Question about KitchenAid 24 in. KUDP02CR Built-in Dishwasher
KitchenAid KUDP02 built-in dishwasher will not fill with water
I have a KitchenAid KUDP02 built-in dishwasher that will not fill with water. I checked the overfill protection float and it freely moves. I have water pressure and no kink in the line. Worked fine for 1 1/2 years. Help!!!
  • magic007 Nov 26, 2008
    we have the same problem. the 'start' button comes on and then keeps blinking and that's it -- no water. pls help!
  • kjf1950 Feb 11, 2009
    My KUDP02FR won't pump in the water at start of a Normal or any cycle. It makes a low humm, then eventually goes to Heat Dry. In Dec I contacted FixYa about a loud was suggested that I replace the seal by installing the Impellar Kit. Then the noises stopped and the washer seemed to be working "normally", so I didn't do anything. Then last night this happened. This morning I tried different cycles....and nothing. No water pumps........and yes, the water is on. Is it the pump?
    Problem Solver:
  • 9 Answers
Couple of things that come to mind here... May be helpful or not - but after all this is free ifo and probably worth what you are paying!!!
1: Have you tried removing power from the appliance?? All these modern appliances use a microprocessor and - like MS WINDOWS - need a kick up the bum now and then - (Well.. with Windows it seems to be every day- hour -minute - or so)
2: Dishwashers are installed with water reduction valves, so there could be a problem with one of there (particularly the hot water side).
3: The water inlet is controlled by soleniod valves (read: electronic valves). If the valves are not opening, no water will enter the appliance, so there could be a problem with the valves.
Posted on Jan 16, 2009
KUDS01FLSS0 Dishwasher - tub slwoly filling with
Slow fill of water is due to the strainer clogging. Strainer is located on the body of the machine where the inlet water hose is connected.
Clean all the water flow tubes in the machine.Clean the solenoid valve opening also.
May 26, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
No water is coming in to dishwasher. Kitchenaid kudk031twho
measure the voltage to the water fill valve. it should be about 120 volts in fill mode. if it is, then the inlet screen may be plugged. turn off water and disconnect pipe. examine and or clean screen. if screen is clean (some may not have one) and it has 120 volts applied to it then you need to replace the fill valve.
Oct 27, 2009 | KitchenAid 24 in. KUDI01FL - Multiple...
Dishwasher overflows when running and when not running still fills without draining
Check the water fill valve - sounds like it's stuck open. Turn the power to the machine off. If water continues to fill into the machine it's the water fill valve. If so...
Take the front lower cover off and look for the valve - it will have a water line going to it. This could also be caused by a bad control board, but look at the water valve first.
May 17, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Will fill bottom then hums
Check to see if something is caught in pump or in bottom of dishwasher stopping the arm.
Mar 12, 2009 | KitchenAid 24 in. KUDI01TJ - Multiple...
How to unclog KUDp02 dishwasher
Are you still having problems with your dishwasher? Please post if you are.
To get to the chopper area and to the area you really need to get to, remove the lower spray arm and then one screw the holds down the filter/sump assembly. Look closely for debris and remove.
Check all spray arm whole for blockage.
Rememeber to only use a brand name DW detergent powder (like Electrosol or Cascade), not a generic, ultra-cheap powder or any gel/tablet. You will be amazed how much better it the brand name powder works!
Golld Luck. Please update me with what you find. OK?
Feb 20, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
KitchenAid dishwasher overflowing; water will not stop coming in
If it is filling when the dishwasher is off then you need a new water valve.
Jan 13, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchen Aid dishwasher does not fill up with water.
yes, the problem is usually dirt in the valve or the water valve under the sink .
Nov 09, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Upper rack dishes dirty
Is it filling with enough water. Look or if you don't know how much water is supposed to be there , Just add a gallon of hot water to the machine after it fills. If this solves the problem check the filter in the fill valve or replace the valve.
Jul 04, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Kitchenaid dishwasher
Motor bad. If you are getting power to the motor then the motor is bad.
Mar 31, 2008 | KitchenAid 24 in. KUDS25 Built-in...
KitchenAid 24 in. KUDP02CR Built-in Dishwasher Logo
391 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
