Question about Dishwashers
Blinking Clean Light on model DU1055XTPQ3
I see there are several troubleshooting avenues for this problem... please let me know which sequence we need to do first! Thanksgiving is in a couple of days and we would like to have it fixed before anymore dishes!!!! Thank you! We purchased the unit in 2005/06... would the heating element/problem still be under warranty???? Once again! Thank you!
    Sergeant:
    Champion:
  • 338 Answers
Heating element should still be covered under whats called a service flash. do your heated dry button and the high temp wash buttons back and forth this should get the dishwasher back in working order but may only be temporary
Posted on Dec 01, 2008
Clean light keeps flashing and dishwasher won't start.
If this is a Whirlpool manufactured dishwasher, the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it is commonly attributed to the heating cycle or thermostat problem. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel.
If you still need assistance, please post back with your MODEL NUMBER and let me know
Apr 26, 2011 | Whirlpool Dishwashers
THE CLEAN LED LIGHT FLASHES 7 TIMES IN CONCESSION AND DOESN'T START
On Whirlpool manufactured dishwashers, the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it's usually attributed to the heating cycle or thermostat failure. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
If you still need assistance, please post back with your MODEL NUMBER and let me know.
Apr 18, 2011 | Kenmore Dishwashers
Kenmore dishwasher model #665.17034401 --- Clean light blinks
The blinking clean light is an interruption in the dishwasher program that indicates a component malfunction, or it can be a result of a momentary program glitch. If a component is defective, it's usually attributed to the heating cycle or thermostat failure. The following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel. Let me know if you still need assistance.
May 07, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Clean lgiht on door is blinking won't start washing
The blinking clean light is an interruption in the dishwasher program that either indicates a component malfunction, or a program glitch. The following link explains how you may be able to clear the blinking clean light problem:
I hope this helps you solve your problem.
Jan 12, 2010 | Dishwashers
The clean light is blinking, and the cycle won't
The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or a simple program glitch. The following link explains how you may be able to clear the blinking clean light problem:
Jan 06, 2010 | Dishwashers
My whirlpool dishwasher "clean" light is blinking. No any buttoms are functional except the "drain" buttom. what is the problem. What parts I need to change? I have disassembled the front panel. It seems...
Before you do anything, please read:
The blinking clean light is an interruption in the dishwasher program that either indicates a component malfunction, or it can be a simple program glitch. The following link explains how you may be able to clear the blinking clean light problem:
Now, keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
If you have any questions, please let me know. I hope this helps you solve your problem.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. The tech sheet will explain. If the tech sheet is not behind the lower toe panel, check along the frame underneath. I have also found them located inside the inner door panel. Let me know if you still need assistance.
Dec 17, 2009 | Washing Machines
The clean light is flashing seven times on our kitchenaid dishwasher model KUDS01DL and it wont wash the dishes
The blinking clean light is an interruption in the dishwasher program that either indicates a component malfunction, or it can be a simple glitch. The following link explains how you may be able to clear the blinking clean light problem:
Blinking 7 times is usually a thermister related problem. However, I have often found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, or affixed somewhere under the dishwasher, I have also found them located inside the inner door panel. Let me know if you still need assistance.
Dec 15, 2009 | Washing Machines
The "clean" light keeps blinking. It will not allow me to start another cycle or to cancel/drain.
The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or it can be a simple glitch. The following link explains how you may be able to clear the blinking clean light problem:
Dec 09, 2009 | Microwave Ovens
Clean light blinking a 7 code for a kitchen aid dishwasher model KUDM01TJWH. What is the sequence to clear, what are the blink code explanations?
Dec 08, 2009 | Dishwashers
Model # DU1055XTPQ3 WHIRPOOL DISHWASHER RESET CODE
chris72 had the solution to my Whirlpool DU1055XTPQ3 not turning on. Per Chris's suggestion, I pressed back and forth between sani rinse and heated dry. All the lights came on as it reset and it was good to go. The dishwasher started up immediately. Saved me a service call, THANK YOU Chris!!
Aug 07, 2008 | Whirlpool 24 in. DU920PW Built-In...
Dishwashers Logo
134 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
