Mobile home furnace with central air unit water coming out of fur
Hi there i recently bought a used mnobile home with a ac unit and everything thing works fine up until i return from deer hunting and my hall way floor is wet first i thought it was the pump. stop working and i checked the hoses everything is fine. thebn the furnace kicked in and then there was water coming out of the furnace and splattering all over. this is a newer furnace with no warrenty so now where do i go from here. do i have to call the ac guys or the furnace guys.there temp here right now is about 10 degree and the furnace is running but wet carpeting
  • 306 Answers
You had the condensate from the furnace come loose look for a pvc pipe coming off the furnace it drains the high efficiency heater. I would really check out your hot water heater too.
Posted on Nov 26, 2008
  • Ken Bledsoe Dec 17, 2008
    What was the problem? ken
Approx 45 mins after central heating comes on, what causes a reasonably loud vibration/expansion noise from the roof?
Hi, it may be that you have a blockage some where in the unit or piping . Best to get the whole unit checked out.
Apr 05, 2016 | Alpine AHDGAH056 56,000 BTU LOW-PROFILE...
Where is the filter on my Central Cooling Air Conditioner York LR49182C (Serial no. EFFS160427) (Model no. M/HD036SC) ?
Your furnace filter or A/C filter is located next to the floor in your cold air return into the furnace. Your other problem is your condensate line out of the A/C box that sits on top of your furnace is plugged. Replace your filter in the cold air duct, and remove your condensate line from the A/C box and blow air in the line to remove the clog in the line.
Jul 20, 2015 | Heating & Cooling
Comfortmaker PAT 336K00A1
Cliff, this is Teng. Look inside your furnace if there is any flashing code. If your furnace is recently installed it should have electronic control board.
Nov 10, 2013 | Comfortmaker 7.5 Ton Heat Pump W...
My AC unit wont blow the cold air.
if the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
Jul 09, 2009 | Fedders A&B Chassis A1A07W2B Air...
AC unit turns on blower doesn't come on
The thermostat is the controller.
Jun 19, 2009 | Heating & Cooling
I have an old 1985-86 coleman central heat and air need manual
The filter is located before the blower if your Coleman is in a mobile home it will be in the door facing. If it is a standard ac/heat application and a regular residential furnace the blower in the cabinet on down flow (ducts in floor) will be above it and possible in the duct connecting in the top. If its the other way (ducts in ceiling) it could be right under the blower. Either of these could have a filter cabinet on the furnace or could have a filter grille at the end of the return air duct (where the air is sucked in).
Mar 10, 2009 | Coleman Heating & Cooling
Ductless minisplit in old mobile home
ductless mini split units are a very good choice!  they are obviously quieter, more efficient and easier to maintain than window units. the downside is the initial expense of buying the unit, but this is paid back in eletric savings and peace of mind. Good luck Peyton
Mar 07, 2009 | Soleus KFR12GWD 12,000 BTU Heat & Cool...
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
WE live in ND and have an Amana furnace that is 30 years old. We also have a Central air unt. OUr central air unit started coming on today when our furnace kicks on. Can you tell me why, it was 24 deegrees...
That would only really happen due to one of two things.
A bad thermostat.
A stuck relay. If the relay to the AC is stuck closed then it would come on whenever power goes through to the furnace.
This would be rare because very few units had that type of setup.
You can verify the T-stat by removinf the tsat from the wall. disconnect the red, white and yellow wires. Touch red to white.
If the heat comes on and the AC stays off, then your Tsat is bad.
Jan 17, 2009 | Heating & Cooling
Heating & Cooling Logo
175 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
