Question about Sony KV-35S45 35" TV
RCA ATC113AA.F20TF20 G2 Problem
RCA ATC113AA Hi guys,I have a problem.I started with dim picture i resolder everthing no avail. then turned up g2 have enough bright but get bad poor covergency on greens. when i turn down the G2 to the rihgt level where i can get a good pic and convergence,then when turn off set then turn back up again the pic is dim or without bright,i have to keep the G2 a litle bit higher thus degrades the green convergence,I don't have sckematic, i suspect either FLY or IC TDA6108 Video Amp, any ideas thanks in advance.
    Scholar:
  • 168 Answers
Adusting these stuffs needs a special equipment like the color pattern generator. u cannot just adjust this manually. try to inspect the crt circuit board see if there is an open resistor there. u have a luminance problem
Posted on Jan 16, 2007
Moto g 2 gen unlock code?
Guy
Contact the original service provider.
Mark
Motorola Support
Feb 16, 2015 | Motorola Moto G (2nd Gen)
Black screen, sound ok.flyback lines when G2 turned up
Never tune G2 voltage too up to a state, to appear retrace lines on screen. it is bad. It might make the CRT damaged. Check the video output card, and the voltages comes to it. This card can be located at the neck of the picture tube itself, will directly plugged to its back of the neck. Reduce the G2 voltage, in such a way that, there is no retrace lines appear. Be careful. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts
Dec 12, 2013 | Televison & Video
Htc g2 says it won't download picture messages
my htc G2 wont let me download media message ,how can i fix this?
Dec 18, 2012 | LUXMO T-Mobile G2 / HTC G2 / HTC Vision...
Camera flash wont work but works on video
I had the same problem. But after I started using Instagram, the problem got fixed.
Dec 07, 2012 | LUXMO T-Mobile G2 / HTC G2 / HTC Vision...
Blank screen audio ok. Picture tube has a line only going up and down
adjust voltage G2 Screen. thats why have retrace line. resolder also CRT board.
May 31, 2009 | Proscan PS50700 50" Rear Projection...
Picture flicks on and off
remove back panel of set look at the pcb boar conecting to the crt, look for a wite or black ajustment knob not all sets have them but most do, it called the g2 seting turn up your g2 a bit pic should come back the sad thing is this meens you pictortube dosent have much life left in it.
Jan 09, 2009 | Sony KV-20VM40 20 in. Combo
Trintron tv
Dear Lammy,
Turn the G2 control up, or clockwise just a hair, and see if the piture returns. The G2 or screen control is one of two controls located on the flyback, or high voltage transformer.
Please let us here from you!
Toprol
Nov 08, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
RCA D32F750T TV
Did you adjust the two controls on the new flyback? The top one is almost always the focus control and the bottom is the G2/screen control (brightness) If you adjust the G2 do it until the picture looks normal, too high and you will get retrace lines through the picture.
Jan 25, 2007 | RCA D32F750T TV
Brighteness
In my case, the adjustment was available from outside the TV. Sortof. On the rear of the TVabout 2 inches to the right of the coax in, there are two vertical slits on a little protrusion. Inside the slits are the two adjustment screws. The lower screw adjusts brightness, the upper screw adjusts focus. I spend 30 minutes popping the case apart just to find that I could not access the adjustment screws from inside. Lo and behold, they made them easily accessible from the outside. On a side note, I have never seen a TV designed as poorly as this on the inside. You have to literally reach in and unplug things just to get the back off. All the electronics save the tube itself are mounted to the rear chassis. On all other TV's I've seen (taken apart, rather), all the electronics are in the FRONT part of the chassis so that they move WITH the tube.
Sep 23, 2006 | JVC AV-27530 27" TV
Sony KV-35S45 35" TV Logo
66 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
