Question about Canon PIXMA MP960 All-In-One InkJet Printer
I have lost the information on my canon pixma mp830 printer
I can't find my papers for where the ink cartridges are exactly located so i can't remove them to buy new ones
    Scholar:
  • 162 Answers
Go to wepsite and download easy setup manual and follow it.
for canon pixma mp830 see the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=12804
for canon pixma mp960
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=13988#DownloadDetailAct
I am sure this will realy help you.
Posted on Nov 25, 2008
Canon MP830 had a paper jam that forced a black sponge/foam piece out. Prints ok now. Do I need the sponge/foam piece?
Hi!
You must replace it because the sponge absorbe your waste ink from your cartridge. If you don't replace it, your cartridge will not long last.... thanks
Sep 07, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6A00 shut down machine. How do you fix it?
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Oct 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
A piece of foam sponge under the ink catridges has broken, and the printer will not cleanly draw paper for printing - it jams.
The sponge under the print cartridges is to soak up the ink when cleaning the print heads. If part of it broken off and lodged in the rollers where the paper is drawn into the printer then try to locate the sponge and remove it. Sounds like it's lodged somewhere and jamming the paper feed.
May 10, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error Code 6A00 on Canon MP830
try this 1. Opening the cover and wait for ink carriage to center 2. Pull out power cord 3. Pushed carriage to far left (should slide easily) 4. Used paper towel and wiped purge unit a lot of times (press down to soak paper towel with ink). Repeat until the paper towel is relatively clear. 5. Used diluted napisan (oxygen-based cleaning agent in the ratio of 1:3 with powder:water) and soaked paper towel 6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white. 7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down 8. Slided carriage back to original position 9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Jun 09, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Need to replace ink cartridge
http://reviews.cnet.com/multifunction-devices/pixma-mp830-office-all/4505-3181_7-31785803.html
Replacing the five ink tanks (cyan, yellow, magenta, black dye, and black pigment) is a simple task. The top of the printer flips up to reveal the ink tanks and the printheads, and by flipping a lever, you can pull out each tank individually. Being able to replace individual tanks is a boon, as you won't waste colors you use less frequently. Also, you won't need separate photo ink to print photos, which we appreciate. Canon ships the Pixma MP830 with full ink tanks. Replacement color and dye-based black ink tanks cost $14.25 apiece, while the pigment-based black ink tank costs $16.25. Canon estimates the cost per page for both black text and color text to be an inexpensive 2 cents.
May 31, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP830 printing red/orange hue on glossy photo paper
are you using geniune canon glossy paper??? it is designed for the printers and really is the best for the machines
Apr 08, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Ink cartridge
see instruction manual. go to manu website and see their manual pdf file and should be helpful-with pictures.
Jun 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
My Canon PIXMA MP830 all-in-one is saying "the type of printhead is incorrect, install the correct printhead."
The cartrige is what holds the ink, the printhead is the device that puts the ink onto the paper.
So if your out of ink, then you need a new cartridge, if you have a new cartridge and you are having issues printing good quality, then you may need a new printhead.
you can get the ink here: http://printerinkcartridgesearch.printcountry.com/canon-pixma-mp830-ink-cartridges.htm
printhead is about 49.95
http://www.precisionroller.com/k_canon_pixma_mp830_print_head/m114d8577c104/
Hope this helps!
Brad Nelson
Mar 14, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Defective Ink Cartridges for Canon PIXMA MP830
1. Just open and close the cover a bid, this will initiate new checking of all ink cartridges
2. clean the contacts of the inkcartridge chip e.g. with spirit
3. Press the reset/stop-button for >10s to quit the error ... but be aware that the ink level will no longer shon correctly
Jan 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP960 All-In-One InkJet Printer Logo
98 people viewed this question
old marine
old marine
