Question about Belling 24 in. IDW603 Built-in Dishwasher
Belling integrated dishwasher not working properly
My belling integrated dishwasher has all the lights on, but it will not let me switch off or go through the function buttons
Are you sure it is the board at fault, not justv the door catch? (as the door wont open). If the dishwasher believes it has just finished a cycle and the door has not yet been opened it will not let you change the program.
I had this same problem so I hooked an allen key around the back of the white door catch and pulled it into the unlocked position with a pair of pliers. Has worked fine since but every now and then the catch will pop back into the locked position when the door is opened.
Posted on Jan 14, 2009
I have a belling IDW604 integrated dishwasher which is not heating the water
An open element will have voltage present and still not operate. Use an ohm meter to test it.
Dec 21, 2015 | Belling Dishwashers
Dishwasher do not start up
Most likely the door is not shut properly or the door latch switch is faulty. I will assume the water is turned on and the power is connected. Also check the delay start is not programmed.
Sep 14, 2014 | Bosch SHX68P05UC - Integra 800 Series 24"...
The program selector is not functioning and the door will not close properly. are they related and how do i fix, tks
Hi.
If the door does not close properly, the door switch may not close contact to timer circuit, and the machine may not do the cycle for this reason. Additionally, a short in the door switch wiring harness may jam the control module.
Before checking control module have a look at the door switch and at the wiring harness inside the door.
Regards.
Ginko.
Mar 21, 2011 | Belling 24 in. IDW603 Built-in Dishwasher
Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
May 07, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
My belling dishwasher wont start, the lights are on but when I press programme the red light no longer skips along the options , it simply doesnt appear.
Hi just trying to solve a similar problem. My machine would turn on but would not fill. It could be that your cold water filter is blocked. If no or reduced water pressure then the machine will not operate correctly. Take off back panel and you should see the filter assembly. GIve this a clean and see what happens.
We have 14 of these dishwashers and so far they have all proven to be very reliable machines. This is the first issue in 4 years.
Paul
Aug 12, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
BELLING IDW604
i have just fixed my e4 code problem
take off salt cover and remove all water with tea towel or dish cloth you must make sure all water is out switch off at wall then back on if still e4 reapeat getting water out my washer is cleaning as i type
Dec 01, 2007 | Belling 24 in. IDW603 Built-in Dishwasher
Frigidaire Dishwasher FDB1050REC1 - Washing Indicator Light Blinking
Here is what happened, you pulled the door open without pressing cancel and allowing it to pump the water out, hence the "flooding in the bottom". This is just one reason why it maybe blinking, there is a water sensor in the bottom. If your dishwasher is hooked up properly to any decent garbage disposal, run the disposal for about 30 seconds to a minute. This should pump the water out, more like activate a light siphoning affect. It should work as normal. If you are not having luck with that, detach the DW drain get it low and let it siphon.
Jun 26, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Belling 24 in. IDW603 Built-in Dishwasher Logo
639 people viewed this question
Top Belling Dishwashers Experts
Kamil Owsianiecki
Level 1 Expert
Oloyede Monsuru
Are you a Belling Dishwasher Expert? Answer questions, earn points and help others
