Question about RCA D52W19 52" Rear Projection Television
RCA HDTV chassis # ITC222 will not come on.
I have a RCA HDTV and my chassis # is ITC222. my television willnot come on. i have unplugged it and let it set about two hours and it still will not come on. I have had it about 3.5 years. When I hit the power button i an hear it click like it is going to come on but no picture or sound. What can I do.
  • RCA Master
  • 8,617 Answers
Most likely the Flyback 259296 and CP150 you can get replacements at the following link with free instalation instructions
http://servicemanuals.vstore.ca/
Posted on Nov 28, 2008
I have a rca hdtv and it will turn itself off then back on after a few seconds cna someone please help me with this
sounds like the classic sign of a bad small signal board especially if you have one of the ITC222 chassis rear projection RCA tvs
Mar 21, 2013 | RCA Televison & Video
My tv dosnt turn right on it takes about 5 minutes
The CP150, CP120 and CP114 capacitors are most likely getting weak. Very common with the ITC222 chassis in both RCA and GE models.
Jun 04, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
After 10 minutes power shouts off
small signal board is the most likliest cause. That a common problem with the ATC221 and ITC222 that model used both different chassis designs. www.tvrepairworld.com has replacement boards available.
Feb 18, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture on TV shuts down but sound still on.
If this RCA TV has a Chassis number of ITC222 then you need to call a tech to swap out the deflection circuit board for a new or rebuilt board. This RCA Chassis is a TV Techs worst nightmare to repair.
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Television will not power on after power surge
Hello , I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83 http://www.electron-age-technologies-llc.com
May 27, 2009 | RCA D52W19 52" Rear Projection Television
52" tv
It sounds like youre decsribing the ITC222 chassis HDTV rear projection. Look on the rear tag to see if its a ITC222 chassis and let me know and I can assist you with it.
May 18, 2009 | Televison & Video
RCA D52W20 won't come on
I believe this may be your problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you,
I hope this helps,
Shuttle83
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
R52WM24
I will need you to look on the rear tag and let me know the chassis number as that model was produced with two different chassis numbers ITC222 and the ATC221 chassis was used, But the chassis number will be on the tag on the rear panel. Please reply to this same post and I will help you locate the power supply board.
Aug 13, 2008 | RCA R52WM24 52" HDTV Projection Television
Looking for R52WM24 part
That should be the ITC222 chassis, can you look on the rear of the set and let me know which chassis it has listed on the tag, I should be able to help you out. please respond to this same post.
Jul 19, 2008 | RCA R52WM24 52" HDTV Projection Television
Don't understand
Can you look on the rear of your set and give me the chassis number and I can explain as that model used three different chassis designs one was ITC222, then ATC221 and ATC321 it should be marked on the rear tag.
Jul 10, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W19 52" Rear Projection Television Logo
467 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
