Question about LeapFrog Leapster Electronic Book: Spider-Man (30425) for PC, Mac
Leapster not recognizing the pen??
I have an original Leapster and for some reason it is now not sensing or recognizing the pen. The games register and otherwise we are having no problems. Do you know why this happens and is there an easy fix?
  • 2 more comments
  • hovismktg Nov 28, 2008
    Thank you that worked great! Now if we can just figure out why, when using the pen it doesn't always recognize what you are writing...the writing games seem to be the worst.
  • mgunnell Jan 30, 2009
    i have a leapster 2.. the pen is not registering with the screen.
    help!
  • leapsterfix Jan 31, 2009
    Leapster interactive globe pen not being recognised when touched onto globe surface (not a battery problem) - no visible problem. What can I do to fix this please?
    Thanks
  • Anonymous Apr 21, 2009
    leapster 2 not recognizing the pen
    I tried the posted solution - it didn't work. Help!!! I have a very upset child!
Press the ? button and hold it while turning unit on.
Press the "a" button to select touch calibration
Press each + with the stylus
Restart machine
Posted on May 22, 2009
Try this - - - -
(1) Insert a cartridge, turn the unit on and wait for the sign-in screen to appear,
(2) Hold down the Home, Hint and B buttons simultaneously,
(3) When the screen changes, press the A button,
(4) Using the Stylus, touch the center of the targets.
Does it work now???
Posted on Nov 25, 2008
  • mommalyze Nov 28, 2010
    I am having the same problem. I used your advise and got the calibration screen - but no "targets" are showing. Can you help?
The pen wont work
hold down the question mark key, while still holding the question mark key turn on the leapster explorer. it will bring you to calibration screen, Calibrate and you should be ok
Aug 07, 2012 | LeapFrog Leapster Explorer Learning Game...
Leapster2 is 2 1/2 years old. Placed brand new batteries in Leapster2. Try to power it on, screen comes up like it is going to turn on, and it turns off.
Welcome to FixYa!
Ensure NO GAME is in unit
Power Unit off
While turning Leapster 2 on, hold down HINT KEY. (Key in middle with question mark on left hand side)
Once unit switches to other menu, Hit A to begin calibrating.
Follow prompts with Sylas pen to reprogram Stylus pen.
Once you are done it will return to original Calibrating Menu.
Power Unit off Turn unit on with game inserted. Stylus pen should respond.
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Do comment if it helped or not in any manner ill know.
Apr 15, 2011 | Leapster 2 Handheld Game
We have a Leapster 2 which the screen no longer registers when touched by the pen. Can this be fixed or replaced? i bought it only 2 months ago hope you can help Emma
I posted a solution to this problem a couple months ago. We have the Cars edition of the Leapster2. I'm guessing it was the same problem that we were having. When the pen touched the screen there was no response and the unit had barely been used. Try this!! I found it on www.ehow.com.
Callibration
  • If you touch your stylus pen to the screen of your Leapster2 and it does not respond, your unit needs to be calibrated. To do this, make sure no game cartridge is in the unit. Turn the unit on while you are holding down the "Hint" or "?" button. Keep holding the button down until the Leapster2 menu appears. You will need to turn off the unit and repeat these steps if you do not see the menu. When the menu comes onto the screen, press the "A" button and use the stylus pen to touch each of the crosshairs as they appear. When you are done, your unit should be properly calibrated.
    Read more: Best Way - Leapster 2 Troubleshooting ' eHow.com http://www.ehow.com/way_5868621_leapster-troubleshooting.html#ixzz0wVJdZzs5
  • Feb 02, 2011 | Leapster Learning System
    How can i get a new stylus for leapster 2
    If you need a replacement pen, with the cord attached, follow the instructions:
    Send $5.00 in check or money order (to cover shipping and handling charges) to
    LeapFrog Customer Service
    Leapster Replacement Stylus
    563 North Fairview Street
    Santa Ana, CA 92703
    Please note that this is supposed to be for pens that are lost or damaged ONLY.
    Mar 25, 2010 | LeapFrog LeapSter L-Max Console
    The touch pen doesn't work
    Answer
    I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
    If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
    5) Restart unit
    Nov 28, 2009 | LeapFrog LeapSter L-Max Console
    We have leapster two, we have power but the pen does not work
    1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
    Aug 06, 2009 | LeapFrog Leapster Learning Game System
    Pen not working on screen to use
    Hi, have you tried to recalibrate the screen as in your instructions?
    Make sure you have no game inserted
    Press and hold down the 'on' button and 'hint' button (with questionmark on it) at same time until a menu appears on screen
    Press A
    Now touch all the little crosses with your pen that appear on the screen
    switch leapster off and restart
    if still not working, repeat above
    Jun 15, 2009 | LeapFrog Leapster 2 Learning System
    Leapster pen or touch broken
    leapster 2 comes on but when you touch screen with pin wont do anything
    Apr 01, 2009 | Leapster Learning System
    Leapster
    I found this on an Ebay guide...
    "FIRST! The pen is not electronic AT ALL! If the screen does not seem to be working with your stylus pen (for instance, you click one part of the screen and it clicks a totally different part), you may need to calibrate the screen! Put a cartridge in, turn the system on, and when the sign in screen comes up, press the HOME, HINT, and B buttons at the same time. When the screen changes, press the A button. Follow the directions.
    Santa Ana, CA 92703
    Please note that this is supposed to be for pens that are lost or damaged ONLY."
    Sep 23, 2008 | LeapFrog Leapster Educational Game: Disney...
    LeapFrog Leapster Electronic Book: Spider-Man (30425) for PC, Mac Logo
    715 people viewed this question
    Top LeapFrog Computers & Internet Experts
    Alun Cox
    Michael Cummings
    Level 1 Expert
    k24674
    Are you a LeapFrog Computer and Internet Expert? Answer questions, earn points and help others
