Question about JVC Everio GZ-MG155 Camcorder
I have a JVC Everio GZ-MG155, and the zoom is stuck at 1x.
Everything is blurry onscreen and when I attempt to zoom out the zoom will not work. It is saying 1x. I have tried to preset back to factory default setting but is not working.
  • 5 more comments
  • gbowdoin Dec 19, 2008
    Mine is stuck on zoom and will NOT focus!
  • slessels Dec 26, 2008
    My zoom is busted too! I can focus at 3x and 17x but the picture is the same. The zoom does not change. A 3 inch object takes up the entire screen from 20 ft away.
  • Chinny9 Jan 05, 2009
    My zoom is stuck and the lens will not focus, either on manual and automatic. When you move the zoom lever, you can see a straight line at the position the lens is stuck. Anyone know how to "unstuck" the lens? It just happened and there were no drops or bumps on the camera previously.
  • tv77 Jan 08, 2009
    I am having the same problem, and the camcorder is unusable.
  • Anonymous Mar 28, 2009
    how to change the language to english
  • Anonymous May 05, 2009
    I have the same problem the zoom works but the focus will not adjust. So all I see is a blurry image. Please help!
  • Chinny9 May 11, 2010
    Spoke with JVC technical support. They had me try to discharge the unit by keeping it on with no power source hooked up (no plug, no battery) for 1 hour. They said it is caused by static on internal capacitors.
    That didnt work. So now they say that means the lens is broken and it needs to be fixed. They didnt quote a price, but could be anywhere from $100 - $275. Darn camcorder is only worth a little more than that.
    Bottom line: Doesnt look like there is a fix. Each user needs to check warranty info or JVC will charge charge you for fixing the darn lens. Seems like they should check for faulty zoom lens, but they are not.
Did you try holding down the record button and the picture snap shot button at the same time to reset it? It did for me.
Posted on Jan 04, 2010
How can I connect my JVC Everio GZ-MG155 camcorder (with a dock) to the HDMI tv input? What kind of adaptor(s) would I need?
The Everio GZ-MG155 and the dock supports an special A/V cable with composite ( http://store.jvc.com/product.asp?Model=QAM0120-001 ) or S-video ( http://store.jvc.com/product.asp?Model=YTU94146A ) cables for a TV with an analog tuner (NTSC). These signals are 480i. If you want to connect this analog signal to the HDMI port, you need an analog to digital video converter (and the appropriate cables). Something like this would work: http://www.monoprice.com/Product?c_id=101&cp_id=10114&cs_id=1011406&p_id=9994&seq=1&format=2 . This model will attempt to upconvert the signal to an HD format (720p minimum). Additional converters are here: http://www.hdtvsupply.com/cotohdco1.html . The A/V to HDMI cables will not work so check out these products carefully.
The manual for the JVC Everio GZ-MG155 is available on the product page: http://support.jvc.com/consumer/product.jsp?modelId=MODL027855 . The direct link to the Instruction manual is http://resources.jvc.com/Resources/00/00/91/LYT1668-001C.pdf .
I hope this helps. If your TV has the legacy analog ports, you just need the original A/V cable.
Jun 03, 2015 | JVC Video Cameras
I have an everio camcorder GZ-MG155U. It will only focus on 9X, 10X, and 11x. Anything else gets blurry. I have tried auto focus and manual focus and nothing works. I also tried resetting to the...
The most likely cause for this is a zoom or focus lens out of place or impaired in some way and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Aug 11, 2011 | JVC Everio GZ-MG155 Camcorder
Looking for a jvc everio gz-mg155u manual
You can download and print the instruction manual for JVC Everio gz-mg155u in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Nov 01, 2010 | JVC Everio GZ-MG155 Camcorder
I have the JVC Everio GZ-MG130 Camcorder, when I turn it on, it always zoomed at 14X, is there a way to set it to zoom at 1x Thanks
Your camera's Tele Wide sliding pot is damage or carbon inside,if you have Isopropyle alcohol then few drops give inside the T/W pot and move it right left maybe your problem will solve
Mar 09, 2010 | JVC Everio GZ-MG130 Camcorder
I zoom in and out on a subject the subject gets jvc gz-mg142ek
the gears or machinery thet move the inside lenses are broken or out of place. I've just opened mine to try to find the exact problem. good luck.
Oct 27, 2009 | JVC Everio GZ-MG155 Camcorder
I have lost the software disc for my jvc everio gz-mg36ek.
i have lost my sofrware dis of GZMG 155 JVC Everio, from where can i download the software ?
please help me over the above matter
Aug 02, 2009 | JVC Everio GZ-MG155 Camcorder
Zoom stuck and will not focus
Check to make sure you have not inadvertently set the camera into manual focus mode. Many cameras have 2 modes: auto focus and manual focus.
Jul 18, 2009 | JVC Everio GZ-MG155 Camcorder
I do not have software for a used JVC Everio GZ-MG155
You can download the manual and software from here with a computer.  I don't know or understand abotu your remote since yo ustated Xp OS.
Dec 20, 2008 | JVC Everio GZ-MG155 Camcorder
JVC Enverio GZ-MG155 30gb camcorder
Try removing the battery and see if it changes back to the default settings.
Aug 04, 2008 | JVC Everio GZ-MG130 Camcorder
JVC Everio GZ-MG155 Camcorder Logo
1,497 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
