Question about Sony Handycam DCR-TRV27 Mini DV Digital Camcorder
Error code My camcorder is constantly flashing the error code C:31:22. The only help I can find is to remove the battery for 60 seconds and then try again. Each time I go into FastForward, 5 seconds later the camcorder displays the error message. Is there anything else that can be done to remedy this situation?
  • 2 more comments
  • Anonymous May 08, 2008
    Same problem. Screen flashes C:31:22 with a yellow flashing symbol of a arrow up.
  • td_qb Jul 12, 2008
    Yes - me too - Same problem. Screen flashes C:31:22 with a yellow flashing symbol of a arrow up. Bought some new JVC mini dv tapes from BB and when I started using them I started getting this error. Thought it was the tape at 1st but tried another new one and then an old one (known good) and I still get the error.
  • horizo_d Jul 20, 2008
    HI
    Same here, I like the camera, but I hope this is not a major problem..any information to resolve this would be appreciated
    dc
  • Anonymous Oct 29, 2008
    My camcorder has the same problem (no VCR/ Camera Mode  working), with the error code c:31:23 with the yellow flashing arrow icon.  Nothing seems to be working to fix the problem.
I had the same problem with my sony dcr-trv310 8mm digital handycam. Out of nowhere, it started beeping and flashing an error code C something with a blinking up arrow. I found a very crude, but effective fix: just hit the bottom of the camcorder pretty hard a few times with an open palm. I found this fix on a different website and thought I'd share it. I thought my camcorder was dead, but just giving it a few good slaps/palm strikes brought it right back to life. Pretty strange and probably less than ideal, but it worked for me. ;-)
Posted on Mar 10, 2009
Me too, but i guess no one has a solution
Posted on Oct 29, 2008
SOURCE:
Canon charge light blinks 7 times
If your Sony camcorder displays a tape transport or mechanical error code always try resetting the camcorder. This is done by removing the battery or ac power, wait 10 seconds, reapply the battery or ac power and try again. If it still goes into error try another tape. The camcorder will not always display an exact error code. Sometimes you may see an error message such as, "Reinsert the cassette", on the LCD screen. This is the camcorders way of saying, "Take the tape out and try again." Try reloading the same tape as well as a new tape. If the camcorder is still going into error this means it is time to send it in for service or repair.
The camcorder may also sometimes display a "Reattach Power Source." This is the camcorders way of saying,"Try resetting my system,so I can try again." Many people mistaken this error and think they have a problem with the battery or ac adapter. This is not true and has nothing to do with your battery or ac adapter. Reset the camcorder by removing the battery or ac power, wait 10 second, reapply the battery or ac power. If the error reappears the unit needs to be serviced or repaired.
Jan 23, 2013 | Canon VIXIA Video Cameras
URGENT NEED HELP WITH C:31:23 CODE ON DISPLAY SCREEN
Try first removing the battery and see if this clears the error.
Aug 24, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Video Camcorder Error Message
Per SONY; To service the C:31 code, Sony recommends you do the following: Turn off the camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter. Turn on the camcorder. If the error message appears, service may be required.
Sep 15, 2007 | Sony Handycam CCD-TRV608 Camcorder
Error code C:31.23
Sony is pretty secretive about the :23 code. It can't be found anywhere. However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Feb 10, 2011 | Sony Handycam DCR-TRV145 Digital Camcorder
Error C:04:00
Shamelessly copy pasted from another forum.
Jul 29, 2010 | Sony Handycam DCR-SR40 Camcorder
Sony DCR-TRV17 - In the middle of filming, a flashing yellow square with a yellow light bulb inside the square appears wiht chimes. upper right hand corner is flashing C:21:00. I turned off recorder and...
May 31, 2010 | Sony Handycam DCR-TRV17 Mini DV Digital...
Keeps flashing c31-42 and shuts down
If you still get the error message you need to contact sony service center to get it repaired .
Hope it helps.
Jan 23, 2010 | Sony Handycam DCR-TR7000 Digital Camcorder
C:31:23 code with flashing icon for eject,with a beeping sound
The error message indicates that the Camcorder has detected an issue that may require a power reset.
Step 1:
Try to reset the Camcorder and check if it helps to resolve the issue. Locate the RESET button behind the LCD screen of the Camcorder.
Step 2:
Turn off the Camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter.
Step 3: If still unresolved Service may requires.
Jul 17, 2009 | Sony Handycam CCD-TRV318 Camcorder
When tape inserted "C:31.23" flashes
Mar 24, 2009 | Sony Handycam DCR-TRV510 Digital Camcorder
Error code c:31:23
Sep 23, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony Handycam DCR-TRV27 Mini DV Digital Camcorder Logo
246 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
