Question about Canon Pixma MP450 All-In-One InkJet Printer
Printer message ''paper is jammed''. there is no paper jam
Whether trying to print a document or trying to scan a document, the paper goes through the printer but the printer does not print on the paper. After the paper goes through a message appears "the paper is jammed. Clear the paper and press.
Any suggestions?
  • dk_doc Nov 25, 2008
    I turned off the printer and unplugged it. On the first try it succesfully made a copy. Then I tried to print a doc from the computer and it didn't work. Belt is good, powering down didn't help and I need to find the printer software to reinstall it. Will work on it when I have time.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A couple of ideas to explore, check or respond to:
  • there was an earlier jam and bits of paper got **** between rollers;
  • unusually cold weather, the paper are damp or cold and slightly sticky to each other;
  • paper in supply tray not properly aligned/stack;
  • too much paper in stack;
  • if your model has an alternative tray, pls try there;
  • pls determine if there are any unusual noises when paper is loading or during the printing;
  • any marks, indentation, crease or fold on the printed paper when ejected?
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 25, 2008
  • 3,037 Answers
The paper feed sensor is most likely in the 'Engaged' position, which tells the printer that a piece of paper is being fed through the machine. You should open the machine and check this out. quite possibly something else such as a wire is blocking if from going back to the normal position and not paper. I would also try the shaking it upside down first, unplug it and plug it back in and see if anything falls out that might have gotten in there accidentally and unplugging it is another way to reset the machine. Let me know what you find when doing this and if you have any questions, just feel free to post them here
good luck
  • 162 Answers
Isolate the printer. Disconnect it from the computer. Do a printhead cleaning. Replace ink cartridge.
  • Canon Master
  • 1,879 Answers
It goes to the motion of printing but no ink is transferred to the paper.
Verify it first by performing a copy.
Same thing ? Re-seat the ink cartridge then perform print head cleaning.
    Genius:
  • 3,422 Answers
HI,
1. Blow it out with canned air. make sure there are no bits of paper or dust in the paper feed area and in the front access area that could be causing the jam.
2. Verify that the cartridge carriage moves to the service area when the front door is opened (as if to change tanks)
3. Verify that the timing belt, drive belt, gearing and rollers all look normal.
4. Take the network out of play when doing the initial troubleshooting
5. With the computer off, unplug the printer's power cord and USB cord for about 3-5 min
6. Completely uninstall the printer's driver and software. Then reinstall the printer's drivers only.
Retry after each step.
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
How do I override a paper jam error message?
Dear
I am a bit of confused about paper jam but you are able to print but facing difficulties in scanning. I think the document jam is there. Pl. check the ADF (automatic document feeder) a small piece of paper or any foreign mater may obstruct or jammed at the sensor. clearing this may help you.
Thanks.
Feb 25, 2015 | Brother DCP 8085DN
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
My Canon MP530 indicates that I have a paper jam. There is no paper jam - I have checked and re-checked and turned it off and on several times and it is still reading that there is a paper jam. How do I...
Hello there You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 25, 2010 | Canon PIXMA MP530 All-In-One InkJet...
The printer is constantly sending a message- 'paper jam'
HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
Issue
During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
Solution
Use the following instructions to clear a paper jam from the product:
Step one: Check for and remove any loose paper from the In tray
Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
Step two: Clear the jam from the back of the printer
Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
Remove the rear access door to clear the paper jam
1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
Figure 1: Removing the rear access door
Rear access door
2. Gently pull the jammed paper out of the rollers.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
Remove the two-sided printing accessory to clear the paper jam
1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
Figure 2: Removing the two-sided printing accessory
2. Gently remove any jammed paper.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
3. Press the button on top of the two-sided printing accessory to open the door.
Figure 3: Opening the two-sided printing accessory door
4. Gently pull the jammed paper out of the rollers.
5. Close the accessory door.
6. Reinstall the two-sided printing accessory.
Step three: Clear the jam from the automatic document feeder (ADF)
1. Remove the document feeder tray from the product by gently pulling it.
2. Lift the cover of the automatic document feeder by pulling it outward.
Figure 4: Lifting the cover of the automatic document feeder
Automatic document feeder (ADF) door
3. Gently pull the jammed paper out of the rollers.
WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
Step four: Verify that the print carriage can move freely
Follow these steps to try to move the print carriage.
CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6. Press the On button to turn on the product.
Step five: Reload and test the printer
After you have removed the jammed paper, make sure the product is still functioning properly.
1. Reload the product with plain paper.
2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
Step six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 30, 2009 | HP DeskJet 3745 Printer
Hp j4680 says "paper jam"
Try this. Sometimes you get that message because a previous jam was never fully fixed.
Sep 29, 2009 | HP J4680 Office Jet All-In-One Printer
Canon Pixma mx300 printer has paper jam message.
Canon Pixma MX300
- new cartrige for Black ink
- can scan
- can photocopy documents
BUT can't print documents from my MacBook eventhough the paper feeds and goes out at the other side
Aug 10, 2009 | Canon PIXMA MX300 All-in-One Printer
The paper is stuck while printing and the message is clear the paper jam
when it stuck, just click start menu below, under settings and printers and faxes. Then find the printer and double click and cancel all documents clear. So after doing it restart again your pc and try print another document.
May 09, 2009 | Office Equipment & Supplies
Media jam fuser
I turned the printer off, took the power cable out, and turned the printer on. After 60 seconds I turned the printer off, put the power cable back in and turned the printer again on. This is a solution in order to loose all the voltage/current build up in the printer. Whether this is the solution or just coincidental, I don't know. The printer worked well after that.
Mar 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Canon Pixma MP450 All-In-One InkJet Printer Logo
14 people viewed this question
old marine
old marine
