voicemail then clear icon, this will clear the message waiting indicator
Jun 23, 2009 | LG RUMOR Cellular Phone
Clear Memory
Goto setup menu and press dial button three times to enter into service menu. Goahead for clear option in that service menu
Feb 02, 2009 | Office Equipment & Supplies
Shutter locked up while reviewing stored pics
Problem not solved at this time. However the Optio web site offers live chat. M-F 9:30 am to 6:30 pm. I will contact them to discuss later today. I will post their recommendations. Thanks Txlingo
Sep 28, 2008 | Pentax Optio S4i Digital Camera
Taking forever to reinstall XP Home Edition
To clear the NVRAM, perform the following steps:
Restart your computer.
At the first text on the screen or at the Dell logo, press the <F2> key every three seconds until the message Entering Setup appears.
The System Setup screen appears.
Press the <Caps Lock> key, the <Scroll Lock> key, and the <Num Lock> key to light up all three lights on the keyboard.
Press the <Alt> and <E> keys at the same time.
The system will emit a beep tone to indicate that NVRAM has been cleared.
Press the <Esc> key, and then press the <Enter> key to save the changes and reboot the system.
Proceed with the installation or troubleshooting that you were attempting
Apr 03, 2008 | Dell Dimension 3000 PC Desktop
Hughes HR10-250 DirecTV / TiVo 200-Hours Video Recorder Logo
177 people viewed this question
Top Hughes Televison & Video Experts
jason
Edward Talavera
Edward Talavera
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
