Question about Lexmark X5495 Printer
My Printer won't print
The paper won't feed and the computer keeps telling me to Load paper. The paper will jam at times but the computer won't pick up on it and will continue printing, then tell me the job is done.....Please Please help I run a business and i can't have this happening...Lizette
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
If the problem repeats then there is the problem with rollers you may need get it replaced if its within warranty or get it serviced .......
Good luck...
Posted on Nov 25, 2008
When we hit the print button to print a page the paper will not feed into the body of the printer and the sign flashes for us to remove jammed paper and hit start button, when we do this it just keeps...
Paper jams
85% of paper jams are caused by worn rollers Chances are, when your tech arrives, he'll tell you that the jams were caused by worn feed rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
MP150 reset:
Feb 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
My printer keeps telling me to remove jammed paper, but there is no paper in it!! Help, and thanks!
OK do one thing off the printer then restart it.Reset the printer from printer option botton. then off again. After that when you on the printer then the massage naver come.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Will not let me load paper - it keeps telling me I need to load paper but when I press select the paper is not feeding through
there may be an jam in the paper tray,, or you have to cancell all the printing commands given to print then .. check
Sep 27, 2009 | Dell 942 All-In-One InkJet Printer
Paper jam while printing on BROTHER MFC-290C all-in-one
hey
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 03, 2009 | Brother MFC-290C Printer
My printer always tells me paper jam
the issue can be found when the paper feed rolls in the printer or the internal encoder strip are dirty.
Please try the following:
- open the backdoor of the printer
- also open the front door
- unplug the power chord without shutting down the printer
- now clean the paper feed rolls inside the printer with a soft rubber
- turn the rolls some times (10 tries or so) from down to up
- close the backdoor
- move the cartridge cart some times from one side to the other
- now you see a transparent strip over the metal bar
- this strip you can clean with cleaning alcohol
(be carefully! don't loose the strip or take too much alcohol)
- now let the printer dry over night (let it be open)
- next morning, close the front door
- press # and 6 at the same time and hold them
- keep them pressed and plug in the power chord
- keep them pressed until you see "semi nvm reset"
done
Hope it helps,
Henning
Feb 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
Jan 29, 2009 | Epson Stylus CX3800 Printer
Mis-feeds paper and thinks it has paper jam
the gears of the printer r worn out and they have hanve lost their allignment settings so this problem.either replace the gears.or the other solution.do not insert the paper in the tray ,keep it little bit outside and hold the end of the paper in hand when you will give a printout the printer will make a noise of picking the paper at that time just push the paper inside and then it will print properly.
Dec 10, 2008 | HP Deskjet 2330 InkJet Photo Printer
Paper Jam
try this
alternative :
Sep 21, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Paper will not feed
These are basically throw away printers. But you might try checking the paper path. There are small plastic "arms" that guide the paper as its picked up and goes throught he printer. Sometimes one of these may get stuck in a position that makes the printer think there is paper in the path somewhere.
Mar 19, 2007 | Apple Epson Stylus Color 777i InkJet...
Lexmark X5495 Printer Logo
98 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
