Question about Goodman GDS80904BNA Open Flame Heater
DOESN'T FIRE - 1 BLINK CODE
THE FAN STARTS AND IT LIGHTS UP AS IF IT IS GOING TO FIRE, BUT SHUTS DOWN AFTER A FEW SECONDS. I'VE BEEN TOLD ITS A ONE BLINK - BUT I CANNOT FIND MY MANUAL NORE THE CODE EXPLANATION CHART.
  • 27 Answers
If the unit fires-up but drops out soon after then you main burner flame sensor is not working
Posted on Nov 26, 2008
What do I do when error code reads E 15 . Dryer runs for a few seconds than shuts down. I've tested micro switch and i'ts fine.
Post some pictures of your pilot assembly. I think this might be one of them spark sensor deals where the pilot lights and then detects flame then relays that back to the control for igniton verification. OR just try and clean up the electrode with steel wool and see if the flames stays lit is what I would try.
Jan 07, 2013 | Wascomat Parts Wascomat 231754 Dryer...
Power supply isn't working
dOES SET COME ON WITH POWER LIGHT ON AND A FEW SECONDS LATER SHUTS OFF?
WHEN it turns off press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both.
watch for power light to blink a two digit error code like 1 blink, 2 blinks and then pause and repeat the code for about 5 times .
Let me know what code you find .
Dec 21, 2012 | Mitsubishi VS-70707 70" Rear Projection...
Push power button and timer button lights for a few seconds and then tv turns off model is Ws 55859
When it shuts down go to the set and press the menu and the Device/Input button both in together and hold for 6 seconds then count the two digit blink code from the power indicator. it will blink a two digit code which repeats several times.
Jul 23, 2011 | Mitsubishi WS-55859 55" Rear Projection...
Power button goes on for a few seconds when clicked and then turns off before picture comes on.
When it shuts down press the menu and Input buttons on the set both in together and hold for 6 seconds the led will then start to blink a two digit blink code which will repeat a few times indicating where the problem is. Let me know the blink code sequence and I will assist you with the problem.
Jun 11, 2011 | Mitsubishi WS-55809 55" Rear Projection...
Oven and broiler will not stay on.lights blink
The cooling fans under the cook top must blow to close fan sail switches. fans stop , oven shuts down. You may have a problem with your main controler board. Shut off yor breaker to range for at least 20min. retry, if it still does same thing your main board is NG. Its burried under the right side burrners.
I recomend calling thermador for service tech. Its not a do it your self thing.
Nov 03, 2009 | Thermador PG486GEBS Stainless Steel...
Trying to replace lamp fan
First let make sure it's the Lamp fan. What many people think is the fan, And by the way there are three fans in this model, What sound like a fan is in fact a color wheel. So listen to the set as it starts up, these Samsungs make certain sounds when they start. First after you hit the power button you get the "Samsung Tones" from the speakers, second ALL the Fans start 1 to 2 seconds later the color wheel starts then stabilizes, third you may here the lamp fire. So if the sound takes two to three seconds after you turn the set on it's the color wheel BP96-00250A Now when it shuts down its like this First the shutdown "Samsung Tones" then watching from the back after a few seconds the lamp will shut off, then the color wheel stops but all the other fans remain on for about 2 minutes. I've worked on thousands of these and in only one or two was the problem a fan. but on the other hand I have enoghf bad color wheels I was able to make a pertty inpressive Christmas decoration
Feb 05, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung 56" shuts off after 5 or 10 seconds see a checker board image before shutoff
When the set shuts down you need to see what lights are blinking. For example: Timer/ Temp/ lamp on the front panel. You should also count the number of times they blink and the sequence. Most DLP`s give an error code alerting the technician to check the balast, lamp, or fan etc. for malfunctions. Unfortunately I can not tell you exactly what is wrong given the current information. Howrver, the last Samsung I repaired for shutting down had a bad light engine.
Nov 29, 2007 | Samsung DLP HL-P5663W 56" TV
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Heating & Cooling Logo
133 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
