Question about Sharp 20R-S100 20" TV
No sound and Picture okey
I have change the power IC but still no sound? What else are the part to be checkor replace?
    Scholar:
  • 168 Answers
Speaker. see if it is open. by the way what power ic is that? is that the audio output ic?
Posted on Jan 15, 2007
LG 42LE4500 ZA no picture
1 or 2 condensed broken check it better in YouTube can see better with images
Dec 30, 2015 | LG Televison & Video
When turn on computer there is a sound signal from computer but the monitor has no picture but monitor is okey.
This sounds like a dead motherboard.
you should reset the cmos (using a jumper) or remove all power cords, battery and the cmos battery. wait 10 mins and put everything back.
The second option is a dead power supply. The only way to check that is to replace it with a new one.
Aug 23, 2014 | Computers & Internet
Lg 42le4500 tv when first turned on its okey after 2 minutes no picture black screen but sound ok, turn it off and back on againdoes the same
I would bet on some component(s) have become thermo sensitive. Most of the time capacitors can do this type of thing. Most likely the defective caps could be in the power supply.
To locate the defective caps, you would have to be able to run the supply and use the combination of a heat gun and freeze spray (liquid air spray) for cooling. At the same time you would have to monitor the output of the supply to see the components that cause the output change.
It is also possible to have thermo sensitive components on any of the other boards. This would also require proper troubleshooting.
The service rep would replace boards until he found the defective board. Then he would return the set with the new board and the bill for his work.
If your set is out of warranty, it may be better to consider a new set. Servicing these can be fairly involved and expensive.
Jerry G.
Jun 25, 2012 | LG Televison & Video
No audio on sanyo ds31520 after replacing vertical IC.
Replacing vertical output IC won't poise this type of problem. Check the voltages at the audio output section.
Jun 22, 2012 | Sanyo DS31520 31" TV
No picture or sound with a red flashing power light. Have replaced the convergence IC's but no change (do not have the chirpint sound). Removed main power board & green LED does not light up
On that model the conv IC is usually not the solution. I believe its the blown capacitor problem with is an easy fix. Check the site www.TvRepairKits.com for a repair kit.
Apr 11, 2012 | Hitachi 53UWX10B 53" Rear Projection...
Tv has sound but no picture
the problem is from your picture IC. The picture IC of your TV is faulty and need to be changed/replaced for your TV picture to display again.
Good luck.
Mar 11, 2010 | Televison & Video
SAMSUNG sp-p4231 sound, but no picture
try changing the display IC that would be the frequent cause of such problems
Jul 04, 2009 | Televison & Video
Picture is ok hissing sound in rf connectoin
Yes, change the tuner and make sure that all ground are well connected.
Jun 16, 2009 | Samsung SlimFit TX-S3082WH 30" TV
No sound or picture
first check  if it is in AV  mode.  if true then change it to TV mode.  problem will solve ...
  In rare cases  inside the TV  board  chroma ic may gone if there are  2 ic's.
micro controller may gone if there is  only one ic...
thank u
Sep 30, 2008 | Samsung TXE2546 25" TV
No picture just sound
TURN UP THE A1S ON THE TRANSFORMER IF YOU SEE A VERTICAL LINE ACROSS THE SCREEN ITS A FAULTY FRAME IC CHECK FOR DRY JOINTS AT FRAME IC, REPLACE WITH A NEW IC IF NO OTHER FAULTS ARE VISIBLE.
Nov 14, 2007 | Sony KV-35S26 35" TV
Sharp 20R-S100 20" TV Logo
66 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
