Intertherm P3RA-048K Air Conditioner Logo
Posted on Nov 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Heater blows cold air
I will turn it on and it blows cold air everything seems to be working but the heat. I have no heat blows great an everything but no heat.
Anonymous
Level 1:
  • Contributor 67 Answers
  • Posted on Jan 07, 2009
Anonymous
Contributor
Level 1:
Answers
67
Questions
5
Helped
81430
Points
48
Anonymous
Level 2:
  • Expert 70 Answers
  • Posted on Jan 04, 2009
Anonymous
Expert
Level 2:
Answers
70
Questions
0
Helped
31588
Points
121
Is this a gas furnace if so does the burner ignite
1helpful
2answers
I have a ceramic heater fan model PCH1033-RC from prem I air and I can't make it blow cold
...."I own one just like this and it is true at the beginning I did not know how to make the cold air work but once I play with the buttons everything worked fine. You have to press mode twice then press the minus button until the air gets cold. The instruction are not clear but the item is great, I used it year round." Prem air PCH1033 RC 1 8kw Ceramic Tower with Remote
The heater in my excel blows cold air only . The dimist still works just no heat what should i look for?
There are several things that you can do about a heater blowing cold air, but if you keep running into problems then it might just be time to call in a heating repair company. If need be, here is a useful article on: HVAC installation cost, and how to get a fair price. How serious of an issue this is depends greatly on where you live. If you live in the north (Bozeman, MT, etc), then I'd recommend you have your furnace inspected annually to ensure that it is working properly. I'd also recommend that you install a backup means of heat...just in case. ASM has over 25 years of heating and air conditioning experience. If you have questions about a heater blowing cold air or any other HVAC related topic, try the ASM Air Conditioning and Heating Blog or if something your contractor is telling you seems expensive or doesn't sound quite right, consider using our Online Air Conditioning Consultation Service.
2answers
Blows cold air turn heat on
Search Results
    07 Tucson heater blowing cold air - Hyundai Forum - Hyundai ...
    www.hyundaiforum.com > ... > Vehicle Line Up > Hyundai Tucson
    Dec 16, 2009 - I have a 2007 Tucson, when you turn on the heater it only blows hot air... Join Date: May 2005 ... a low coolant level will exhibit the first stated symptoms of no heat/low heat at idle and increased heat at cruise due to an air ...
    Denlors Auto Blog » Blog Archive » Car Heater Blows Cold ...
    www.denlorstools.com/autoblog/.../car-heater-blows-cold-auto-service-ti...
    Oct 10, 2009 - When a car heater blows cold air, there are several possibilities that should ...... On my Dodge Neon when I turn on the heat it blows out cold air.
    Heater blows only cool air...even w/ defroster on : Buick ...
    repairpal.com > Problems > Buick > LeSabre
    ... Cadillac, Chevrolet, Chrysler, Dodge, FIAT, Ford, Geo, GMC, Honda, Hummer,Hyundai, Infiniti, Isuzu, Jaguar ... I'll turn up the temp on the dual control to get heat,
2answers
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
2answers
2002 Ford Taurus, Heater blows cold air?
What have you checked so far ?
Radiator full of coolant ? Heater hoses getting hot ?
Heatdoesn't work, A/C blows out warm air and defrosts blow out cold air
Right think the problem is the heater core is blocked with corrosion ,now remove the bottom hose from the rad and the heater hoses then flush every which way you can including through the heater core reversing direction then ,refit all the hoses fill with water only and see if heater works if so the remove the bottom hose again and drain ,then add a minium of 3 litres of antifreeze ,its a anti corrosion agent as well as antifreeze and without it the internal of the engine will corrode and the slurry will block the heater first then the radiator ,
94 thunderbird heat or cold air doesnt blow
if you saying the fan wont blow it may need a fan motor not uncommon it might be a speed switch if it has one some time you can hook a wire on the back of the speed switch plug in to get it on high use a 14 gauge wire or bigger a small jumper bent in a loop with the rubber peeled off the ends and shove them in the switch plug find the 12 volt ht wire on the plug with light or vom then try the other wires one at a time til fan runs with ignition switch on
1helpful
Air works great but no heat just blows cold air
For this types of problem,i suggest you to check this help links:----Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
---------A/C, heater, defroster fan, not working?http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
--------Heater problem?http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
---------Engine Overheats and heater blowing cold?http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
-----------Heat blows cold on drivers side and hot on passenger side?http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html----------------This will help.Thanks.
2answers
2000 Jimmy Blows Cold Air from Heat
check radiator you may have a pin hole
Top Intertherm Heating & Cooling Experts
john h
Paul Carew
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
