The printing is full of toner
The printer is printing text as a background and on top of this is a lot of toner,first page clean,second dirty and third one full of toner
  • BadCopier Feb 18, 2009
    We have the Panasonic DP-C354 and the pages are printing fine but there are dark marks all over the page. I believe it is toner and is somehow being rolled onto the page because they are in lines across every page that prints.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Not sure if this is a printer or copier !!!!
Printer : replace the drum unit
Copier, ( need model) it may be the waste toner system or the drum blade a
Posted on Nov 25, 2008
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
I have a HP LaserJet 5P. This has been a great printer with excellent print quality. Recently I printed a file that had a lot of dark background. Since then the printer output has a spattered black...
Geez, a real oldie.
If you pull down the back door, I think that you can see the fuser.
It's been a long time, but let's see how this goes. The back of the fuser, I think pulls down.
If it does, look at the rollers inside. There are two of them. Do they look dirty or torn?
If yes, you need a fuser.
Run a 1/2 print test. Send a print job to the printer. It has to be about 4 pages. Use the manual feed tray, so that you can watch. When the sheet of paper gets 3/4 of the way in, open the top cover. Pull out the toner and look down at the paper. Does it have the black splatter?
If yes, replace the toner cartridge. If no, replace the fuser.
Jan 15, 2011 | HP Office Equipment & Supplies
There is a faint background shadow covering the
remove toner/drum unit from the printer. remove toner from drum unit and shake toner cart. side-side to loosen toner inside. On top front of the drum unit there is a purple/blue button that will slide right-left. Do this a few times to clean the wire. If there's a lot of loose toner, take a vacuum and clean carefully. Put everything back inside. With front door still open, hold GO/Control button down until all lights have lit, then let go, close front cover.
If you still have the shadow over the page, it's most likely the toner cart and you need to buy a new one (or recond.-refill) at someplace like Office Depot or Staples.
Jan 20, 2010 | Brother HL-2040 Laser Printer
Gray background
if you have a laser printer you may need to clean the printer or install a new drum cartridge, if it is ink-jet you will have to clean the bottom of the ink cradle it sound like you getting grey background from a toner/drum cartridge.
good Luck
Let em know if this helps.
Jan 29, 2009 | HP LaserJet 1200 Printer
HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Nov 28, 2008 | HP LaserJet 1100 Printer
Gray background where printo on glossy paper 130g/m2
hello
this sounds like a bad black ink cart, or the fuser rolls built into the printer are dirty.
you can swap out a black cart to test that theory, you can also just print a single blank page (no text or graphics) onto a piece of glossy paper and see if there is anything there after its gone thru the printer.
if the piece of paper has stuff on it it had to come from the rollers inside the printer.
service required,unless your comfortable changing out parts in your printer.
norm
Nov 06, 2008 | HP Color LaserJet 2600n Printer
Gestetner DSc224 starts to print black strips inside colorpages
the printer in the service program has a option for the printer to do a process control on selected number of copies that number for your machine should be lower because you print about 150 duplex pages an that is 300 single pages so go in the service menu and set the process control on some 30 pages to be done .
Follow the next procedure:
- For to enter the service mode:
1. Press the clear modes key(the yellow key)
2. Type “107” at the numeric keypad.
3. Press the clear/stop key(red key)
and hold it down until the screen
display changes (for about 3 seconds).
4. Touch “Copy Sp” on the touch screen.
In the upper right corner on the touch screen has a key named [Sp Direct],touch that key and enter with the numeric key pad the numbers:3003 and on he screen will appear [Lubricant Interval] set the interval on 30 pages and press the "#" key for to confirm the value. After that for to return to normal mode press the exit key on the touch screen several times.
Also do the [maintenance -clean/adjust] option once after 1000 or 500 pages printed. Because this is a office machine and when you print on her a lot of pages per day the machine start to get dirty.
PLEASE RATE ME IF THIS HELPS
Aug 09, 2008 | Gestetner DSc224 Copier
Different looking text, but only in certain areas of the page.
Samsung CLP-300 color laser leaves 3-4 lines of various shades of black in middle of paper. Otherwise everything is great.
Posssible black toner cartridge problem?
Jan 30, 2008 | Samsung CLP 300 Laser Printer
Laser Printer Cleaning
Does the dirty background get lighter as you print additional pages? Have you tried a new cartridge yet? Unless your toner cartridge is leaking toner (you?ll see toner on the inside of the printer or leaking out if you remove the cartridge and shake) a simple cleaning is probably not the answer. Let me know and we'll pick up later.
Feb 28, 2007 | HP LaserJet 4100n Printer
59 people viewed this question
k24674
jasbo
jasbo
