Question about Dell C600 (002UH) Motherboard
C600 DEATH When i turn on the computer usind the ac power or the battery the green light starts for one or twe seconds and than turns off. I replaced the motherboard but i still got the same problem, i removed the hard drive, the memmory, the processor, everything from the motherboard and it still with the same problem what can i do? How can i know if the problem is with the motherboard or with some other component? Thanks a lot F?bio
I am guessing this issue is similar to something I noticed only recently when tampering with an old C600. The LED is the power on LED and with it is the HDD LED. They stay on for a few seconds then nothing. I believe the laptop has had the Fn+Esc keys simultaneously pressed and the Laptop is now suspended. I dont know how to fix it and no matter what I do the laptop will not power up. I have been told that it may be useful to remove the battery for a while and let the charge storage devices dissipate so resetting the BIOS or better still get the BIOS battery out which resets the BIOS to a default mode. Haven't tried it yet though, however the motherboard and BIOS is encased in riveted steel Faraday cage! Brilliant!
Posted on Aug 20, 2007
  • 624 Answers
Hi Jack, When you say green light are you referring to the battery led? If yes it might be your A/C adaptor causing the problem. I've had laptops flash the battery like it was going to charge then stop. If the A/C isn't supplying power and the battery is dead you could see your symptoms. If its not the A/C adaptor more information would help a diagnosis. What were the circumstances that lead to this, exactly what lead died and so on. Let us know if we can help further and don't forget to rate the posting.
Posted on Jan 04, 2007
SOURCE:
Suddenly died with blue screen of death. will not turn on again. when I press power button, it lights up and battery light lights up also. as soon as I take finger off the button, nothing. tried...
No guarantee but you can try this. Remove the battery and unplug the AC adapter. Hold down power button for 30 seconds. Plug in AC adapter but leave battery out. Try to restart computer. If it starts, reinstall battery. It worked on a Gateway I was working on last week. Worth a try.
Aug 27, 2010 | Dell Vostro 1500 Notebook
Used my 6910 with battery power. It evetually dies. When I got home I plugged it in and it won't turn on. Took the battery out and it still won't turn on. Get green lighting bolt but won't power up. Help
Disconnect the AC adaptor and remove the battery pack from the computer, then press and hold the power button for 30 seconds.
Second, remove the RAM module, clean the slots then reseat it.
Now, turn on the Computer by connecting the AC adaptor and with the battery out of the Computer.
Nov 20, 2009 | HP Compaq 6910p Notebook PC PC Notebook
Power light shuts off after only 3 seconds
Disconnect the AC adaptor from the laptop and remove the Battery pack from the Battery bay. Then, remove the RAM module and reinstall it after cleaning the RAM slot. Next, connect the AC adaptor to the laptop then try turning it ON. Please make sure that the AC adaptor is connected to a functional wall outlet. If the laptop still doesn't turn ON then you may try cleaning the Battery bay and the metal contacts in the battery compartment then insert the battery and try turning ON the laptop. If the laptop still doesn't turn ON then the issue is with the power supply unit.
Sep 04, 2009 | Dell Latitude D600 Notebook
My charge light constantly flashes orange and my C600 won't turn on at all. I hold the power button and all the lights turn off. I got nothing. Just a blankscreen.
When you say charge light, was that the battery led light that you were referring to or the power button?
If it is the battery led light, try this:
Try to power on your laptop without the battery in your laptop.
take out the battery and just use the ac adapter, if it works fine then there could be a problem with your battery.
If is the power button that is flashing orange, then try to power cycle laptop.
turn off laptop.
take out the battery and the ac adapter.
then while those are out, you hold down power button for atleast 10-15 seconds.
put back the power source and check the led again.
Apr 08, 2009 | Dell Latitude D600 Notebook
When I plug in my ac adapter into my computer to charge it the green light turns off and won't charge my computer
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective
good luck
Apr 05, 2009 | Dell Inspiron 6000 Notebook
Toshiba satellite A210 11-P crashes when i disconnect the power lead
From Toshiba, try step-charging the battery or Battery conditioning procedures:
Batteries don't last forever. All types of batteries gradually lose their ability to hold an electrical charge as they age. Eventually, the computer's battery charge indicator may show that the battery contains less than a full charge, even though the battery has just been fully charged. The computer will then not run for as long a time from the battery as when the battery was brand new.
You may prefer to simply replace the battery if this happens, but you may also wish to try 'step-charging' the existing battery per the following instructions.
This procedure should work for the battery in any Toshiba notebook. Follow it only when you find that the computer will run from the battery for just a short while.
Check the User's Guide for more specific information about charging the battery in your computer .
Procedure
Step-charging the computer's battery
  1. Unplug the AC adapter from the computer, and turn ithe computer on. Let the computer run from battery power until the computer turns off, indicating that the battery is fully discharged. Time this interval, but not with a software clock running on the same computer.
  2. Remove the battery pack from the computer.
  3. Unplug the AC adapter from the computer.
  4. Wait at least 30 seconds. The first time through this procedure, use a soft cloth to wipe the battery pack's contacts and the AC adapter's plug.
  5. Re-insert the battery pack.
  6. Plug into the AC adapter into the computer again and check the fit of its plug in the wall outlet, making sure the connection is secure.
  7. With the computer turned off, let the battery charge until the battery status light or icon glows green, or otherwise indicates a full charge.
  8. Unplug the AC adapter from the computer.
  9. Remove the battery.
  10. Wait at least 30 seconds, then re-insert the battery.
  11. Plug the AC adapter back into the computer.
  12. Let the battery charge again until the battery status light turns green or otherwise indicates a full charge, again.
Repeat this procedure, starting from step 1, at least three times. Each time, check to see if the computer runs longer from its battery than the previous time.
Battery Conditioning:
IMPORTANT!!
Interruptions in the charging cycle can be responsible for an issue called "memory effect" which may reduce the battery's charging capacity. Whenever you suspect the battery performance is not at it's optimum you should try using the following "Battery Conditioning" procedure.
Before you start: Turn off your battery saving features temporarily.
***IMPORTANT*** Repeat the following steps 2-3 times!
  1. Unplug the power cord from the computer
  2. Turn the computer on and let it run until it shuts itself off.
    Note: Using the CD-ROM to play an Audio CD will speed the discharge.
  3. Plug in the power cord (While the system is off) charge the battery until the battery light changes from flashing green to solid green
  4. Remove the battery for 30 seconds and then replace it.
    Note: If the battery light isn't lit, wait a few moments, if it still does not light check your power connections.
  5. Continue charging the battery until the battery light turns solid green once again.
    **REPEAT THIS PROCEDURE 3 TIMES**
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 04, 2008 | Computers & Internet
C600 not starting
Check memory and CPU first, typically they cause shut offs. Try battery, AC to laptop and AC via port replicator. Borrow one if need be, but it's good to check these options
Aug 26, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
My c600 is not puttin power in battery
if its the battery with a press button that lights up 5 green lights.. if u hold it for about 6 seconds it should light up all or some in a row like 000.. ( depends on charge it has) after 6 seconds none should flash , they should turn off . if any do flash or led green are missing in between its likely a bad battery.
Sep 29, 2007 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
Dell C600 (002UH) Motherboard Logo
114 people viewed this question
Clive
Clive
Alun Cox
