Question about Ricoh Aficio 1035 Copier
Scan Can I scan a document and send it to a specific file. The Product is a Ricoh Aficio 3030
  • 65 Answers
Yes you should be able to set up a destination in your address book. The folder must be shared. Click here for the scanner reference for this machine for more information.
Here is a link to all of the other manuals. Hope this helps. Let me know if you need more help.
If this helps you out, please rate this as fix ya.
Posted on Nov 25, 2008
I used to be able to scan a lot of documents and then just last week I couldn't scan any document using the Ricoh Aficio Type 2018. The message "Sending has failed. Press Job Information key to check the...
It is a problem with the network connection, if you are using scan router recheck the configuration settings in case of scan to email check connection with smtp server, port no. ssl on or off and do the connection test, check mail server authentication, rest assured it is not a problem with the machine or GW controller.
Feb 18, 2015 | Ricoh Aficio 2018D All-In-One Laser...
Hi, I have multifunction printer (Ricoh Aficio 1515MF) I want to use it to scan many pages to a folder in my pc, unfortunately I didn't found any way to make that, the only way I found by email, then I set...
If the printer came with operating software you should use it to scan the document. Even without the manufacturer software (but not the drivers) you can use Acrobat or Word Perfect or LibreOffice to scan to the application then save the scanned file either as pdf, image format, or as text (OCR).
There are some free scanning software available on the Internet: freeOcr, pdfViewer, Paperscan Free edition They are usually able to send the file to an application or save in a specific format. If they are not able to scan a multipage document you will have to scan one page at a time then assemble the pages
Oct 11, 2013 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh scan email
get operation manual for email and scan will explain how to set it up. or have copier technician come out.
May 14, 2013 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
How to scan documents and save them as jpg Format as default instead of tiff?
On some copiers, there is an option to scan as JPG. Press the Scanner function key on the left, and look for a button on the screen that says something like "Scan as file type." Press this button, and if that copier can scan JPG files, you should see the option there. Otherwise you might have to scan as TIFF files and then use a program like Microsoft Office Picture Manager to convert them to JPG images.
May 21, 2010 | Ricoh Aficio 1035 Copier
Ricoh 3235 scan to eail will not work
for this to go to email you will have to enter the administrators email address the document is going through this can be found by going into the user tools(123 button) then system settings and file transfer at the bottom there is a tab for administrators email address enter it here and it should allow the emails to got through.Good Luck
May 08, 2010 | Ricoh Aficio 2232C Color Copier
Ricoh Aficio 2018D - previously used a scan router software to scan to file on Windows server. Now being told Windows server 2008 is not compatible. We are using scan to email but very cumbersome. Is there...
No, all the newer machines have imbedded scanning. The scanrouter software was an old product and only supported through 2k3 server. I would setup an old PC with the scanrouter and whatever platform you were running before and use it just for scanning. You can install it as a service so it will run on its own.
Feb 02, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio Scan Reads
the system can track scans however is accessed through SP mode only.
www.p4photel.org
Sep 05, 2008 | Ricoh Aficio 450 Copier
Problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Jul 02, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 1075 - SMTP error message
To use the scan to email function on your copier you need some settings from your internet provider (email setting specifically). Go into Outlook options and get your SMTP server, user name and password.
On your copier you need to change under User tools, system setting and file transfer and put these settings in. As long as your machine is set up for scan to folder thats all you should need.
Apr 18, 2008 | Ricoh Aficio 1013F Copier
How do you set a scanned document folder on a ricoh aficio 1045?
do you mean how do you creat a folder to scan your documents into ? if you have document server or scanner buttons on the key pad, then just select scan and mofidy the folder to your choosing.
Thank You,
Mikey
Apr 03, 2008 | Office Equipment & Supplies
Ricoh Aficio 1035 Copier Logo
304 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
