Question about Dell Dimension 2400 PC Desktop
Dimension 2400 Flashing Power Light
This is all I get when I try to power the machine up. The green power light (L1) on the motherboard lights when AC power is connected. None of the four diagnostic lights on the back are on. I've disconnected everthing from the motherboard (including boards) except the cable connected to the power switch and the power cable from the power supply: same result. My best guess is that the power supply died, but how can I test to make sure?
Thanks in advance,
Steve
  • steveje0711 Nov 25, 2008
    All quadpack lights are off. No sounds of any kind. The only response to the power switch is a flashing amber power light. I've disconnected everything from the MB except power switch & lights and power cable. How can I further isolate the problem to the PS or MB?
    Problem Solver:
TO TEST TO SEE IF THE POWER SUPPLY IS FULLY FUNCTIONAL IS TO USE A VOLT METER ON THE 20 PIN CONNECTOR THAT ATTACHED TO THE MOTHER BOARD. SET YOUR METER TO DC VOLTS IN THE RANGE OF +5 TO +20 AND TOUCH THE PINS FROM 1 TO 20 INDIVIDUALLY. tHERE ARE THREE PINS THAT SHOULD DISPLAY AT YOUR METER A +5 VOLTAGE READING, iF THEY DO, YOUR POWER SUPPLY IS OK. iF THE FAN OPERATES, THE POWER SUPPLY IS OK. ALSO, IF YOU DISCONNECT THE CONNECTOR FOR YOUR POWER UP BUTTON AND THEN REMOVEPOWER CORD IN THE REAR, WAIT 20 SECONDS THEN ECONNECT POWER CORD, YOUR COMPUTER SHOULD START UP AND YOU WILL HEAR THE FAN. IF YOU STILL GET NO ESULTS, YOUR FINAL TEST WILL BE TO RESET YOUR BIOS AT THE SOCKET. REMOVE GREEN SHROULD COVERING HEATSINK, RELEASE TWO GREEN PLASTIC STRAPS ON EITHER SIDE OF HEAT SINK, LIFT THE HEAT SINK FRO PROCESSOR. [ NOTE: IF YOU HAVE HAD YOUR 2400 AS LONG AS i'VE HAD MINE, THE HEAT SINK WILL BE A LITTLE SNUG TO THE INTEL P-4 PROCESSOR, JUST WINGLE IT A LITTLE AND IT WILL COME LOOSE. ] YOU WILL SEE THE PROCESSOR AND A SMALL LEVER ON THE SIDE OF THE SOCKET, RELEASE THE LEVER AND THAT WILL RELEASE THE PROCESSOR, REMOVE AND RE-SEAT AND REATTACH THE HEAT SINK AND RELATED PARTS, NOW TRY AND BOOT UP. THE FINAL TEST IS TO REMOVE THE CMOS BATTERY FROM ITS HOLDER, THIS TO RESETS YOUR BIOS. WE ALWAYS ASSUME THAT, THAT BATTERY LAST FOREVER, IS DOES NOT AND MAY NEED TO BE REPLACED THE LAST RESORT REGRETABLY, IS A FAILED MOTHERBOARD, IT WILL BE DIFFICULT TRYING TO FIND THE SAME ONE, EVEN ON E BAY, GOOD LUCK AND LET ME KNOW THE RESULTS, jOHN jhaskins75@comcast.net
Posted on Nov 26, 2008
    Scholar:
  • 172 Answers
This is a blown motherboard, i have just repaired one of these today using a new board.The processor socket has blown. Boards currently available.
compdoctor2005@btinternet.com
Posted on Nov 27, 2008
  • 61 Answers
What it the colour of the qudepack (4 back led's ) may be your guess is right but there might be possiblities that the M/b must have gone bad too do you hear the memory beeps?
Posted on Nov 25, 2008
Motherboard aux power light is flashing
If you mean the power button just flashes green but it does not power on then your motherboard might be the issue. Remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. In other words just have the power supply and motherboard connected and see if the power light stays solid green. If it does then start re-inserting cards and connecting drives etc (WITH POWER DISCONNECTED) to try and isolate the problem. If not then your motherboard is probably defective and needs to be replaced. Also plug the computer directly into the AC wall outlet.
Nov 16, 2012 | Dell Dimension E521 PC Desktop
My dell 2400 wil run for sometimes 10 sometimes 45 minutes and the the monitor loses signal and the power light is amber and the hard drive light is green, the diag. lights in the rear are either off or...
The power supply may be going out. Go to the Dell website, select support, enter your service tag number and find your symptom to determine the problem. The lights in the back will help you isolate the issue by cross referencing it to the lights that are lit and not lit.
Nov 02, 2010 | Dell Dimension 2400 PC Desktop
I have a dell dimension 2400. My starts up fine
Most likely a motherboard issue.
Also ensure the CPU Heatsink is firmly attached. If the heatsink is loose, replace the plastic heatsink retainer
If it is secure, then the motherboard is the most likely failure point
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
May 19, 2010 | Dell Dimension 2400 PC Desktop
Dimension 2400 won't start up a green light comes on on the start button but nothing else? This isn't the first time this has happened, in the past what I could do was simply shut the machine off (hold the...
Hi There, the1st and quickest thing to try would be checking if the power supply is faulty, very common problem, if this isnt the problem then more than likly the motherboard. Let me know how you get on or if i can be of any help.
Regards
Grant
Nov 02, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 with steady amber power light and diagnostic lights of ABC green and D off. What could be the problem?
Steady amber power LED is indicative of a problem with the motherboard. Remove all external connections except power, remove all PCI Cards, ram, disconnect power from all drives, turn on see if power LED is still steady amber. If it is, more than likely the motherboard has a failure. Also check to see if the CPU heatsink is firmly seated (The plastic retainer has been known to fail causing the CPU to overheat)
Oct 04, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 hit by lightning. the green
it can be one of 2 things:
1. if the battery charge light is all that comes on then you motherborad is busted.
2. if the power light turns on without the screen showing anything then you will need to replace the screen, but first connect it to an ordinary PC monitory and see if it works from there before changing anything.
Jul 18, 2009 | Dell Dimension 2400 PC Desktop
DEMENSION 2400 WONT POWER UP
It sounds like the power supply went.
Take it to your local computer repair shop for repairs.
Good Luck.
Mar 13, 2009 | Dell Dimension 2400 PC Desktop
Dimension 2400 can not power on
If you have no power by pressing the front power button and you have verified that the black connector coming from the power switch on the front is connected properly to the motherboard, then make sure that both connectors from the power supply are connected properly, the main connector and the p4 connector. Reseat both of the connectors to be sure.
If you still have no power and still have the light coming up on the motherboard then I think the motherboard may be bad cause that means something is shorting out the motherboard and not allowing power to go thru it properly.
Mar 08, 2009 | Dell Dimension 2400 Power Supply ** FREE...
Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Aug 08, 2008 | Dell Dimension 8300 PC Desktop
Dell Dimension 2400 PC Desktop Logo
925 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
