Question about Hobart A200 Stand Mixer
Hobart A200 diagnosis
I'd really appreciate your input regarding an older A200 (#794389) that I have.  It is making a periodic noise that seems to coincide with the occasional clutch slip?  I assume it is the clutch slipping as the planetary motion speeds up momentarily before settling back down to normal speed.  All 3 speeds of the transmission function and the attachments are not hitting the bowl.  The machine has sat idle for quite some time so I was wondering if there is anything I can do (oil/grease) to refurbish it a little.  Here's a quick video of it:
Many thanks!
  • cdnDough Nov 25, 2008
    Many thanks.  I think I may take the top cover off this weekend to access the internals.  A few more specific questions:
    - Is the noise in the video I linked, 'normal' for these machines?  It doesn't seem excessive to me but it has been 15 years since I worked in a kitchen.
    - How frequently should the transmission be repacked with grease?
    Also, what is the easiest way to check the worm gear drive?  I removed the top case and tried to peer into the two ports... one is blocked by grease, the other by dried grease/grime.  I gather I'll need to pull the transmission gear unit to inspect the worm drive.  Looking at the exploded diagram (PL-6754) in the spec #3943 instruction manual, I'm looking for the presence of a worm (part no. m-12743) and spring / shock absorber (part no. v-12757).  For what it is worth, I certainly cannot make the planetary slip if I try and hold it so perhaps the skipping is the dough pushing.
  • 49 Answers
The first A-200's have a worm gear drive that will slip when old but also when mixing dough somtimes the dough will push the mixer aherad of its self and look like its slowing but its just catching up. if you have a old worm shaft it will have a spring on it is how to tell. it is replaced with a shaft that is all keyed and has no slip or give unless a key shears.
Michael
Posted on Nov 25, 2008
How to change hobart a200 motor bearings
Do not heat up you have to strip the gear box but not all take the top gears off but look what you are doing its got to go back the same way or it won't work you have to take the worm gear off and then you can take it out from the back but if you can't do it get in touch with **** at x bakery in Haywood and ill sort it for you hope this helps it is a big job sorry
Jan 06, 2013 | Hobart A200 Stand Mixer
Hobart A200 Noise
After viewing and listening to your video, my first guess would be bad bearing(s). The sound varies with the speed of the agitator, so the noise is at the speed of the transmission shaft or planetary area. These mixers use very common standard bearings. As such, they are available very reasonably from sources OTHER than Hobart. You will need to take the transmission apart in order to find and solve the problem. Study the parts manual in detail. It seems complicated, but once you understand it, it is logical. I highly recommend that you get a really good understanding of how it works and goes together before you start taking it apart though.
Nov 02, 2012 | Hobart A200 Stand Mixer
Was just givin a hobart a200 was in a school warehouse for at least 1o years attach.shaft and seals replaced by hobart 6 month before put in storage runs great smooth no gear noise BUT fromm sitting bowel...
Ogrin56,
The problem is in your lift handle cams, you need to take the pedistal apart and clean and grease all the cams. I take them apart and wire brush them and use white lithium grease to keep them from freezing up.
Feb 26, 2011 | Hobart A200 Stand Mixer
Can I cange 3x230v up to 400v
Are you stating you have an A200 mixer that is 3 phase 230 volt?
I was under the impression all A200's were single phase. The D300 floor model came 3 phase. In any regard, to change the input voltage to any maching, you would have to replace the rotor, stator, and control group, including wiring. It has to be kept to orgiinal specifications, and tech support would have to authorise the change. As you can imagine, it's not really an option. If you change from 50 to 60 Hz, you would have to change your worm gears also.
Oct 03, 2009 | Hobart A200 Stand Mixer
Hobart A200 Worm Gear Shredding Brass Gear
no there are no adjustments . you must have bent the case just a little , i dont see any good news for you , sorry . i have worked on hobart mixers for years and you should get 5-10 years out of that gear
Jan 15, 2009 | Hobart A200 Stand Mixer
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
Hobart A200 transmission issues
does not sound good it need to be torn down and checked from here thats more then can be figured out sorry
Nov 26, 2008 | Hobart A200 Stand Mixer
Hobart A200 noises
Hi, here is my opinion: 1) your planetary, or attachment hub is making the noise as it goes around, and there is grease in the gear ring that keeps it lubricated, it may be as simple as removing the planetary grease ring ( the chrome ring), and taking loose the bolt and lowering off the hub and cleaning the old grease, and installing new, reassemble in reverse. You may also have bad bearings in the shaft portion of the planetary ( the shaft your attachments go onto) allowing the shaft to "wobble" a little bit causing a slight misalignment as the smaller gear goes around while mixing. How far you want to go is up to you.
For your other problem, I have seen the brass clutch bearings stick on the main shaft in the transmission, causing the planetary to momentarily speed up, or to maintain a wrong speed ( 2nd or 3rd) when set to first, but that would require full disassembly of the transmission. Best left to someone who has done it before, but if your inclined, go for it, but get a part breakdown first, or take pics as you go. Hope at least some of that helps, and thank you.
Nov 25, 2008 | Hobart A200 Stand Mixer
A200 problem
Check the planetary.this is the bottom part of the mixer where you attach the hook.
You will see two nuts; make sure their tight as the planetary may have moved down.
Also have a look below:
http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
Feb 04, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
268 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
