I am having the same error code , P3-P5. Stating the head is open and the head is too hot. How can I fix this problem?I am having the same error code , P3-P5. Stating the head is open and the head is too hot. How can I fix this problem?
You can't post conmments that contain an email address.
There is a printhead hot error that will come up on the printer if it overheats the printing mech and it will pause. If it totally locks up I'd suspect the main logic.
1.Double check that the ribbon and the labels are routed correctly. 2.Make sure the media guide is holding the labels against the inside of the printer and not moving to the right away from the media sensor. If the labels are sliding to the right as they come out, increase the left side head pressure on top with a flat blade screw driver. Download the user manual at zebra.com .Check the media type and sensor type, and set for thermal transfer if using a ribbon.
try to recalibrate media and sensors, run calibration, and run sensor profile, save, and restar again the printer. check if setings from the driver are correct or they can change the setings from the printer
The display shows P3/P5 ERROR? You can try to load firmware, download the file from www.zebra.com press the keys - and +, turn the printer and you see FIRMWARE DOWNLOAD in screen, download the file through the parallel port. Roberto Martinez
Yasemin, the most practical solution is to design your label on a software like a label matrix or zebra designer and print to a file and have the ZPL codes.
Roberto Martinez
Mexico
[email protected]
The printer is Z4M or Z4M plus? I found this error at z4m plus and the solution is to change the motherboard.
Roberto Martinez
Mexico
[email protected]
