Question about Canon EOS 400D / Rebel XTi Digital Camera
Camera fell in the water for 3 seconds, wont turn on
My canon rebel xti fell in the water for no more than 3 seconds and i made the mistake of turnnig it on after a while, some images came on but it was blury, i took the battery out and the flash card, now the camera wont even power on. i need help
    Problem Solver:
  • 15 Answers
The best advice is to check with Canon, describe what happened, and take their advice. I think you will do best if it is seawater, or saltwater, to return it for servicing, as salt is deadly to some camera parts, and if you switch on with salt water in, it can cause permanent damage to circuits, and even can create a short between components, particularly the flash circuit. If it is fresh water, and for some reason you don't want to return it, it is best to use a hair dryer on medium or low heat to blow dry as much as possible, with the lens off, and the battery and card compartments also open, and come back to it after about an hour and repeat.Do not heat it to anything more than about skin heat, as evaporation will continue at even room temperature. Do this for most of the day, and leave it for a day or two, or even a week, as open to the air as you can, but in a dust-free environment, preferably in a warmish place, like an airing cupboard, so that all moisture will evaporate, Then try it again with fresh battery. I suspect that if it still won't operate, you could repeat the process, but it is most likely then, that you will have to return it for servicing or repair. I had an Olympus C8080w, and me and the camera were swamped by heavy spray from a wave, and I ran to the local shop, bought some tissues, and dried it immediately. I took it home, zoomed out, dried as much as possible down the lens gap, and left it in warm room. When dried out, some salt crystals were left on the lens barrel on zoom out, but thank the Lord, it still worked, and has not let me down - I did use a damp hanky to try and absorb as much water as possible from the outside, and dilute any surface salt as much as I could. I still use it regularly, but dropping into water is a different matter. - Please post and let us know what happens - and the best of luck
Posted on Nov 29, 2008
Canon rebel xti
Tr5y a factory reset on the camera. And try another Memory card.
Aug 19, 2014 | Canon EOS 400D / Rebel XTi Digital Camera
How do you get to the video mode on the canon 400d rebel xti
There is no video mode on the Xti. The first Canon Digital Rebel to be equipped with video was the T1i, which came out almost 5 years later (2 years ago).
Feb 15, 2011 | Canon Rebel XTi / EOS 400D (body only)...
My canon rebel XTi body fell into a pond. I tried to dry it out for the past 2 weeks, but it won't work. It won't turn on at all. Is there a way to fix this?
Unfortunately there is no way of fixing the issue short of replacing the parts that were damaged by water. The service is available, so all hope is not lost!! However, I must warn you that the replacement of the main board (which is most likely what is causing your camera to not power on) may not fix your camera completely as you do not know how far the liquid damage has gone.
There could be other issues such as lens damage, water spots inside the lens, etc. My suggestion would be to have that main board replaced and go from there. If you're comfortable doing it yourself, I strongly advise you to open the camera and try to determine how far the corrosion (it will look like lime build-up basically) from the water stretches before you make any decisions on whether to have the main board replaced or not.
Sep 09, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I dropped my Canon EOS Rebel Xti in the canal while kayaking.
Water in the camera body could take up to a week to dry. If you tried turning it on while it was wet inside, you may have shorted out some circuits.
Aug 23, 2009 | Canon EOS 400D / Rebel XTi Body Only...
CANON REBEL XTI LCD
Your battery is low ...shut the camera in off position and replace with fresh battery
Oct 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XTI isnt getting powered on after few drops of water fell on the lens and the screen.
Such symptom indicate a malfunction on the DC/DC voltage converter circuitry or the main board, caused for moisture as result of the water drops.
In order to perform a correct diagnostics and repair of it, it is necessary to open such camera and perform it by a qualified camera repair technician.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you have the options of pay for its repair, or do it yourself if you are willing to open it and perform some basic diagnostics of the failure. You will need tools to do it, which includes the usage of a soldering iron.
The repair cost may be so huge that is cheaper to buy another camera, since after open it, it may be necessary to replace multiple expensive parts.
Best regards,
Sep 01, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon Rebel XTi/EOS 400D
I made the mistake of putting ahotshoe protector from my old camera on the new EOS 400D. It stopped the flash from popping up. I took it off and things now work.
Mar 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Not working with my Rebel XTI
ALL Canon digital EOS cameras will work with E-TTL only. Solution: you need EX flash for full auto.
Oct 20, 2006 | Canon Speedlite 540EZ TTL Flash
Canon EOS 400D / Rebel XTi Digital Camera Logo
307 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
