Question about Olympus D-600L Digital Camera
Olympus D-600L Lense tries to open & shutter won't work. Firstly, Batteries are properly charged. The Zoom works, the SLR viewer is closed. When holding down the button it sounds like the camera wants to activate the shutter. I tried to remove the case but even after removing all the screws I still could not loosen the case. Any help would be appreciated.
  • raymonty May 03, 2008
    Yeah, same problem as above. Green light keeps flashing like it used to with insufficient light, but now, under no circumstances will the shutter release.
5 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: Shutter release inoperative
The "button" is actually just a plastic extension for the actual switch on the printed circuit board. You will have to dismantle the camera to gain access to the board and then use a DMM to test the switch contacts.
Posted on Oct 04, 2007
jackboy
  • 2985 Answers
SOURCE: olympus mju zoom 140 35mm
This is like to be the zoom motor playing up.
If the camera is new[1 year or less] return it.
A repair is not a likely option.
Posted on Jul 23, 2008
  • 919 Answers
SOURCE: need a replacement lense for
You may want to call Olympus Customer Service and discuss repair cost and process. Their telephone number is 800-622-6372 option 2 and then option 3
Posted on Dec 11, 2008
mark24354
  • 776 Answers
SOURCE: camera (Olympus SP500-uz) turns on,
Make sure you have the switch turned to "take picture (camera)" instead of "reveiw photos (green triagle)". On this one, i think it is a wheel on the top of the camera.
Only thing I can think of...
-Mark
Posted on May 05, 2011
Shutter won't reset after battery replacement
it can fixed only camera fixera company,better if you fix it according to camera company because your problem also be facced to me,i take it to a ordinary camera fixer and then my camera fully get damaged because who fixed my camera they fall acid in battery placce.
Mar 26, 2013 | Vivitar V3800N Zoom 35mm SLR Camera
Nikon FG. Replaced 3V battery. On the M90 setting the film advances OK. On 'program' or other settings it will only advance once and after shutter fires it will not advance until put on...
M90 is a battery independent setting - it requires no battery power to function. If it won't advance until put on M90 from other settings, then either you're not allowing for proper exposure, have the settings incorrectly set (film speed, etc), or you have shutter issues. The shutter is electronically controlled on all settings except M90. In the auto setting, your lense MUST be set to the smallest aperture (biggest number). On any other setting, you can use it however you'd like. I'd suggest unloading any film, setting the shutter speed dial to 1/125 or so, opening the back and looking thru and firing the shutter. If it's not snapping open and immediately closed, theres an issue and you need to consult a repair technician either locally, through Nikon, or through KEH Camera online.
Jun 29, 2011 | Nikon FG 35mm SLR Camera
I have a nikon N2000 35mm slr, before it was fully functional, now the problem is, The shutter won't open/close but the rest of the camera controls are still functional. Camera wasn't set on B...
So I assume you have changed the batteries and made sure there isn't any corrosion on the contacts. If your mirror is flipping up but no shutter, it sounds like a bad shutter. Check the shutter from the back, then from the front behind the mirror. Look for abnormalities or residue. It is a great camera and uses standard batteries (!) but the 1/2000 shutter has a half life like any other SLR. If you are going to throw it out you may want to open the back and use a q-tip to drip a couple drops of 90% alcohol on the top and bottom (and sides) of the shutter. As a last ditch, I throw cameras or lenses in the toaster oven at 200° for 10 min. and retry (take out batteries and film). At the least it will kill any fungus at the worst it hardens some lubricants. It does make you feel like you are doing some specilized scientific work before you toss it in the trash.
Jan 07, 2018 | Nikon N2000 35mm SLR Camera
The shutter will only close in the B or M90 postion. It opens fine, but won't close. What should I do?
Try a new set of batteries. The shutter is electronically operated at all speeds except the B and M90 settings. If the exposure meter works with a new set of batteries but the shutter still does not, then you'll have to take it in for service.
Feb 20, 2011 | Nikon FE 35mm SLR Camera
Shutter wont close
Try setting the shutter to B and see if you can trip the shutter. If no go then it has mechanical problem. If it works on B but not on other shutter speeds, you have electronic problems.
May 16, 2010 | Pentax Program Plus 35mm SLR Camera
Lense will not work with SLR Nikon D90
This lens is too old for the D90, it has not got the electronics for metering and autofocus.
You can use it manually in M mode but you will have to set the aperture and shutter yourself.
The D90 manual has a section on compatible lenses, page 228 in my version.
This recommends CPU lenses for the D90, type G and D.
Dec 25, 2008 | Nikon Zoom 80-200mm f/4.0 AIS Lens
Lense Damage in side
It depends on the nature of the damage. What are the symptoms? For example, does it fail to zoom in and out, does it fail to focus properly, do you see something out of the ordinary when you look through the viewfinder? Have you taken some test pictures? If so, what did the photos look like. If you can give me the specifics, I can probably advise you correctly.
Nov 25, 2008 | Olympus IS-300 35mm SLR Camera
Re: Shutter Wont click
Hi , check everything set c amera speed to 60/seconds auto or manual / check also the the camera shutter blade , open the lense and close to activate the shutter blade .
Feb 17, 2008 | Nikon F80 35mm SLR Camera
Shutter
sounds like the lil motor that is in charge of opening and closeing the shutter might have shorted out causing it to stick, or it could have just simply burnt out or striped the lil gears on the motor. If the shutter moves alil bit i would say you probably have a short in the shutter motor.
Dec 05, 2007 | Fuji Zoom Date 60 35mm Point and Shoot...
Lense wont open
Firmware fault Tell Olympus Tech Support
May 04, 2007 | Olympus Camedia C-50 Zoom Digital Camera
Olympus D-600L Digital Camera Logo
52 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
