Question about SanDisk Sansa View 8GB MP3 Player - Black
Sansa View shuts off without warning
My Sansa View 8GB has started shutting down automatically after only an hour of play, even with a full battery. I thought at first it had something to do with the cold weather, but it occurs indoors as well. Updating the firmware appears to cut down on the number of automatic shutdowns, but does not eliminate the problem.
Additionally, it is prone to lockups.
I've had the same problem but it wasn't with the battery, when it kept shutting itself down it was due to static electricty. Every time i took of my jacket and had my headphones on, I would hear a small click and then my sansa woud be turned off. I just kept it away from things that might cause some sort of electircal interference. I'm also not sure what kind of screen apperas on this lockup or shutdown but the screen goes black for me while the blue ring stays lit, and everything is discfunctional. I have to reset it each time.
Posted on Feb 08, 2009
  • 758 Answers
I am sorry to hear that..it sounds like your battery is defective..Unfortunately the only way you can get the problem fix is to contact sandisk so they can replace the battery for you...There isnt any shop out there that will be able to replace the battery for you..I hope that helps.
Please rate accordingly
Thank you
Computerrep
Posted on Nov 25, 2008
My ps4 is shutting down automatically after playing for 5/10 minutes. What to do?
it looks like it is heating up. heat fan replacement can solve the problem.
Mar 01, 2015 | Computers & Internet
My Toshiba P35-S611 shuts down without warning a short time (2 min-45 min) after it boots up. The battery isn't hot but the heat dissipation fins in the back are very hot.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 09, 2010 | Toshiba Satellite P35-S611 Notebook
My sansa wouldn't recharge - thought the battery was dead - replaced it - it worked for a couple of hours, then was dead again and wouldn't take a charge. Think it's fixable?
slide the switch in the on position and hold for 20 seconds , release and then flick the switch to on position and it should start.
This will happen anytime the battery runs down.
Apr 09, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Sansa View doesn't start up
why doesnt screen dont work on these when i start up it turns in a faded screen then it starts again
Jan 09, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Can you please help me, don't know what to do =(
Yes! That is, if you are certain that the device has no malware or virus on it! Shut the computer down completely (power off). Then connect your device and reboot the computer. It should then recognize your device.
Apr 24, 2017 | SanDisk Sansa View 8GB MP3 Player - Black
Sansa view
if you did not charged it properly you could of just messed it up so just call the company they should fix it for free
Jun 17, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Sandisk Sansa View 8GB = would not connect
I jsut purchased an 8GB sansa view mp3 and I downloaded it like I was suppose to and it does not work in Rhapsody at all, also in the windows media player it shows that the device was installed correctly but it still doesn't work and I still can't sync my songs to it. The sansa icon won't even show up
Dec 26, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
SanDisk Sansa View 8GB MP3 Player - Black Logo
119 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
