Question about Aprilaire 600 Humidifier
No water flow to the humififier
I checked to replace the water pad on my aprilaire model 110 humidifier today, lo and behold the water pad still looks brand new telling me that water wasn't flowing to add humidity. Water valve is open, there's power to the unit, i set the humity setting to 20 deg outside temp so water would flow, still nothing happened. I need your help to fix this problem. Thanks.
  • zucca1 Nov 25, 2008
    I have the same problem as edmac655 but with an Aprilaire 600 model and replaced the mineral covered filter recently. Ensured it's in Winter mode and set to 20 degrees. No water flow seen through plastic tubing and I've ensured water is turned "on" at water valve.
  • edmac655 Dec 19, 2008
    hello kman, i did exactly what you suggested. it's working good now. thank you very much, you have a merry christmas.
    God bless,
    edmac655
I've been working on the Aprilaire 110 unit today, after encountering the same problem. Here's how I fixed it: First, with the humidistat turned to 0%, I turned off the water supply saddle valve all the way (all the way to the right)--and then turned it back on all the way (all the way left). Still no water flow. Second, I slightly loosened the inline valve nut on the discharge side of the solenoid on the side of the 110 unit. Water began flowing, so I tightened it back up; and now the water flows freely. Conclusion: You may have some mineral deposit buildup in your lines, as I apparently did.
Posted on Dec 15, 2008
Coating from water panel pad clogging furnace filter
I know of no answer to this except to remove the coating manually to prevent it clogging you filter.
Jun 22, 2017 | Aprilaire 600 Humidifier
Aprilaire humidifier 110
Hello, typically solenoid valves should be replaced every 7 years and they are not very difficult to replace. Just need to shut off water at saddle valve, turn off power to humidifier, and remove mounting hardware. Here is a link to store which sells the solenoid needed for your humidifier. http://www.aprilairehumidifierparts.com/product.php?p=aprilaire_4005&product=111011&category=1686
Dec 18, 2012 | Aprilaire 700 Humidifier
Have an HE225A, B By-pass Flow thru humidifier about 9 yrs old. Just change the antimicrobial pad with recommended Aprilair 110/220 and when the furnace comes on, there is a loud, hum-like, vibrating noise...
Make sure the new pad you installed is in the right position. The pad is marked with a black dot about the size of a quarter. This end should be up for proper water flow through the pad.I fwater flow is being restricted at the pad the vibrating nosie that you are hearing is the dry portion of the pad vibrating agaist the platic housing of the humidifier. This noise stops once the pad has absorb enough water in this area of the pad.
Jan 23, 2011 | Honeywell HE220A1019 Whole House...
I just moved iinto my new home. I have never owned a home with aprilair 560 unit. I just got it fixed I hope. But I put a new water filter in monday the 27th. How often should you replace it. ...
It is a bypass humidifer the pad in it should last a couple of years, the water runs over the pad and air pulls moisture off the pad. Putting it into the home. Make sure the damper is open for proper air flow.
Dec 30, 2010 | Aprilaire 550 Humidifier
Should water be continualing running through the drain tube?
Water will flow over the filter pad as long as the unit is calling for humidity. once the unit is satisfied the solenoid valve should stop the water flow. if the water continues to flow with out call then solenoid valve has failed open. hope this helps.suppling an owners manual in case you need one.
http://www.aprilaire.com/themes/aa/en/manuals/AA-Humidifier-Owners.pdf
Dec 21, 2010 | Aprilaire 600 Humidifier
My Aprilaire new water pad has a white substance on it. I mentioned this because twice the pad (tworeleased a sticky, mucous substance that plugged the drain line and caused flooding in my basement. The...
Hello,All the pads have a protectant(white) coating because the pad is aluminum and would rot out fairly quickly from getting wet.The slime is bacteria(fungus) not from the coating that forms from stagnant (sitting) water.Make sure the unit is draining out dry after each cycle.With the pad out pour vinegar OR bleach & water (10:1) to kill the mold in the drain pipe.Do not clean the pad at all ,it gets replaced.They sell an inexpensive wet floor alarm at the store that makes noise when wet.
Oct 12, 2010 | Aprilaire 550 Humidifier
Solenoid on Aprilaire whole house humidifier
the solenoid allows water to flow to jet that then runs down the pad the solenoid is control by the stat
Feb 23, 2010 | Aprilaire 700 Humidifier
We have an Aprilaire humidifier model 110 that the water inlet valve no longer sends water into the humidifier. What can we do? Thankyou
Check the out put tube in the valve end ther is a plastic water flow fitting, it has just a pin hole opening, it is probably clogged.
Jan 25, 2010 | Humidifiers
Low or no humidity.
i have an aprilaire model 550 im getting no water to the filter but i am getting water to the solenoid
May 11, 2009 | Aprilaire 550 Humidifier
Aprilaire 110
Modle 110 has a relay in it see if it is stuck.Hope this helps
Nov 05, 2007 | Aprilaire 600 Humidifier
Aprilaire 600 Humidifier Logo
363 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
Mack Baxter
1STHVACMAN
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
