Question about Dell UltraSharp 1907FP 19" LCD Monitor
Dell 2007FPb monitor cover removal
A small quantity of softdrink liquid dripped on the bottom right part of the monitor, rendering them last 3 buttons (-, +, POWER) hard to operate. I removed the 4 screws in the back but I can't locate any notches between the front and rear covers (as mentionned in a solution on your website) to clean the circuit board.
any help would be much appreciated
thanx
  • bavery Feb 17, 2009
    i have the same problem
3 Suggested Answers
Mark_Webber
  • 472 Answers
SOURCE: Dell monitor back removal
This can go one of 2 ways..very easy or very hard.
Having said that here we go.
  • Get a towel and lay it on a flat surface.
  • Remove the 4 screws from the stand and remove it.
  • looking from under the monitor you should see 2 small notches between the front and rear covers.
  • Carefully insert a flat blade screwdriver (not too far) into the hole and lift upwards. It should pop. Do the same on both sides.
  • Carefully pop it all the way around (without using anything but light pulling pressure.)
Hope that helps =)
Posted on Apr 09, 2008
SOURCE: Removing front bezel of Dell 1907FP monitor to repair stuck power button
I didn't take the case apart at all. Using the info kaitanium supplied above (thanks!),
I simply drilled a small hole directly between the power button and the + button.
I now switch the monitor on & off with a toothpick.
I would advise this method if your power button seems to be stuck (it isn't, it's broken off inside) as it saves you scatching the buttons/case and the hole is not noticable at all. Pick a drillbit that's just big enough for a toothpick to fit through and only apply a tiny amount of pressure to the drill. The plastic case is very thin so be ready to stop the drill immediately.
Oh and for the hard of learning... Unplug the monitor first. :)
Posted on Sep 26, 2011
Service manual for dell 2007fpb
Gopees2000,
There are no service manuals available. Only the user manuals.
You can click the link below to download the online manual for the Dell 2007 fp monitor.
http://dell.to/1QMvq6t
Thank You,
Dell-Jesse L
Dell Social Media and Communities
May 14, 2015 | Dell Computers & Internet
I HAVE DELL LCD TV SCREEN 2007FPB SUDDENLY IT DOES NOT WORK WHEN CONNECTEC TO POWER SUPPLY, PREVIOUSLY IS GOOD WHAT IS THE PROBLEM & HOW MUCH MONEY NEED
First check your monitor light is blinking or not. If it is then--
Check your monitor cable which is connected your CPU. If it is ok then
Open your CPU and unplug *********** board power cable and re-install it.
And also remove RAM and clean with a brush softly and re-install it.
Best of Luck
May 13, 2011 | Dell E173FP 17" LCD Monitor
Dell 2007FPB LCD Won't turn on nothing happens when the power button is pressed
Hi and welcome to FixYa!
As a first course please check the monitor power cable. It may be a little loose that's why its not powering up.
Hope this helps and thank you for using FixYa!
Dec 02, 2010 | Dell UltraSharp 2007FP (Black) 20.1 inch...
DELL 1907FP MONITOR
There were no screws on the back of my monitor so that was not an option for me. I figured I didn't have much to lose, so I took a very thin and small screw driver and pried the on-off button right out of its socket, which does break it. To the left, inside the hole,you can see where a tab on the button pressed against a small circular inner button. I pressed that with the screwdriver and the monitor turned right on. I replaced the button for the sake of cosmetics and will never touch it again. If I leave the monitor for any extendd period of time I will simply unplug it.
Sep 06, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell E196FPf monitor power problem
generally dell monitors open from the bottom they have slight indented flat spaces for a small flat head screw driver to twist and pop the frame apart I start on the bottom left and work my way right and then open the sides carefully and last the top.
Please rate if helpful
Jan 14, 2009 | Dell E153FP 15" LCD Monitor
Dell W1700 picture went out. Still have audio.
I have just did this here is the solution for you:
MoniServ, Inc.
http://www.moniserv.com
Tools:
Philips screw driver
Small Flat screwdriver
that’s all!
Preparation:
Make sure your desk is clean and you also need a piece of soft clothes because you need
to place your LCD Monitor face down.
How to open the back cover:
First, remove all screws on the back cover, then, use a small flat head screw driver to
push down
the plastic Clip inside the LCD Monitor star at the bottom of monitor. Then you can easily
separate the front bezel and back cover like the photos shown below.
Backlight Inverter Installation Procedures for Dell W1700
Place the Monitor
Face Down
Push This Plastic Button
Down and Remove
Swivel Base as shown
on Next Photo
Remove these
screws
Star at the bottom of monitor as
shown on photo.
Use a small flat head screw drive
to push down the plastic clip.
Do it one side at the time as
shown on next 2 photos
When you have unlocked all 4 sides of plastic clips, Place the monitor face down again
as shown on photo
Slowly tilt
upward from
left side of
back cover
Disconnect this cable and
remove back cover
Remove two
screws and Pull
out this small
circuit board
Disconnect Speaker
cable and remove
the tapes
Disconnect
Backlight cables.
Remove these screws
on the both side of
Panel
Caution!!!
Slowly tilt upward the chassis and disconnect the flat cable
between Chassis and Panel As shown on next 2 photos.
Holding the chassis upward and
Use small flat head screw drive
to unlock this plastic clip
Slowly pull it out
Remove defective inverter board and replace with our New Substitute Board
(T501045.00MSS) and re-install all disassembly components back. Now your LCD
Monitor working again.
MoniServ Substitute Board is available at
http://www.lcdpart.com/Products/t50104500mss.html
Backlight Inverter board.
Photo Shown with our Substitute Board
Remove 4
screws and
disconnect
this cable
Nov 29, 2008 | Dell W1700 17 in. HD-Ready LCD Television
Opening the dell 1707FP monitor
To open the case, do the following:
1. Remove the base from the back of the monitor by pressing the large black button on the back.
2. Remove the 4 large black screws located under the plate you removed in step 1.
3. Along the left side, towards the top of the monitor, locate the seam that divides the front from the back of the monitor. This is located along the left side and is about 1/16" back from the front of the monitor.
4. Using a flat blade screwdriver with approx a 1/4" wide blade, work the screwdriver into the left side seam, almost to the top of the seam. Your screwdriver should be going into the crack between two pieces of black plastic.
5. Gently turn the screwdriver left and right until you feel the front separate from the back.
6. Once you have a "hole" to start working from, gently pry the rear cover away from the front bezel. Make sure that the bottom right corner (closest to the power and adjustment buttons) is the last part of the front that you attempt to pry apart. Be extremely careful in this area, as the buttons are part of a small circuit board attached to the front bezel. While it seems like front bezel is the piece to remove, actually you want to remove the back case first. Pulling the front bezel too far away from the LCD screen itself can damage the flex circuit. Once you remove the back cover, you should be able to see the red and white flex circuit that goes to the front panel circuit board.
7. Gently fold the bezel away from the LCD screen, keeping the bottom edge of the bezel close to the screen. Again, use caution not to damage the flex.
8. Once this is done you should be able to see a green circuit board with 5 very small phillips head screws. Remove the screws and find a safe place for them. Once this board is removed you should be able to see the cracked button. In my case I just removed the pieces of the button and powered on the monitor using a small q-tip. Once reassembled, the actual button is inside the hole, but off to the left. The two contacts that you see directly behind where the button used to be are LEDs to indicate the power is on.
NOTE: In place of a q-tip, you can use any small, non-metallic, not sharp object. A pointy pencil eraser might work well too.
Reassembly is the reverse of disassembly. Hope this helps!
Jun 25, 2008 | Computers & Internet
Hope that helps =)
Apr 08, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Relisys tl 766 monitor
ok i think i know how to get rid of it now, i did an ATX reset on it and it does go away HOWEVER as soon as you push the menu button again it comes back.
ATX Reset: unplug the main power lead then hold down the power button on the front of the monitor for about 10 seconds, plug the mains lead back in and then switch the monitor on.
Jan 15, 2008 | Relisys TL 766 Monitor
Main menu / positioning /
Sounds like a button is sticking. Does it seem too sensitive? It should give a little resistance when pressed and have about 0.1" of travel. Try gently prying outward on the offending button with a pin or needle. If you're comfortable taking the monitor apart, do so and check the alignment of the menu buttons.
Oct 03, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
Dell UltraSharp 1907FP 19" LCD Monitor Logo
1,917 people viewed this question
Alun Cox
